Old 08-05-2006, 07:16 PM   #1 (permalink)
venom
Guest
Posts: n/a
CAI on 06 tsx - worth it?
The 06 tsx has a different intake than the other years, doesn't it? I think it already has the intake in the wheel well. If that's the case then does the switch to an aftermarket intake make any sense at all other than looks?
Also if you shop for intakes they don't specify any model years so does the same intake fit all years even though (I think) the throttle body opening is bigger on the 06?
Anybody that has an 06 and has done reseach on this topic please respond, thanks!
Old 08-05-2006, 11:08 PM   #2 (permalink)
My Ride: acura/tsx/2006
aeon is neutral and has a clean balanced record.
uhm.. intake should be the same for all years. the intake you're talking about in the wheel well is the intake resonator.. just about all honda/acuras have them. you have to remove that when you install a cai.
yes switching to an aftermarket intake makes sense if you're looking for more power.
aeon is offline   Reply With Quote
Old 08-10-2006, 03:31 AM   #3 (permalink)
RaCeR4LiFe022's Avatar
My Ride: Acura / TSX / 2006
RaCeR4LiFe022 is either technically knowledgeable, or well loved.RaCeR4LiFe022 is either technically knowledgeable, or well loved.RaCeR4LiFe022 is either technically knowledgeable, or well loved.RaCeR4LiFe022 is either technically knowledgeable, or well loved.RaCeR4LiFe022 is either technically knowledgeable, or well loved.RaCeR4LiFe022 is either technically knowledgeable, or well loved.
CAI definetly gives you power gains... but i have realized that people advertize the CAI only for 04-05.. I also need to know if they are the same.
06' TSX!
PWP
I was fortunate... JDM saved me... JDM rules everything around me now...
RaCeR4LiFe022 is offline   Reply With Quote
