Old 02-19-2006, 05:55 PM   #1 (permalink)
Snowboarding is LIFE!
amadeus303's Avatar
My Ride: Acura TSX 6Sp with Nav
amadeus303 , with enough acceptance, will soon become famous.amadeus303 , with enough acceptance, will soon become famous.
Comptech Icebox
I know this has been discussed here and in other forums, but I can't seem to find it in the search...
What makes the CT Icebox less prone to hydrolocking than the other intakes available? Is it just the mere height of the inlet/horn? Most of the other CAIs run much lower, right?
amadeus303 is offline   Reply With Quote
Old 02-19-2006, 06:14 PM   #2 (permalink)
Black Listed +/- Banned
Knox's Avatar
My Ride: Acura TSX 2006
Knox is neutral and has a clean balanced record.
Correct. When you use a CAI, the actual filter location is much lower. When using any sort of airbox (stock or aftermarket) the air is funneled into the box where it is then filtered, much less prone to suck up water or anything else. Personally, I prefer either the stock airbox with a new filter (green or K&N) or some sort of short ram with a heat shield.
Here are some helpful threads:
LINK 1
LINK 2
LINK 3
Knox is offline   Reply With Quote
Old 02-19-2006, 06:45 PM   #3 (permalink)
(9)
Ex-Moderator Emeritus
LannyMCS's Avatar
My Ride: 2006 MINI Cooper S JCW
LannyMCS has a spectacular aura and a relevant respect from many.LannyMCS has a spectacular aura and a relevant respect from many.LannyMCS has a spectacular aura and a relevant respect from many.LannyMCS has a spectacular aura and a relevant respect from many.LannyMCS has a spectacular aura and a relevant respect from many.
I agree, and that is also why you will probably see a little less gain with the Icebox. It doesn't generate as much air suction at the filter as a CAI is capable of, but it's a nice improvement over stock with none of the hydrolock risks, and also much easier to access the filter for cleaning/changing then a CAI......
LannyMCS is offline   Reply With Quote
Old 02-19-2006, 07:55 PM   #4 (permalink)
My Ride: acura/tsx/2005
kyotousa , with enough acceptance, will soon become famous.kyotousa , with enough acceptance, will soon become famous.kyotousa , with enough acceptance, will soon become famous.
how do i install icebox
i removed the wheel.......took out like 5 pop out pin (the back rear plastic)
i don't see any metal part =_=|||
kyotousa is offline   Reply With Quote
Old 02-19-2006, 09:15 PM   #5 (permalink)
Knox's Avatar
Do you not have the directions? Search for "Comptech Icebox" and you should get some help on our forums. Thanks.
Old 02-20-2006, 12:31 AM   #6 (permalink)
direction is to take off the front bumper
i am trying to use the remove the wheel method
after...i remove the wheel.....i took half of the plastic off
i don't see anything like the manual shown in Injen installation posted by memphis
i am pretty sure if i get through the plastic covering part...then i'll be able to do it
Old 02-21-2006, 12:08 AM   #7 (permalink)
vidgamer's Avatar
My Ride: TSX/2005
vidgamer is neutral and has a clean balanced record.
The airhorn for the Comptech still seems to stick down a bit. How high is the stock location (relative to the alternatives)? I'm wondering if you are increasing the risk even by going with the Comptech.
Alternatively, how about when you remove the resonator (of course, you can replace the airfilter)? On my previous car, the stock "snorkel" inlet was way up at the top of the fender, and if you removed the resonator, it actually lowered the intake point by maybe a few inches. (Of course, if/when I get around to yanking the resonator out, I will probably see for myself, but I guess I'm still trying to decide if it's worth it to go with an aftermarket intake, or if just removing the resonator is good enough.)
vidgamer is offline   Reply With Quote
