02-11-2008, 10:24 PM
#1 (permalink)
I vtec
Hi everyone,
I want to know how do i know the Vtec is turned on? i heard ppl saying it usually turned on when it is 6000rpm, but how do i know whether it is on or not?
Thz
02-11-2008, 10:27 PM
#2 (permalink)
Hayai
Listen for the changeover.
02-11-2008, 10:39 PM
#3 (permalink)
Platinum Club Member
Like he said listen closely for the change over.
02-12-2008, 12:53 AM
#4 (permalink)
i mean, is the sound change significantly?? since i tried for several times running between 5000-7000 rpm. but i just didn't listen that sound!!! Did you really feel that actually?
Thanks
02-12-2008, 01:18 AM
#5 (permalink)
trancE-head
I don't think I have ever hit vtec yet. Just not enough space. >=/
Domo-kun co-pilot l tint l debadged l cool white (coming soon)/interior blue leds l license plate leds l Greddy evo2 exhaust l vinyl black out trim l mugen visors l mugen grille l k&n typhoon cai (installing soon)
02-12-2008, 01:22 AM
#6 (permalink)
Premium Club Member
Kei169 is your car used?
theres a good chance you might have the car reflashed if so someone found their car was reflashed from the previous owner.
thats a thought.
What car is yours
04-05 typically vtecs at 6000-7200 rpms to be exact and you feel a slight kickback.
02-12-2008, 02:15 AM
#7 (permalink)
trancE-head
how about for the 06+ models?
02-12-2008, 02:20 AM
#8 (permalink)
Icrazyaznl,
yes!! I bought the used one 04 a year ago. what do you mean?? so mine doesn't have Vtec u mean???
Thz
02-12-2008, 02:29 AM
#9 (permalink)
Premium Club Member
Hrmms you might not feel the kickback since hondata makes it feel less.
If your car gets more agressive around 5000 rpms that means you have hondata ecu reflashed.
You can redline the car up 7600 as well
04
* 5000 rpm VTEC point decreased from 6000 rpm
* 7600 rpm Rev limit, increased from 7300 rpm (for auto trans must be in sportshift mode)
* Maximum torque gain 26 ft/lbs torque at 6000 rpm
* Maximum power gain 29 hp at 6000 rpm
* Peak torque increases from 169ft/lbs at 4500 rpm to 175 ft pounds at 7500 rpm
* Peak power increases from 206 hp at 7100 rpm to 210 at 6800 rpm
* Very wide flat smooth torque curve. 90% of peak torque available from 2000-7000 rpm.
* Passes Californian smog testing (no measurable difference from stock)
* Fully dealer compatible - works with all Honda scan tools and equipment
The Hondata TSX reflash is designed for use with an intake and headers. It will work very well with a stock airbox and stock headers. Testing was done with a stock cat back system.
06
* 4850 rpm VTEC point decreased from 6000 rpm
* 7600 rpm rev limit (sportshift mode only in the auto)
* Maximum torque gain 28 ft/lbs torque at 6000 rpm (24 ft/lbs auto)
* Maximum power gain 32 hp at 6000 rpm (28 hp auto)
* Peak torque increases from 165ft/lbs at 4700 rpm to 168 ft pounds at 4700 rpm
* Peak power increases from 201 hp at 7100 rpm to 204 at 6800 rpm (up to 8hp - auto)
This reflash will work very well with an 06 TSX in stock form, or with headers and intake.
#10 (permalink)
what crazyazn is saying is hondata is a aftermarket ECU that lowers your vtec to about 4000k.
And all honda's and acura's have vtec.
5AT '05 Premium White Pearl TSX
02-12-2008, 02:32 AM
#11 (permalink)
Not A MOD3RATOR
My Ride: 2005 Acura TSX 5AT
Missed by 3999K... lol
5000rpm (or 5K rpm) for 04/05; and 4850 (or 4.85K rpm) to be exact.
02-12-2008, 02:54 AM
#12 (permalink)
^ oops thanks for the correction chuson =)
02-12-2008, 02:59 AM
#13 (permalink)
 Ex-Moderator Emeritus
Got Vtech?
Originally Posted by VorteC
02-12-2008, 03:45 AM
#14 (permalink)
sorry, one more sounds like a stupid question,
how can i know whether it is reflashed??
Thz
02-12-2008, 04:09 AM
#15 (permalink)
Not A MOD3RATOR
1. Look for Hondata Sticker.
2. Find the ECU #, and call Hondata to verify.
3. Redline your car, listen to the change over sound. If your car can take the redline up to 7600rpm; then it's reflashed. If not, then you will hit the fuel limitor @ 7300rpm.
| Thread Tools |
| Display Modes |
Linear Mode
