Old 02-23-2008, 02:19 AM   #1 (permalink)
My Ride: Acura TSX 2004
TurbanRacer is an unknown soldier, or on the road to either parallels.
RBC intake manifold upgrade? and 06/07 Si throttle body
Has the 06/07 Honda Civic Si RBC intake manifold crossed any of your minds? along with the drive by wire 06-07 Civic Si throttle body?
What about maybe swapping over a 06/07 Civic Si internal transmission gear set with OEM LSD into yur 6spd TSX tranny..
All these above with a CAI, headers and catback with a Hondata reflash.. now we talkin
Contact Info.. 516.945.4010 Or Wheredidwedoit@aol.com
TurbanRacer is offline   Reply With Quote
Old 02-23-2008, 03:09 AM   #2 (permalink)
RaCeR4LiFe022's Avatar
My Ride: Acura / TSX / 2006
RaCeR4LiFe022 is either technically knowledgeable, or well loved.RaCeR4LiFe022 is either technically knowledgeable, or well loved.RaCeR4LiFe022 is either technically knowledgeable, or well loved.RaCeR4LiFe022 is either technically knowledgeable, or well loved.RaCeR4LiFe022 is either technically knowledgeable, or well loved.RaCeR4LiFe022 is either technically knowledgeable, or well loved.
They say the RBC intake manifold does not yield any gains. They say that the RBC helps in the higher RPMS slightly but our intake manifold is where we get out torque
06' TSX!
PWP
I was fortunate... JDM saved me... JDM rules everything around me now...
RaCeR4LiFe022 is offline   Reply With Quote
Old 02-23-2008, 03:23 AM   #3 (permalink)
well i guess i'll be the first to install 06 Si gears and LSD in my tranny and a 06 Si RBC manifold... wish me luck..
Old 02-23-2008, 03:31 AM   #4 (permalink)
Hayai
kuma912's Avatar
My Ride: EP3-RR8-CL9
Best of luck to you. I'm gonna be working on an engine with those things too.
Old 02-24-2008, 01:42 PM   #5 (permalink)
My Ride: acura tsx 2004
RBC_K24 is neutral and has a clean balanced record.
Here is mine K24 with RBC/SI TB
RBC_K24 is offline   Reply With Quote
Old 02-24-2008, 03:19 PM   #6 (permalink)
Originally Posted by RBC_K24
niceeeeeeeeeeee... dude did you feel a difference.. is it worth it? so the 06 Si throttle body is plug and play? how about the newer S2000;s i was told der drive by wire..
Old 02-25-2008, 01:32 AM   #7 (permalink)
Not A MOD3RATOR
chuson's Avatar
My Ride: 2005 Acura TSX 5AT
Who told you that and what does it has to do with you?
If you are not sure, search.
The 06 Si TB is extremely similar to the TSX 06 TB, this is due to both running off the K-Series engine; and the 06 Si IM is similar to RBC.
The S2000 TB, size is 62.5mm. Depends on which year of TSX you had, the 06+ comes w/ a 64mm TB, any reason you would like to switch for S2000 TB?
BTW: S2000TB only fits F-series engine.
Old 02-25-2008, 09:03 PM   #8 (permalink)
first off i can't remember where i saw that information, maybe it was honda-tech. and as for what it has to do with me!! well ALOT.. i plan on droppin the06/07 SI 6spd gearset along with the LSD.. I just picked up the 06/07 Si RBC intake manifold and next i guess i'll try to find a 06+ TSX TB..
Oh BTW.. this is FACT.. AP1 S2000 tb's fit B.series ALSO, not just F.series
Old 02-26-2008, 04:34 PM   #9 (permalink)
Not A MOD3RATOR
chuson's Avatar
I don't know if the S2000 TB fits on B-series, maybe, I'm not sure. But none of the picture below shown me it's a direct fit?
What I'm saying is, if you have a 06+ TSX, then your TB will probably the same as the 06+ Si in term of volume/size (64mm). If you would like to bolt it on to the RBC, you do NOT need the 06 Si+ TB; all you need is an Kcarpet adapter, or simply a TB Spacer (a specific one) will do the work. Unless you want it to be bigger, your only choice will be max bore it.
I'm just saying I don't see how's the S2000 TB doing anything for the K-series...
S2000's Throttle Body.
J's Racing AP1/AP2 Throttle Body
B18C Throttle Body.
Old 02-29-2008, 10:57 PM   #10 (permalink)
thanx for yur insite.. unfortunetely i have a 04 TSX which means its 62mm.. i guess i'll hit up max-bore..
Old 03-01-2008, 05:10 PM   #11 (permalink)
Not A MOD3RATOR
chuson's Avatar
If I'm not mistaken, my 04 TSX TB is 60mm only, which is 4mm less than the 06 TSX TB (64mm).
I've got the 06TB to replace my 04 TB, but before putting it in I will send it along w/ my TB spacer, IM to maxbore for some work done, hopefully 68mm+.
Old 03-11-2008, 03:28 AM   #12 (permalink)
My Ride: Acura/TSX/06
daicacharco has a spectacular aura and a relevant respect from many.daicacharco has a spectacular aura and a relevant respect from many.daicacharco has a spectacular aura and a relevant respect from many.daicacharco has a spectacular aura and a relevant respect from many.
Sorry to burst your bubbles. I've already done the tranny gearing swap ;]
daicacharco is offline   Reply With Quote
