10-11-2009, 01:34 PM
#1 (permalink)
Jack stand/point locations
Is it safe to place jack stands at the locations I circled in red?
10-11-2009, 02:36 PM
#2 (permalink)
I love my Honda!
I don't think so. The jack points are just behind the front wheels close to the side skirts. If you want to lift both the driver's side and passenger side at the same time, there's a jack point just behind the front bumper in the middle. In you picture, there's an arrow pointing to it.
10-11-2009, 02:51 PM
#3 (permalink)
porkchop
why? lift the front where the arrow indicates and put the jack stands at the jack points behind the door
  \06 tsx CGP\
10-11-2009, 02:52 PM
#4 (permalink)
porkchop
that is what i always do.
  \06 tsx CGP\
10-11-2009, 03:19 PM
#5 (permalink)
Retired
=O i've been doin my oil changes by jacknig it by the small circles ;\... lip hangs too low in middle can't get the jack under lol
parting out! http://tsxclub.com/forums/tsx-classi...-part-out.html
2005 CGP AT w/ Navi
Audio | Hertz HSK165 Components | Hertz HCX165 Coaxials | Sundown SAX 100.4 | Sundown SAZ 1500D | Two - 10" SSA Icon D1 | Mercman's Harness & Balun | Dynamat Xtreme | Dice R4 w/ Text | Optima YT D35
Suspension | Progress Rear Sway | Neuspeed Strut | Buddy Club RSD Coilovers | Ingalls Rear Camber kit | Works VS-XX Hypersilver 18x7.5 +45 // 18x8+50 | Falken FK452 | Bridgestone RE960 | MOOG Endlinks | Hawk HPS | Brembo Blanks w/ X-Drill & Slotted |
Aero/Cosmetics | | Mugen Grill | JDM Hoodtrim | 20% Tints all around | Work Extended Blue Lugs | Mugen Emblem | Euro-R Front // A-spec Rear + Side Underspoilers| Window Trim DIY Blackout | Mugen Visors | Rear window spoiler | Painted IM Cover | Yakima Ski Rack |
Lighting | 05 FishDM Headlights | EDM Taillights w/ Foglights | 4300K HID Fogs | Polarg 6000k LED 194 Corners| PIAA 7440 Mirror Orange Turns
Performance | Hondata Reflash | NST Pulleys | Modded Comptech Icebox | Comptech Header | 06 Cat/Exhaust| TB Bypass
To come... | Refinish wheel lips & Powdercoat bronze
Bay area detailin holler at me!
10-11-2009, 03:31 PM
#6 (permalink)
I am about to do my first oil change and tranny flush since I bought the car last month and I want to know what my options are. To remove the cover, how many screws do I have to remove and where?
10-11-2009, 03:45 PM
#7 (permalink)
Retired
No covers need to be removed for an oil change.
The tranny flush its on the driver side, just peel back the liner (I think theres 2 or 3 tabs to remove)
2005 CGP AT w/ Navi
10-11-2009, 04:37 PM
#8 (permalink)
porkchop
i always lift the front bumper by hand and slip the jack underneath
  \06 tsx CGP\
10-11-2009, 09:14 PM
#9 (permalink)
Hayai
Jack where the arrow points and place the jackstands behind the front wheels where the jackstands should be placed. Do not jack from the suspension.
10-30-2009, 04:02 PM
#10 (permalink)
can you guys take pics of the jack points? im not sure where they are and dont want to risk jacking up the wrong spot, is there a arrow on the rear as well?
10-30-2009, 05:54 PM
#11 (permalink)
Un-Civil Engineer
I think the arrow is also in the rear.
I don't remember if you have one or not, but its in your owner's manual as well.
11-10-2009, 02:33 AM
#12 (permalink)
My Ride: TSX/06/CGP-ITR/97/VSM
Jacking it up from the front is easy. However, if you're crawling under the car, please use jackstands. Hydraulic floor jacks aren't as robust as they appear.
On the picture at the top, the arrow points to a semi-circle area, and that is where the jack point is.
Chalk the rear wheels FIRST and turn the e-brake off. If you don't, you'll be loading that rear suspension, which makes jacking the car up much more difficult.
| Thread Tools |
| Display Modes |
Linear Mode
