12-06-2006, 06:46 PM
#1 (permalink)
DBW sucks
TSX has a timing-chain, not a timing-belt
There seems to be a lot of people who think TSX has a timing-belt. It's not their fault. Almost all of us assume this when we think of Japanese cars.
For the longest time, Japanese cars have been known for their quietly beating engines with a soft-feeling transmitted to the steering wheel and the gear shifter. This was mainly due to their well designed rubber-belted pollies. American car manufacturers never managed to achieve the same results and in fact they stuck to metal chains for a long time.
Just as American car makers started to finally find the right combination of pollies and rubber-belts for their engines, the Japanese giants(Honda, Toyota and Nissan) are moving away from rubber belts to metal chains!
Traditionally, chained engines run a bit louder and are less effecient. Not anymore. The Acura TSX is a perfect example.
The K24, 4 cylinder engine(naturally not as smooth as a V6 or V8) with a very high compression ratio(10+) and a timing chain(traditionally rough and noisy) runs much smoother than most V6 engines using timing-belts!
Advantages of chain over belt:
1. Usually outlasts the car itself
2. Doesn't need replacement until truely worn out with constant warnings(you'll know when it needs replacement unlike a timing belt which could tear into pieces while you're driving at 80mph on the highway and suddenly your engine starts producing smoke and BAM... You're out at least $2000)
Just thought I'd give us all another reason to love our babies!
12-07-2006, 07:13 AM
#3 (permalink)
 Ex-Moderator Emeritus
My Ride: 2006 MINI Cooper S JCW
Originally Posted by IranBT
....For the longest time, Japanese cars have been known for their quietly beating engines with a soft-feeling transmitted to the steering wheel and the gear shifter. This was mainly due to their well designed rubber-belted pollies.....
What are "rubber-belted pollies"?
12-07-2006, 11:52 AM
#4 (permalink)
Originally Posted by Peregrine
I think most of us know about this little goodie, nevertheless, very well written and explained
(moved to a proper forum section)
I didn't. Thanks for info.
12-07-2006, 12:04 PM
#5 (permalink)
i must say it is good to have this here. i'm pretty sure there are ppl who wouldn't have known this. good post Iran
December 2006 TSX of The Month -
97 Integra 4DR - JDM H22 Modified and Tuned, 355whp - 322tq - On Spray
05 TSX MR/Ebony 6-Speed - Back to Basics and a new Project coming soon....
12-07-2006, 12:52 PM
#6 (permalink)
 Administrator Technical & Staff Operations
I'm pretty sure he means pulleys that were well designed for belts in that context
12-07-2006, 02:56 PM
#7 (permalink)
My Ride: 06 CG TSX 6sp w/NAVI
It was a nice read. Killed a couple minutes of work time. hahaha!!!
12-07-2006, 03:30 PM
#8 (permalink)
helped get you through your "Busy" work day too i see lmao
12-10-2006, 12:22 PM
#10 (permalink)
Full power user
My Ride: EDM TSX Honda accord 2.4 Type-S
did not know that... just assumed it was a rubber belt as always with honda... happy with this chain, saves me some money at 100k km's  !
TSX AT in Holland 39000€ = 49690$ ... you are soooo lucky
petrol in Holland 1.39€ / liter = 1.77$ / liter = 6.70$ / gallon... you are soooo lucky
01-24-2008, 04:39 PM
#11 (permalink)
Cool! I was starting to worry about the timing "belt" snapping on my 2004. It has 115,000Km on it. And I sometimes get the sudden urge to redline it, so... I'm very glad to know that I don't have to worry about it anymore. Thanks!
02-02-2008, 06:55 PM
#12 (permalink)
so on chains no need to replace as often ? or i though you said it will out last the car it self if i read it right.. what are the warning of a chain breaking ?
 TSX4US
02-04-2008, 01:39 PM
#13 (permalink)
Premium Club Member
Some guy posted that he didnt take care of his tsx and let the oil run almost dead. I think he spent 5000-8000 roughly on fixing like cams timing chain and some other big labor.
So thats how much you can estimate to know you hurt you car badly.
| Thread Tools |
| Display Modes |
Linear Mode
