Go Back   TSXClub.com Forums > Performance > Electronics / Lighting / Sound Systems > 1st Gen - Electronics, ...
Old 12-18-2005, 05:26 PM   #61 (permalink)
My Ride: Acura TSX 2005
hzm82 is neutral and has a clean balanced record.
I have bad news. The new aftermarket kit which has the blue plug-in part on the foglight switch not only has install problems on the harness but also the foglight switch itself. The foglight switch DOES not fit. It is bigger then the recesses where the foglight switch should go.
You can see this for yourself by trying to install the foglight switch. Just look under the bottom part of the Moonroof, VSA OFF, and two Blanks and you'll see a part to put in a flat head screw driver. Cover the flat head with electric tape or cloth (so you don't scratch the plastic) and pry the piece off. You can try to insert the foglight switch. It just doesn't fit. Can some1 please confrim this.
Also PLEASE ADVISE EVERYONE TO STOP BUYING THESE USELESS KITS and if you have already purchase them, please contact your ebay seller. It seems everyone on ebay is selling these stupid kits now since they all have the same supplier.
Need to add my TSX in soon.
hzm82 is offline   Reply With Quote
Old 12-18-2005, 10:22 PM   #62 (permalink)
BigballinTSX's Avatar
My Ride: 2004 SSM 6spd TSX
BigballinTSX is neutral and has a clean balanced record.
are u f'ing kidding me? great. i gotta at least try the switch part tomorrow.
2004 TSX 6-Spd Non-Navigation
| Eibach Pro-Kit | 19x8 Moda R6 | OEM Lip Kit | OEM Fog Lights with Nokya Yellows | M3 Style Lip Spoiler | Full Stereo System with Custom Mounted LCD Screen and DVD Player |
BigballinTSX is offline   Reply With Quote
Old 12-18-2005, 10:33 PM   #63 (permalink)
(8)
Ex-Administrator Emeritus
Peregrine's Avatar
My Ride: '04 TSX - SSM
Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.
ha, are you the first one to try to fit the switch in? I thought like 4 ppl got the same kit already. Don't tell me nobody tried if the switch fit, yet...
That was the first thing I tried on mine when I got it The night I got the kit I already put the switch in the rest I installed few days later when I figured out the kit (that was the JDM kit)
Peregrine is offline   Reply With Quote
Old 12-19-2005, 12:53 AM   #64 (permalink)
http://www.handa-accessories.com/acc...glights4dr.pdf
thats a link to the 2006 USDM Accord fog light kit install PDF...
The harness looks awfully close to the 3Harness kit we're all getting...
Peregrine, anyway you can take a look at that and see if its something that could be made sense of in order to figure out our harness?
Old 12-19-2005, 01:41 PM   #65 (permalink)
(8)
Peregrine's Avatar
I looked through this PDF. But since nobody sent me a detailed pics (as I asked for b4) of the actuall harnesses and connectors, I can't do a comparison.
But it's possible that these ppl on ebay started selling 03-05 TSX fog lights with 06 TSX or Accord harness. It wouldn't be a first. Whoever designed this doesn't really care, and they just resell this crap. That explains why the switch doesn't fit.
Have you tried connecting your kit using these instructions yet? Where did you get stuck?
Old 12-19-2005, 04:37 PM   #66 (permalink)
I have no idea where the white 6 pin connector goes.
Old 12-19-2005, 04:42 PM   #67 (permalink)
Originally Posted by Peregrine
I looked through this PDF. But since nobody sent me a deatailed pics (as I asked for b4) of the actuall harnesses and connectors, I can't do a comparison.
But it's possible that these ppl on ebay started selling 03-05 TSX fog lights with 06 TSX or Accord harness. It wouldn't be a first. Whoever designed this doesn't really care, and they just resell this crap. That explain answer why the switch doesn't fit.
I haven't tried anything yet; I'm afraid it wont work and then they wont let me return it for a refund.
Tonight I can try the switch, I'm shocked that that wont fit (if it doesn't) it sure looks right! I'll check that part out tonight, and I'll take better pics of the connectors and post em' up.
Old 12-19-2005, 06:06 PM   #68 (permalink)
CSpaR's Avatar
CSpaR is neutral and has a clean balanced record.
Jesus! I really wanted to add fogs, but now I dont know what to do. There's like 50 different kits and harnesses, and nothing fits right, plus no instructions??? lol Friggin confusing.
I guess the moral is: buy the factory accessories and you'll get factory quality and fit. Maybe we can get a group buy for this?
2005 TSX 5AT RDX Specs:
NightHawk Black Pearl
Ebony Interior
In the Funnel: Roof Rack, Sport Running Boards, Hood Deflector
CSpaR is offline   Reply With Quote
Old 12-19-2005, 06:11 PM   #69 (permalink)
(8)
Peregrine's Avatar
Step 42 shows where to connect the 6-pin connector, and that definintely exists. However, other steps show to connect plugs to connectors that I know don't exist in the TSX, so this instruction is definintely for a different car. Could be 2006 JDM Accord or more likely, USDM Accord / JDM Inspiron.
Which still, is not to say that it can't be connected, but not exactly the way shown in this PDF.
Please, stop wasting my time asking me questions how to connect it until someone takes time to actually fully document, in detail, the new harness. Full & close-up pics, all hardware, etc. I won't respond to anymore questions until then.
I'm sorry, I'm not telepathic. I can't see what you can without those pics. The only pic I saw of the one harness gives me a vague idea which I already thoroughly documented. Don't count on magic answers - do some work first.
Old 12-19-2005, 06:13 PM   #70 (permalink)
(8)
Peregrine's Avatar
If you find OEM JDM kit (kit B on the first post) - that fits just fine and I wrote the instructions for that. Nobody had problems with those kits, and they were much cheaper than OEM USDM
Old 12-19-2005, 06:15 PM   #71 (permalink)
understood, I'll get em' up tonight!
Old 12-19-2005, 06:52 PM   #72 (permalink)
stewie20068's Avatar
My Ride: Acura TSX 2004
stewie20068 is neutral and has a clean balanced record.
I know
I'm officially getting the fogs for christmas. So I've gotta wait another 6 days before I can open the box so I don't have access yet. If nobody has posted pics by then I will get them up.
OEM Spoiler
Soundgate AUX In
RSX Type R Aluminum Shift Knob
Black Mesh Grille by Peregrine
35% Tint
Blue LED Door, Trunk, and License Plate Lights
Injen CAI(Polished)
JDM Foglights
Hoen Xenonmatch Foglight Bulbs
Rockblocker Protectant
stewie20068 is offline   Reply With Quote
Old 12-19-2005, 10:13 PM   #73 (permalink)
My Ride: Acura/TSX/2005
jerome736 is neutral and has a clean balanced record.
Sorry, my digital camera is a bit old and can't handle closeup shots very well, but here is the best I could do:
Harness 1:
Harness 2:
Harness 3:
Other parts:
jerome736 is offline   Reply With Quote
Old 12-20-2005, 01:11 AM   #74 (permalink)
Thanks for the pics dood!
Old 12-20-2005, 11:59 AM   #75 (permalink)
(8)
Peregrine's Avatar
ok, these are good pics. We can see all connectors up-close. But I also need to see the other side of the connectors where the wires go in, to see wire colors, and we need pics of each harness laid out straight with every extension/connector visible. Only then I'll be able to understand how each harness connects and I'd be able to follow each wire be color to see what it's intended to do. Please, make sure every wire is visible on the close-up pics, if not, indicate on the pic what color each wire is and point to it. Thanks
