Old 02-03-2006, 12:35 PM   #1 (permalink)
studdly's Avatar
My Ride: Honda/Civic/2000
studdly is neutral and has a clean balanced record.
Transmission Flush
I am trying to get a good gauge on the effectiveness of a transmission Flush
How effective was it?
What brand fluid did you use?
Where did you purchase your fluid from?
studdly is offline   Reply With Quote
Old 02-05-2006, 10:27 AM   #2 (permalink)
Staff: Rank 1
Administrator
General Operations
TOTM 2004
If you need to overhaul your transmission because you've damaged something, it'd definitely be effective removing fine debris you couldn't get out. But otherwise on such a new car, it's not exactly a necessity.
Old 02-05-2006, 02:24 PM   #3 (permalink)
TOTM 2006
JeffTSX's Avatar
My Ride: 04 Pearl White TSX 6spd
JeffTSX is neutral and has a clean balanced record.
Noel is right, on new cars there is no need. On the RSX-S, there is a famous gear grinding problem and when I flushed and topped up with Motul tranny fluid, it helped. I did the same to my TSX too. I didn't use a machanie though since my work is too cheap to get one so what I did basically poured 2L of Honda MTF into the tranny with the drain plug open then filled it with Motul. MTF.
That's some good sh*t!!!
JeffTSX is offline   Reply With Quote
Old 02-05-2006, 03:44 PM   #4 (permalink)
studdly's Avatar
I find that of late, shifting from third to second can be very rough.
Not in tems of the car jerking, I mean gearring into 2nd from third is rough.
Old 02-05-2006, 08:55 PM   #5 (permalink)
Staff: Rank 1
Administrator
General Operations
TOTM 2004
That'd be attributed to the transmission fluid type use rather than the need for a flush.
Old 02-06-2006, 12:50 PM   #6 (permalink)
studdly's Avatar
So what type do you suggest to remedy?
Old 02-08-2006, 04:19 AM   #7 (permalink)
Staff: Rank 1
Administrator
General Operations
TOTM 2004
Genuine JDM Honda MTF/MTF-II works fine for me.
Old 02-08-2006, 09:35 AM   #8 (permalink)
UK Accord Type-S
alnug's Avatar
My Ride: Honda Accord Type-S
alnug is neutral and has a clean balanced record.
I had 29K miles on mine and did notice that the shifting just didn't seem as smooth as before especially 5tgh to 6th. I changed the fluid and all is fine now...but it did take the new fluid about 20 miles before i felt the difference.
UK Honda Accord Forum
APB Accord 2.4 Type-S:
Spoiler, 17" OZ, A-spec Suspension, Comptech SS and IceBox, LED lights, Mugen grill and exhaust with bonnet trim, AUX+MP3+USB input, shifter bushings, skunk2 knob, ingalls camber kit
alnug is offline   Reply With Quote
Old 04-04-2006, 12:22 PM   #9 (permalink)
Donating TSXCLUB Member
Vegito's Avatar
My Ride: Acura/TSX/2005
Vegito is neutral and has a clean balanced record.
Is there an easier way to self drain/fill.. I did mine first time over the weekend and it look forever to losen the air damper cover..
07 Z4
05 TSX
99 Accord V6
Vegito is offline   Reply With Quote
Old 04-04-2006, 04:48 PM   #10 (permalink)
My Ride: acura/tsx/04
EPGONZALEZ is neutral and has a clean balanced record.
transmission is always neglected.
it has no filter, or cooling system.
in a best motoring video, mr. spoon rec. changing more frequently than oem specs and using magnetic drain bolts to try and keep oil free of debris.
EPGONZALEZ is offline   Reply With Quote
Old 04-04-2006, 05:49 PM   #11 (permalink)
Vegito's Avatar
It was easier on my accord.. i can see the drain bolt by the driver wheel..
07 Z4
05 TSX
99 Accord V6
Old 04-05-2006, 12:20 AM   #12 (permalink)
dookie's Avatar
My Ride: several
dookie is neutral and has a clean balanced record.
simple.
http://www.tsxclub.com/forums/showthread.php?t=8988
'99 mazda miata sport pkg.
--RP-F1 (15", yo!), azenis, bilstein, 4-1 header, rollbar
'01 mitsubishi montero
--33" AT's, 2" OME HD lift
'05 acura tsx 6MT
--JDM Kikkake style
dookie is offline   Reply With Quote
Old 04-05-2006, 10:23 AM   #13 (permalink)
Vegito's Avatar
AT is in different location, not as simple
07 Z4
05 TSX
99 Accord V6
Old 04-06-2006, 08:32 PM   #14 (permalink)
dookie's Avatar
My Ride: several
previous discussion of mtf and 5th to 6th shift leads me to believe it's a 6MT, although the OP never actually says.
'05 acura tsx 6MT
--JDM Kikkake style
Old 04-27-2006, 01:12 AM   #15 (permalink)
Staff: Rank 2
Chief SuperModerator
Entertainment
pcdawg's Avatar
My Ride: TSX
pcdawg is either reputation whoring, or truly reaching the elite club.pcdawg is either reputation whoring, or truly reaching the elite club.pcdawg is either reputation whoring, or truly reaching the elite club.pcdawg is either reputation whoring, or truly reaching the elite club.pcdawg is either reputation whoring, or truly reaching the elite club.pcdawg is either reputation whoring, or truly reaching the elite club.pcdawg is either reputation whoring, or truly reaching the elite club.pcdawg is either reputation whoring, or truly reaching the elite club.
Bringing back from the dead.
If one is to track the car, or for those AT users, would getting better tranny fluid be better for the car since we will use the SS mode more??
pcdawg is offline   Reply With Quote
