03-04-2008, 08:39 PM
#1 (permalink)
Tsx Iddle
just wanted to know what is the normal iddle speed for a 2004 tsx automatic transmission, mine has been inconsistant lately, just under normal iddle it is at 800rpm and then other times between 600 and 700 rpm, any info on this.
Thanks.
03-04-2008, 08:44 PM
#2 (permalink)
Un-Civil Engineer
Usually 800 rpm. On cold mornings it will idle higher until reaching a certain temperature.
Yours seems to be idling fine the way it is so no worries.
03-04-2008, 08:50 PM
#3 (permalink)
Hey Griffojm, thanks for the response, what about when the car is all warmed up and I have been driving it,and let say I come to a stop light, that when it is usually inconsistant.
03-05-2008, 11:41 AM
#4 (permalink)
cold start around 1500 normal aorund 800
06' CGP TSX w/ NAVI
-35% tint all around
-NST Overdrive Alternator Pulley
-NST Underdrive Crank Pulley
-Injen Cold Air Intake w/MR Technology
-T1R Earthing kit
-Topspeed header
-StrutKing Racing Stainless Steel Pedals
03-05-2008, 05:16 PM
#5 (permalink)
Un-Civil Engineer
I think it can vary if you do something, such as turn the steering wheel a little at a stop. The rpms might change a little then. I can't think of anything else that would change the engine speed at operating temps
03-05-2008, 07:40 PM
#6 (permalink)
Platinum Club Member
Thanks.
Thats about right.
#7 (permalink)
Thanks.
Thats about right.
03-05-2008, 08:06 PM
#8 (permalink)
Thanks guys will keep a eye on it.
03-06-2008, 11:38 AM
#9 (permalink)
My Ride: 2008 Acura TSX AT Navi
Most of the time I see mine where I think is around 650 - 700 rpm when idle - and with engine warmed up.
03-07-2008, 01:04 AM
#10 (permalink)
I'm not sure what kinda of idle air system this engine uses, but on older hondas if the idle air valve got dirty or sticky it could cause idle probelms as the engine isnt getting enough air sometimes..
03-07-2008, 10:17 AM
#11 (permalink)
Un-Civil Engineer
That is also something I have seen in other cars. You could also clean the intake butterfly valve to help the situation.
03-07-2008, 01:52 PM
#12 (permalink)
The k20a2 is set 750+ or - 50 from factory,the higher the rpm the higher the base line.(i.e. cut off 7100 idle 700+or -50 )
Its hard to know your exact rpm unless your hooked to apexi or some other rpm device.
03-10-2008, 12:40 AM
#13 (permalink)
Let me...help you!
it could be your a/c compressor turning on and off, causing a slight drain from the engine. The car will turn it on and off as needed to maintain your specified temperature.
2006 CGP TSX w/ Navigation (6-MT)
Hondatafied//15% Formula One Pinnacle tint//Tein SS coilovers//Neuspeed front strut bar
Comptech rear-sway bar//Rear Ingall camber kit//Euro-R pedals//rear view camera
My first compliment of the decade:
Originally Posted by shay654
And you're my "novel twin"
| Thread Tools |
| Display Modes |
Linear Mode
