you didnt bolt it up right, i had the same problem. take apart the muffler and rebolt it properly (with a more upside angle) thatll fix it. i thought it was a problem at first by greddy, but i took it to them and thats all they did and its fine now.
just the mufflers. if you look at it from the bottom youll probably notice the muffler can be slighly aligned. take off the bolts between the muffler and the piping and rebolt it but make sure you put more upward pressure and angle when your bolting it back. it should correct the problem.
