09-15-2006, 02:00 PM
#1 (permalink)
Time for battery change?
Hi, sorry if this is in the wrong forum, but i was thinking battery is part of the engine so i posted here. I just want to know when should i replace my battery. TSX stock battery is not the best out there when comes to capacity wise. And lately when i turn on too much electronic gadgets the Nav will malfunction and not able to acquire gps signal. Also battery dies if i listen to music for like 30mins or so.
I also have harder timme starting, unlike when it is new, it will start just 1 crank, now i have to crank it longer.
btw, my car is at 65k miles and it is 2004/nav
09-15-2006, 03:49 PM
#2 (permalink)
why not just change the battery now since you are running into those problems
5AT '05 Premium White Pearl TSX
09-15-2006, 04:13 PM
#3 (permalink)
change it now, get like an optima.
09-15-2006, 05:45 PM
#4 (permalink)
It could also be RF interference affecting your GPS receiver if you have a lot of extra gadgets that use RF...
09-17-2006, 09:20 PM
#5 (permalink)
Yes, get a dry cell type battery if you want an upgrade. Optima is a good selection basis.
09-18-2006, 12:24 AM
#6 (permalink)
 Chief SuperModerator Performance
I agree, the Stock battery is one of the TSX's weak points...
09-18-2006, 12:47 AM
#7 (permalink)
 Ex-Moderator Emerita
My Ride: 2005 Acura TSX w/ navi
haha...Sorry, I was laughing at your first statement about wondering if this was the right forum to post your inquiry...hehe I hope my previous "forum police" posts didn't scare you! hahahahahaa
So, is 65k around the time we should start thinking about changing our battery or does it depend?
"Only those who value their heart will recognize the people who don't deserve it"--Unknown Author
"They don't care what you drive or how much money you have,the only thing independent women want you to do for them, is make them LAUGH!"--Roslynn
"Not one drop of my self worth depends on your acceptance of me"--Quincy Jones
My standards aren’t high. Some men are just used to low class bitches.
"What's done in the dark will come into the light"--Tupac
IN ORDER TO EVOLVE ONE MUST ENDURE MANY ENDINGS...NOT ALWAYS A BAD THING WHEN EVOLUTION IS LONG OVER DUE...IN OTHER WORDS KEEP IT MOVIN' AND TRY NOT TO LOOK BACK
09-19-2006, 05:47 AM
#8 (permalink)
My Ride: Euro CL9 K24A3 6MT
Your battery is dying because you have run your battery flat previously. Change it and get a deep discharge battery like an Optima Yellowtop or an odyssey.
09-19-2006, 10:11 AM
#9 (permalink)
 Ex-Moderator Emeritus
Just a note on the optima...there is no battery out for the TSX from optima. Closest you'll come is a red top 51R (i believe) but you'll have to modifiy the battery tray for it to fit. They stopped selling the yellow top because of defects causing it to lose power (i thinkt hat was the reason).
Originally Posted by VorteC
09-19-2006, 11:58 AM
#10 (permalink)
Make sure you have the codes for your Navi and Radio before disconnecting the old battery. I think you need to change you battery ASAP. The old battery has given you plenty of warning signs to replace. If you wait, make sure you have a cell phone to car for road side assistance.
06 5AT CGP Qtz w/ Navi
ASA AR1 Chrome 17X7
A-Spec suspension w/ Progress RSB
35% 3M tint & clear bra + head/fog lights
Spoiler kit/wing, air deflector, metal trim kit, cargo net, trunk tray, Nav screen film & All season mats
350Z cargo net, dr edge guard & Acura racing pedals.
09-19-2006, 03:16 PM
#11 (permalink)
Not really. Some will last wayyy more than that. If you want to change your battery really, its not that expensive, you can do it at any time. Some wont need to do it the whole life of the car, some may need to do it at 50k miles, just depends on usage. If you leave the radio on a lot while parked, or have an aftermarket stereo installed (amp/sub) your battery life will be considerably lower than someone that just has a regular usage.
09-19-2006, 04:21 PM
#12 (permalink)
You usually get 3-5 years from a regular size battery (+5 years was always my avg with my other Hondas). The TSX has a smallish battery for a car this size. It would seem this type of battery would fall more into the 3-4 year range. If you have any doubts about your battery, change it out before the freezing temps of winter set in. That is when you find out how much power your battery has because a vehicle is a lot harder to start and needs more power below freezing.
Also batteries hate being dirty (moisture/oil/corrosion around terminals), loose connections, extreme temps (below freezing and +100 degrees) and being 100% drained of power. If you ever drain your battery, just replace it because it will never recharge back to the same level again.
ASA AR1 Chrome 17X7
09-19-2006, 04:37 PM
#13 (permalink)
I am having problem with my battery
went dead twice already...had to jumpstart
my car is only 1 yr old...but Acura won't replace it.......
anyway.......are there any upside to change to redtop or yellow top? for regular user...
since I am not running anything extra....I am thinking if it dies again i'll just go to walmart to buy that 50dollars battery.....
09-19-2006, 05:00 PM
#14 (permalink)
odd, Acura replaced my battery for me once...
Well anyway Id say the factory battery sucks as it is, so its really not a bad idea even if your not running any toys to switch to a better one
09-19-2006, 07:14 PM
#15 (permalink)
well i don't see the reason to spend extra 70 dollars if i see no improvement
yah Sterling Acura in Austin is a dick place to go....
| Thread Tools |
| Display Modes |
Linear Mode
