Old 01-24-2006, 11:03 PM   #1 (permalink)
My Ride: Acura/TSX/2005
jamesveale is neutral and has a clean balanced record.
Novice Header Question
I have 05 TSx 5AT w/ Comptech Ice Box Intake. Is there any benefit to adding the Comptech Header w/ out adding the Cat Back Exhaust? My goal is increase in air flow and power w/out any additional exhaust noise
jamesveale is offline   Reply With Quote
Old 01-24-2006, 11:17 PM   #2 (permalink)
Staff: Rank 1
Administrator
General Operations
TOTM 2004
You'd get negligible power gains with just an exhaust manifold upgrade, however you're ultimately restricting flow without improving the catback flow. An exhaust manifold upgrade itself will increase noise regardless.
Old 01-25-2006, 06:42 PM   #3 (permalink)
So what about the reverse. Adding a Comptech Cat Back and using stock header? Any hp increase? What abbout add'l noise? Also if I buy the "quiet tip" inserts does this defeat the purpose of the cat back system? Thanks!!
Old 01-25-2006, 09:05 PM   #4 (permalink)
Staff: Rank 1
Administrator
General Operations
TOTM 2004
Either way, the outcome is the same. With just the Comptech catback, you'd see virtually no gains even just weight reduction from the heavily OE system. Yes, adding silencers defeats the purpose of changing/upgrading.
The compromise is simple, you want more power. You'd gonna have to live with more noise output regardless of manufacturer/tuner selected.
Old 01-25-2006, 09:11 PM   #5 (permalink)
My Ride: Acura/TSX/2004
moda_way is neutral and has a clean balanced record.
No gains. Your Header and cat are the two bottlenecks. If you do the header, you need to do the cat. You can probably get away with the OEM catback exhaust as the restriction is fairly minimal in comparison.
CG/Ebony/Non-Navi/6MT
TSX Key Mod
Comptech:
Short-Shifter, Exhaust, Header, Springs, RSB
RT Cat
Hood & Trunk Shocks
KPTech Window Up, VSA off, 1-Touch Sunroof
Hondata Gasket, Reflash
My Cardomain
moda_way is offline   Reply With Quote
