"any more info"
sure
Hydra- The hydra is a full stand alone form of EM. This means that it does not use or require the stock ECU. It controls all systems required to make the engine operate. This is both a blessing and a fault. It means that you have absolute control at all times. However if you do need to pass an OBD-II scan for your annual inspection you will not be able to do so with the Hydra in place.
In order to make a car run well with a full stand alone like this you need to map out how the ECU acts in all situations. This means that you must design the compensations for all temperature ranges, altitudes, cold start, bad gas, extra load, and anything else that may change the way the car runs.
The hydra is MAP based instead of MAF based. This means all the internal tables are setup based on the boost pressure and temperature currently flowing through the intake manifold, and not by the mass of the air flow. This eliminates the need to have MAF sensors that read larger flow rates, or to trick the MAF sensor into reading less air mass than there really is. This is a good feature for high HP cars, but requires retuning any time the efficiency of the system is changes. That means anytime you change any component on the car you run the risk of requiring a retune.
Additionally right now the Hydra is hindered by a cumbersome interface. Although it is a pretty interface, the ability to make global changes to a map currently does not exist. Currently you are required to make changes to each load site one at a time. New firmware is all that is required to improve this issue.
