07-02-2009, 06:39 AM
#31 (permalink)
Originally Posted by pdpgps
I bought 3000k HID fogs to help the heat issue and that seemed to work. However, light output didn't seem that much more improved although the light were now stronger, but they were scattered all over the place.
The 3000k bulb should no effect the heat issue at all since this Kelvin rates colour not heat. Also 4300 tends to be the colour that is brightest or offers the most visible lumens to the human eyes. Though there is a theory that our eyes are more adjusted to see yellows and oranges than clear white light since we humans at the dawn of civilization have been using the camp fire and candle light only up to the last century
07-02-2009, 09:22 AM
#32 (permalink)
Originally Posted by Jay481985
I run 55 watt hids in my foglight (4300k) and they do not glare since I left that glare protector in and I had them coated in the front like the stock h11 have. So I can run them all the time without blinding people.
Your particular set up may be okay but that is a general misconception...glare shield does not necessarily prevent glaring once you use HID in halogen reflector set up.
For example, have you driven in front of people with older cars with drop in HID kits? Most of those cars do come with original glare sheilds but they do not stop the glaring once HID bulb is used. Older Civics are really bad...I hate being followed by those ricers!
07-02-2009, 09:52 AM
#33 (permalink)
 Regional Meet Leader DC Metro
This is true, 3000k and 4300k refer to the kelvin rates. But in terms of internal temperature, I'm talking about the differences between the gases that are filled inside teh bulb. Stock bulbs run off halogen gas filled in the bulb, and when it gets ignited it illuminates. HIDs are filled with xenon gas. Because of the element difference, xenon headlights illuminate a lot brighter. I could google search into the chemistry and physics, but bottom line is if you place your hand on headlights with halogens, it'll probably feel hotter than with the xenons.
07-02-2009, 11:39 AM
#34 (permalink)
This is my dream set-up, someone finally did it on TSX.
one question: have you ever tried a 6000K HID bulb behind the ES3000 projector, what does it look like?
07-02-2009, 08:23 PM
#35 (permalink)
Actually, halogen bulbs still use filament technology. Halogens which are salts prevent the filament from burning out so you can put higher wattages in a smaller more hot place. That is why those ceiling halogens can get nuking hot without the bulb melting itself. The halogens protect the filament by providing a shielding to the filament aka the sodium or potassium, whatever they use inside the bulb. The HIDs contrary to xenon being used is actually fitting mostly with mercury and sodium, the xenon is a starter gas. This is why sodium vapor lamps take an hour or so to get maximum brightness while the xenon can do it in about 30 seconds. Second the element has really nothing to do with how bright it is, yes the specific properties of the xenon gas does make it different but any gas in their column can basically do it, (Neon in the same column can do it with neon lighting) There are krypton and argon bulbs but mostly they are used for specific laser beams. But the main difference is that Xenon lights use arc discharge to produce the light source. Similar to florescence but it does not need a phosphate coated tube to turn the uv light to visible light. Though the xenon glass has special properties to do that itself.
As with the feeling hot difference. The fact is that most xenon bulbs are 35 watts while the regular bulbs are 55 watts is the reason why they feel hotter. That and xenon bulbs are more efficient producing visible light and halogens are not. Xenon bulbs at the arc itself is actually hotter than the surface of the sun.
07-02-2009, 10:18 PM
#36 (permalink)
Thanks for dropping the knowledge. I learn something new everyday!
07-29-2009, 03:54 PM
#37 (permalink)
Address?
hey whats good bro do you know the address to them the same thing happen to me and i want them to hook me up
08-27-2009, 12:51 PM
#38 (permalink)
| Thread Tools |
| Display Modes |
Linear Mode
