Originally Posted by crix868
yea well i'm def not planning to do it now i'll def do it once i get K-Pro and Turbo my motor. jus wanted to know if anyone knows of it. i had the MSD on my Teg i it gave a big difference in spark and i know u got to be running more fuel/forced induction for this item.
stock coil packs will handle more than enough even with a turbo setup...you guys gotta realize that even when K pro is available, it doesnt help that the C/R of these motors is still so high...most will not build the block and will run about 8-10psi on something like a fast spooling turbo like a 16g or 18g...maybe a t3/t4 50 trim. With that said, there is no need to spend the 750 on something that your factory system is more than well equipped to handle the job.
