Old 02-09-2006, 06:55 PM   #1 (permalink)
TOTM 2006
My Ride: euro r JDM CL9
shadowlegz is neutral and has a clean balanced record.
DC5-R head on the tsx
I'm just wondering can we put the DC5-R head with all the cams valve etc in the tsx engine. You think it will give HP
shadowlegz is offline   Reply With Quote
Old 02-10-2006, 02:56 AM   #2 (permalink)
Staff: Rank 1
Administrator
General Operations
TOTM 2004
From an NA perspective, yes it's a significant progress.
Old 02-10-2006, 10:20 PM   #3 (permalink)
TOTM 2006
Hi Noel thanks for the reply if anything is the head with all the parts a direct bolt on to the tsx block or is there needs for modification.
Old 02-12-2006, 06:24 AM   #4 (permalink)
Staff: Rank 1
Administrator
General Operations
TOTM 2004
There are components requiring modification, are you also aware of voiding your factory warranty?
And this isn't going to be an easy swap, you'd also need a tuneable aftermarket ECU to get everything working correctly as well.
Old 02-13-2006, 12:31 PM   #5 (permalink)
iVTEC no koe
HoRRo's Avatar
My Ride: Acura/TSX/2005
IIRC, won't he lose DBW and then need new gauges?
Old 02-13-2006, 03:56 PM   #6 (permalink)
Not A MOD3RATOR
chuson's Avatar
My Ride: 2005 Acura TSX 5AT
I'm wondering what OTHERs Mod can be done on a TSX once its swap to a DC5-R Intake Manifold THAT it can't be done b4??? K-Pro?
Old 02-13-2006, 07:37 PM   #7 (permalink)
Staff: Rank 1
Administrator
General Operations
TOTM 2004
Yes, there won't be the DBW function with the effective swap. And there are plenty of ECU options out there for the K20a. Hondata is not be all/end all.
Old 02-13-2006, 07:56 PM   #8 (permalink)
TOTM 2007
04_K24TSX's Avatar
My Ride: 2004 Acura TSX 6MT
04_K24TSX has a spectacular aura and a relevant respect from many.04_K24TSX has a spectacular aura and a relevant respect from many.04_K24TSX has a spectacular aura and a relevant respect from many.04_K24TSX has a spectacular aura and a relevant respect from many.
What about running the K20a head but retaining the K24's intake manifold and TB? It should work shouldn't it?
August 2007 TOTM
Comptech Supercharged 04' NBP TSX 6MT
OEM Kit, OEM Fog Lights, JDM Headlights, JDM Tail lights, JDM Euro R grille and badges,Tein Basics, Progress Rear Sway bar, M3 Lip Spoiler, Feels Twin Cam N1 Exhaust, T1R Test Pipe, Comptech Icebox and AEM SRI, Comptech Header, Cusco OS S/B, Signal Auto CF Spark Plug Cover, Rotora 2pc BBK, 19x8 Volk Racing TE37's and 18x8.5 Rays 57f, Pioneer Avic N2, JL 12w6v2, JL 500/1, JL 6X9's, Escort Passport 9500i. More coming soon!
04_K24TSX is offline   Reply With Quote
Old 02-14-2006, 01:42 AM   #9 (permalink)
My Ride: Honda/CL7/2004
superx , with enough acceptance, will soon become famous.superx , with enough acceptance, will soon become famous.
ok that is a very cool topic, I also do have the same questions, I am owning a CL7 K20A 155horse power accord in Hong Kong, I so have the same questions, can I use DC5-R engine parts for my CL7 to gain horse power like Euro-R...
superx is offline   Reply With Quote
Old 02-14-2006, 08:53 AM   #10 (permalink)
Staff: Rank 1
Administrator
General Operations
TOTM 2004
O4 K24TSX - No, that's a conflicting setup. You won't get optimal performance as one setup is bias for torque while the other for high end. You'd need to lose the DBW functionality and use the K20A intake manifold/throttle body setup.
Superx - Your K20A would be better off swapped out for an entire Euro R K20A instead of going about this route. This setup isn't applicable/ideal for you.
Old 02-16-2006, 01:50 AM   #11 (permalink)
I found this information is quite details to explain all the K20A or K24A engine, please take some times to read it, quite useful!!!
http://www.theksource.com/news/04/k-...vtec-breakdown
CL7
Old 02-19-2006, 03:17 AM   #12 (permalink)
Staff: Rank 1
Administrator
General Operations
TOTM 2004
Isn't there a sticky in the General Topics subforum which lists the differences already/as well?
Old 02-23-2006, 11:49 AM   #13 (permalink)
accord cl9
My Ride: honda/euro/2003
eurocl9 is neutral and has a clean balanced record.
how about just fit dc5-R intake manifold to euro with bigger throttle body would it make significant gain ?
eurocl9 is offline   Reply With Quote
Old 02-23-2006, 07:26 PM   #14 (permalink)
Non-Registered User
Cyde's Avatar
My Ride: TSX 2004 Duh!
Cyde is neutral and has a clean balanced record.
when you swap in the k20a R head on the k24 block, you going have to replace your gauge cluster too, cuz the stock tsx gauge cluster won't work with the ecu of the k20*
on the bright side, you can now use the hondata S300 or the AEM e-manage ultimate(pain in the ass to tune) where as you couldn't before with the TSX k24 head and ecu... I might be wrong on this but correct me please.
Cuz i got allan swaping in the tsx k24 bottom end with the R head, on toda cams and vavle springs, and we trying to decide between AEM e-manage or Hondata s300... and some other goodies.. hehehe.
..and when he's not looking i'm going to steel his engine for my car lol
The message posted is intended only for the designated recipient(s), person or entity to which it is addressed and may contain confidential, privileged, proprietary, and/or otherwise private information. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this material by persons or entities other than the intended recipient(s) is prohibited. If you received this in error, please contact the sender and delete the material from any computer.
Cyde is offline   Reply With Quote
Old 02-23-2006, 10:42 PM   #15 (permalink)
Staff: Rank 1
Administrator
General Operations
TOTM 2004
That's pointless and doing more harm that any good if/any. Disabling DBW at the same time in this backward process.
The CL7 IM is designed for mid-high end power vs CL9 IM which is designed for torque and low-mid end gains instead.
Without the proper ECU tuning for fuel/ignition, VTEC and RPMs all you're doing is destroying the balance of what the K24A is designed to do.
