Old 02-10-2008, 05:42 PM   #1 (permalink)
ckelleyfla's Avatar
My Ride: 04 TSX
ckelleyfla , with enough acceptance, will soon become famous.ckelleyfla , with enough acceptance, will soon become famous.
Throttle Body Spacer
Is this a good mod to do its inexpensive just wondering if anyone has done it and if is reccomended
04 TSX PWP AT
Fujita CAI, TB Coolant Bypass, Hondata IMG, P2R TB Spacer & Gaskets
98 Camaro Z28 M6
Intake, Headers, 4.10 Gears, Ram Air, Intake Manifold
ckelleyfla is offline   Reply With Quote
Old 02-10-2008, 05:49 PM   #2 (permalink)
reflash before i die plz
xjohnkdoex's Avatar
My Ride: Acura/TSX/2007
i ordered the spacer and gaskets, but haven't gotten them yet (gaskets still being worked on).
from what i've read, this mod is inexpensive and helps in adding some low-end torque, and even some hp. there is one for the TL, and a lot of TL owners have mentioned that they can feel a difference.
Old 02-10-2008, 05:50 PM   #3 (permalink)
ckelleyfla's Avatar
My Ride: 04 TSX
It will work with a cai right
04 TSX PWP AT
98 Camaro Z28 M6
Old 02-10-2008, 06:49 PM   #4 (permalink)
Staff: Rank 5
Moderator
Marketplace
Pacemaker_Guy's Avatar
My Ride: 05 Auto ABP
Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.
You sig says 04 TSX. they make them for 2006+ However there is a way for you to do it.
Palm Beach Hot Rods
Speed-Theory 973-227-2119
^Honda shop in Fairfield NJ
Pacemaker_Guy is offline   Reply With Quote
Old 02-10-2008, 07:43 PM   #5 (permalink)
Not A MOD3RATOR
chuson's Avatar
My Ride: 2005 Acura TSX 5AT
The spacer will be a little bigger than your TB, cause you have a 04/05 TSX.
The spacer/gasket itself is NOT expensive, however, the gain will be very minimal. The TL guys get great gains thru Intake Plenum; not TB Spacer/gasket, gains of 3-4hp is really nothing. Without replacing the most restrictive parts I/H/E, I will say the gain will be minimal, to non-noticable.
Old 02-10-2008, 08:45 PM   #6 (permalink)
Staff: Rank 5
Moderator
Marketplace
I think you need a 04 Civic TB spacer
Palm Beach Hot Rods
Old 02-11-2008, 12:00 AM   #7 (permalink)
Not A MOD3RATOR
chuson's Avatar
The 04 Civic TB Spacer MIGHT NOT fit simply due to their design, you will need to verify on it. However, the 06 Civic TB spacer WILL FIT, due to their same bolt pattern. The 06 Civic TB Spacer is only 4mm larger than the stock 04 TSX TB; a simply fix is to maxbore your 04 TB, which increase the airflow as well.
Old 02-14-2008, 12:45 AM   #8 (permalink)
ckelleyfla's Avatar
My Ride: 04 TSX
Thanks man
04 TSX PWP AT
98 Camaro Z28 M6
