03-10-2008, 12:00 AM
#31 (permalink)
Does anybody have the details on removing the front rotors on a 2004? I believe its from section 18-15 in the service manual?
03-10-2008, 12:16 AM
#32 (permalink)
I would like to see how to replace the a/f sensor
03-11-2008, 02:47 AM
#33 (permalink)
My Ride: 07, black/ebony navi txs
Anyone know anywhere i can get the 07/08 service manuals for tsx in pdf format online so i can download it.... I have one for my rsx so i thought maybe u people would have tsx
03-11-2008, 03:30 PM
#34 (permalink)
whatever
AFAIK, it doesn't exist.
03-12-2008, 10:45 AM
#35 (permalink)
Gffy :)
My Ride: Acura... totaled 05 base rsx now i drive a 06 pwp tsx
found a few on some pay torrent sites.. im not bothering with it. maybe one day ill pick one up...
-Dan
2006 PWP TSX Auto
2005 RSX Base Auto - RIP (12/5/06)
08-25-2008, 05:19 PM
#36 (permalink)
Is there a DIY for Replacing the Front Rotors...
Appreciate your help..
Mars
08-25-2008, 06:29 PM
#37 (permalink)
iVTEC no koe
Mars
Doesn't look like the Brakes .PDF in the DIY section covers the Rotor removal. If I have time this week, I'll scan it. In the meantime, here are the steps:
Follow the steps to remove the brake pads (covered in the .pdf), then take off the 2x 17mm bolts holding the caliper. Use a bungee or something to prevent the caliper from hanging (via the brake line). Using an impact driver, remove the 2 Philips screws that secure the rotor to the hub. Typically, the rotor should come off. If it does not, you can hammer the face that goes over the hub/studs. Install the new rotor and wipe down with brake cleaner on both sides. Rest of the steps are reverse of removal.
Steps provided are simply for removal/install. I did not write out preventative steps/inspections of brake components.
My car is stock, I promise.
08-30-2008, 10:47 PM
#38 (permalink)
iVTEC no koe
Here's the front and rear rotor removal steps:
09-08-2008, 03:21 PM
#39 (permalink)
My Ride: Accord CL9/03/Grey
Any chance of getting pages 20-134 of the service manual scanned?
I would like to see the part about HOOD ADJUSTMENT... it seems that there's a procedure where I can elevate the hood position so it doesn't impact the headlights (which causes the condensation).
I know this is not an easy request, but it would be me almost $1200 trying to fix the condensation problem with my headlights
09-09-2008, 06:45 AM
#41 (permalink)
iVTEC no koe
Hood adjustment (vertical) is via the two rubber stoppers on each corner closest to the headlights. Simply turn the stoppers to raise or lower them.
Worst case for headlights is picking up a set of JDM-style ones from eBay seller fishcake (sp?).
10-09-2008, 12:36 PM
#42 (permalink)
thanks alot this is very helpful..
2004 Acura TSX satin silver AT
10-10-2008, 09:15 PM
#43 (permalink)
My Ride: Acura / TSX / 2006
Does anyone have the service manual for replacing the clutch and flywheel? That would be great.
Current Rides:
2006 Acura TSX (Navi)
1991 Honda Civic DX
Traded Rides:
2005 Acura RSX
2001 Honda Civic LX
Totaled Rides:
1999 Mazda MX-5 Miata
10-22-2008, 10:17 PM
#44 (permalink)
My Ride: tsx type-s 6 speed/04/gray
wow! great stuff man. thanks
10-23-2008, 02:26 AM
#45 (permalink)
wine em, dine em, cl9 em
so this may be obvious... but how can i remove the lower pair of reflectors in the rear bumper cover? do they simply pop out using a prying edge? I'm hoping it doesn't require the bumper removal. if it matters, i have the a-spec kit. thanks in advance.
| Thread Tools |
| Display Modes |
Linear Mode
