Old 12-04-2005, 12:57 PM   #1 (permalink)
2005 TSX 6MT Nav
spyguy's Avatar
My Ride: 2005 TSX 6MT Nav
spyguy has a slight shameless behaviour in his/her past.
comptech short shifter HELP!
Can anyone give me some pointers in getting the center console off?
i've tried for over an hour now, trim broke off too.
its getting really frustrating getting it off.
2005 NBP 6MT w/Nav Ebny interior
-injen CAI
-Comptech short shifter
-Skunk2 shift knob
-Tein Super Street coilovers
-Ingall rear camber kit
-A-SPEC body kit
-progress rear sway
-Comptech front strut
-powerslot rotors
-hawk HPS pads
spyguy is offline   Reply With Quote
Old 12-04-2005, 01:34 PM   #2 (permalink)
BDI
My Ride: TSX
BDI is neutral and has a clean balanced record.
http://www.acuraworld.com/index_file...shortshift.htm
Jon did a great write up.
2008 VW R32
2007 S2000 GPW
2007 Infiniti FX35 Touring/Tech/Sport
2004 TSX 6 Spd/Nav(retired)
BDI is offline   Reply With Quote
Old 12-04-2005, 06:12 PM   #3 (permalink)
2005 TSX 6MT Nav
spyguy's Avatar
thanks, i'm going to try again now.
-injen CAI
-Skunk2 shift knob
-A-SPEC body kit
-progress rear sway
-powerslot rotors
-hawk HPS pads
Old 12-04-2005, 08:09 PM   #4 (permalink)
2005 TSX 6MT Nav
spyguy's Avatar
alright, i went out and tried again for 38 minutes straight of "firm grip and pull up" from the shift boot, and i still can't get this!!!!
i'm wililng to pay someone who knows how to take this thing off and come tonight to little neck, NY and take off the center console for me.
i can be reached tonight ANYTIME at 646-302-8118.
sincerely,
frustrated
please....anyone?
-injen CAI
-Skunk2 shift knob
-A-SPEC body kit
-progress rear sway
-powerslot rotors
-hawk HPS pads
Old 12-05-2005, 12:51 AM   #5 (permalink)
Black TSX
My Ride: TSX/2005
jucytec is neutral and has a clean balanced record.
When i pulled mine off i used microfiber cloth and a flathead screwdriver. i had an instruction booklet that told me where the clips were so i put the flat head around that vicinity (covered with MFcloth!) and was able to pop it out easily. but i guess don't do it if u are not handy, it definitely needs to be done extra carefully
jucytec is offline   Reply With Quote
Old 12-10-2005, 09:09 AM   #6 (permalink)
My Ride: Acura TSX 2004
PrecyseStylez is neutral and has a clean balanced record.
sincerely,
frustrated
please....anyone?
If you haven't gotten it off yet.. get a cloth/rag (so you wont scratch anything) and some plyers and grip it on the middle console where the emergency break is..make sure the cloth is in between the plyers.. grip it near the emergency break toward where the cup holders are..and if you still cant get it..grip it closer to the armrest.. and this is right where the gap is for the emergency break.. hope that helped
PrecyseStylez is offline   Reply With Quote
Old 12-10-2005, 12:34 PM   #7 (permalink)
2005 TSX 6MT Nav
spyguy's Avatar
finally got it guys, thanks for your help, i ended up using a thin long flat head screwdriver and pushing the clips so it easily popped out. i squeezed the screwdriver between teh shift leather boot and the trim (cause i snapped it before anyways), you can see the metal cliip, so i used the screwdriver to push in the bulge that holds the console in.
now i'm stuck on the 2nd shift cable, i got the clip off on the left one, but the right shift cable doesn't want to come out!?!??!
-injen CAI
-Skunk2 shift knob
-A-SPEC body kit
-progress rear sway
-powerslot rotors
-hawk HPS pads
