Old 12-17-2006, 01:46 PM   #1 (permalink)
raheel616's Avatar
My Ride: TSX/acura/2006
raheel616 is either technically knowledgeable, or well loved.raheel616 is either technically knowledgeable, or well loved.raheel616 is either technically knowledgeable, or well loved.raheel616 is either technically knowledgeable, or well loved.raheel616 is either technically knowledgeable, or well loved.raheel616 is either technically knowledgeable, or well loved.
DIY Thread NST pulley kit installation, pics, dyno...
Long story short, I found out my old buddy Mike from www.NonStopTuning.com was in the process of building some new pulleys for the TSX and offered my car for testing. From the NST website...
The NST Acura TSX pulley kit increases horsepower via great weight reduction and the underdriving of accessories. Superior to other available kits, NST kits also offer an Overdrive Alternator Pulley to optimize output for stereo system lovers!
^^ This is really a plus for people like me who want to add a nice audio/video system in the future, because the NST alternator pulley will charge the battery and run the electrical system just like the stock setup!!!
Each kit is carefully crafted from 6061-T6 aircraft aluminum, tested and balanced to high tolerances. Every NST pulley is hard anodized for exceptional durability and is available in a choice of colors: Blue or Graphite Gray.
Here are a couple pics...
http://www.nonstoptuning.com/pKitHonTSX.htm
06' CGP TSX w/ NAVI
-35% tint all around
-NST Overdrive Alternator Pulley
-NST Underdrive Crank Pulley
-Injen Cold Air Intake w/MR Technology
-T1R Earthing kit
-Topspeed header
-StrutKing Racing Stainless Steel Pedals
raheel616 is offline   Reply With Quote
Old 12-17-2006, 01:48 PM   #2 (permalink)
raheel616's Avatar
And a quick pictorial of my installation...
06' CGP TSX w/ NAVI
-T1R Earthing kit
-Topspeed header
Old 12-17-2006, 01:50 PM   #3 (permalink)
raheel616's Avatar
06' CGP TSX w/ NAVI
-T1R Earthing kit
-Topspeed header
Old 12-17-2006, 01:51 PM   #4 (permalink)
raheel616's Avatar
hp curves
torque curve
i have the dyno files monday so i will post those then.
06' CGP TSX w/ NAVI
-T1R Earthing kit
-Topspeed header
Old 12-17-2006, 03:37 PM   #5 (permalink)
Not A MOD3RATOR
chuson's Avatar
My Ride: 2005 Acura TSX 5AT
Nice mod~! Nice to see more products avaliable for TSXers...
Old 12-17-2006, 03:44 PM   #6 (permalink)
Staff: Rank 1
Administrator
Technical & Staff Operations
Peregrine's Avatar
My Ride: '04 TSX - SSM
Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.
Excellent !!
Thank You!
(Added to our DIY Menu)
Peregrine is offline   Reply With Quote
Old 12-18-2006, 12:10 AM   #7 (permalink)
raheel616's Avatar
this is a great mod before i even put my intake on the pulleys could be felt
06' CGP TSX w/ NAVI
-T1R Earthing kit
-Topspeed header
Old 12-18-2006, 01:16 AM   #8 (permalink)
SToCK
AcidLotus's Avatar
AcidLotus has a spectacular aura and a relevant respect from many.AcidLotus has a spectacular aura and a relevant respect from many.AcidLotus has a spectacular aura and a relevant respect from many.AcidLotus has a spectacular aura and a relevant respect from many.
You know a lot of the D and B series crank pulleys had harmonic dampeners. I would assume that our K24s also have harmonic dampeners looking at your pics. That said, replacing it with a piece of aluminum that does not have a harmonic dampener can be damaging to your engine, like tearing your bearings apart and eventually throwing a rod.
AcidLotus is offline   Reply With Quote
Old 12-18-2006, 02:11 AM   #9 (permalink)
Not A MOD3RATOR
chuson's Avatar
There's an extended discussion on harmonic dampeners on this or "other" forum, search. Anyways, our car does not require the harmonic dampeners.
Old 12-18-2006, 05:49 PM   #10 (permalink)
iVTEC no koe
HoRRo's Avatar
My Ride: Acura/TSX/2005
K series don't have harmonic dampeners.
Old 12-18-2006, 09:21 PM   #11 (permalink)
TOTM 2005
SAZABI's Avatar
My Ride: TSX
SAZABI , with enough acceptance, will soon become famous.SAZABI , with enough acceptance, will soon become famous.SAZABI , with enough acceptance, will soon become famous.
nice~
but... what is the effect of having a smaller pulley? I mean how it is gonna change the factory design? (any negative impact?)
June 2005 TSX of the Month
SAZABI is offline   Reply With Quote
Old 12-18-2006, 10:50 PM   #12 (permalink)
SToCK
AcidLotus's Avatar
May not "require" them? They are built in from the factory... I wouldn't start tearing off factory items for like 3 horsepower.
Old 12-18-2006, 10:51 PM   #13 (permalink)
SToCK
AcidLotus's Avatar
What's your source? Both my mechanic who has worked on Honda/Acuras for 20+ years and some on K20A.org beg to differ.
Old 12-19-2006, 12:00 AM   #14 (permalink)
raheel616's Avatar
Chat with Mike from NST on AIM, screen name NSTonAIM, and ask him. He has been using these pulleys on all his cars and his customer cars over the past few years with no problems. None of his pulleys have the thin rubber damper.
Civics, Preludes, and tons of Hondas have been running these pulleys with no problems. Also look up their name on www.ScionLife.com or www.MR2OC.com and look at all the people that use their products. You won't find anyone with a blown motor.
Look at this thread, it is very interesting...
http://www.scionlife.com/forums/viewtopic.php?t=122725
Mike is a bit older than me and Ive been friends with him since I was a kid. I seriously doubt that he would put some garbage product on my car if he knew it would cause serious harm to my car.
06' CGP TSX w/ NAVI
-T1R Earthing kit
-Topspeed header
Old 12-19-2006, 12:18 AM   #15 (permalink)
SToCK
AcidLotus's Avatar
Regardless of whether or not you or anyone else thinks that they are junk are not is not quite the point. The point is that you are running a risk. It could take days or years, who knows. Also, just because they don't yet have a blown motor, doesn't mean that they may not be wearing their bearings down prematurely - The only way to tell is a block tear-down and measurements taken and compared to the median failure rate. Not a risk I would personally take for ~3 HP.
