Old 08-30-2006, 06:04 PM   #1 (permalink)
Metal Head
1TSXer's Avatar
Hondata IM gasket
I just ordered my Hondata IM gasket. I know it's a little late, but is it worth it? 3-4 HP for $60 doesn't sound bad. I plan on installing this myself as I do everything else
04 CGP 6spd MT
Old 08-30-2006, 06:39 PM   #2 (permalink)
TOTM 2007
Tsx536's Avatar
My Ride: Acura TSX 2004
It's a kind of hard install too from what I've heard.
The Hondata IMG doesn't give you any power, it justs gives you back any power you would lose from the high heat. I believe it can reduce air temps by 15-40 degrees. Not sure how that translate into real world performance though.
Old 08-30-2006, 07:12 PM   #3 (permalink)
SToCK
AcidLotus's Avatar
My Ride: 2005 Acura TSX
AcidLotus has a spectacular aura and a relevant respect from many.AcidLotus has a spectacular aura and a relevant respect from many.AcidLotus has a spectacular aura and a relevant respect from many.AcidLotus has a spectacular aura and a relevant respect from many.
installation is a biatch. I was quoted $40 for the IMG, and $220 I think for the install.
AcidLotus is offline   Reply With Quote
Old 08-30-2006, 07:35 PM   #4 (permalink)
My Ride: Acura/TSX/2004
moda_way is neutral and has a clean balanced record.
Did it myself and followed someone elses instructions on another informative site like this. It is a bitch to do and per Hondata's site, significantly lowers intake temp. That's good for any mod.
CG/Ebony/Non-Navi/6MT
TSX Key Mod
Comptech:
Short-Shifter, Exhaust, Header, Springs, RSB
RT Cat
Hood & Trunk Shocks
KPTech Window Up, VSA off, 1-Touch Sunroof
Hondata Gasket, Reflash
My Cardomain
moda_way is offline   Reply With Quote
Old 08-31-2006, 02:30 AM   #5 (permalink)
TOTM 2009
IntegraGSR23's Avatar
IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.
It's not that bad, I have done a few install already. Just time consuming and a pain.
Old 08-31-2006, 03:00 PM   #6 (permalink)
Metal Head
1TSXer's Avatar
Ya, I get mixed reviews. Some say it was hard, some say it was easy yet time consuming. I got the same reviews when asking about the suspension install. I found the suspension install to be extremely easy. So how does this compare. SPRING/SUSPENSION install on a scale of 1-5, 5 being the hardest I'd give it a 1.5. For those who have done the IM gasket install what would you rate it on a scale from 1-5?
04 CGP 6spd MT
Old 08-31-2006, 03:28 PM   #7 (permalink)
Donating TSXCLUB Member
Vegito's Avatar
My Ride: Acura/TSX/2005
Vegito is neutral and has a clean balanced record.
http://www.thefesteringcyforce.com/tsx/tsx-intake.pdf
07 Z4
05 TSX
99 Accord V6
Vegito is offline   Reply With Quote
Old 08-31-2006, 06:50 PM   #8 (permalink)
Metal Head
1TSXer's Avatar
Originally Posted by Vegito
cool, that might come in handy!
04 CGP 6spd MT
Old 08-31-2006, 08:23 PM   #9 (permalink)
TOTM 2009
I would say a 3.5
Old 08-31-2006, 09:04 PM   #10 (permalink)
My Ride: acura/tsx/2006
aeon is neutral and has a clean balanced record.
not sure if it's the same, but i've done it before on a b-series motor. first time was a little hard because of the tight space. after that it was pretty easy. i would give it a 3.5 on the b-series motor and after the first install it was like 1.5 afterwards.
aeon is offline   Reply With Quote
Old 09-01-2006, 05:10 PM   #11 (permalink)
Metal Head
1TSXer's Avatar
Ya, I've install a Spoon Ventuli plate (aka "rubber chicken") on a B16 before and it was pretty tight. But on the K motors the intake manifold is right there in front of you and the only hang up I could see would be the bottom bracket.
04 CGP 6spd MT
Old 09-07-2006, 06:01 PM   #12 (permalink)
Metal Head
1TSXer's Avatar
Well, I did the install today. It was fairly easy and only took about 1.5 hours. I have not driven it yet so I will give an update soon.
04 CGP 6spd MT
Old 09-07-2006, 07:10 PM   #13 (permalink)
Vegito's Avatar
cool.. how helpful was the instructions... i bought mine last year.. busy at work.. haven't touch it.. hhahahah
07 Z4
05 TSX
99 Accord V6
Old 09-07-2006, 07:18 PM   #14 (permalink)
hitting 200,000km
shitbox's Avatar
My Ride: 04PWPCL9
shitbox , with enough acceptance, will soon become famous.shitbox , with enough acceptance, will soon become famous.
which instruction did you follow through out the installation?
now my butt is itchy i might install it myself instead of selling it.
what kind of tools did you use?
shitbox is offline   Reply With Quote
Old 09-07-2006, 08:21 PM   #15 (permalink)
I dont' think there will be a big enough gain where you would feel anything.
