03-16-2008, 04:46 AM
#1 (permalink)
Shaka!
Motul + MT105 + Mugen Oil Filter = >Power
So I did another oil change but decided to Mugen it out except for the oil. I used Motul 300v 5w-30 and added 190 ml of MT-105 Mugen Engine Oil Treatment plus a High Performance Mugen Oil Filter. Seriously, this has been a great notice in power and change of ride. Everything is more responsive, smoother and powerful. My engine is quieter. I am still going to wait a little longer to see if it made a drastic improvement on gas mileage. I'm pretty sure if you use a decent oil like Mobil 1 or Royal Purple, similar results would occur. I think a lot of it has to do with the MT-105 and possibly the mugen oil filter. I'm sure tho' that the Motul racing oil I put in increased performance. I recommend purchasing the MT-105 and a Mugen High performance oil filter. I also added a skunk2 magnetic oil drain plug and mugen oil cap.
i got mine at www.kingmotorsports.com
Oil filter $29
MT105 $50
www.inlinefour.com
Motul 300v 5w-30
seriously think about trying it. I know its expensive but this is for our engines!!
2006 Evo IV MR "Stock"
03-16-2008, 01:28 PM
#2 (permalink)
Bork Bork Bork
Hmm, maybe I should try this Engine oil treatment as well. I don't see an oil filter creating that much performance.
03-16-2008, 02:10 PM
#3 (permalink)
SToCK
Sounds like a placebo effect, perhaps partially to rationalize the cost.
03-16-2008, 03:02 PM
#4 (permalink)
Never never perform engine oil flush. Worsting to do is that. Motul is the best motor oil you can. as for transmission oil I don't know I drive a AT but just to be on the safe side just stick with Motul Transmission oil.
03-16-2008, 03:07 PM
#5 (permalink)
My Ride: Acura/TSX/2007/6spd non-navi
Oil filter $29
MT105 $50
www.inlinefour.com
Motul 300v 5w-30
using race oil for a street car is NOT recommended. Race oil lacks the detergents and additives that oil made for street cars has. Race cars rarely sees the miles on a single oil change that street cars see. Race oil break down much quicker because of the lack of additives and do not have any cleaning agents. Because of this, blow-by particles, particluates, or water vapor aren't suspended in oil causing the oil to break down. Its because race engines are torn down and rebuilt after every race, they run race oil. In the long run you risk engine damage and cost over runs. No offense but you wasted your money. Besides changing oil will not increase performance significantly unless you run like 0W weight oils. Even then our engines only produce 205hp, and decrease in viscosity is only gonna net you like 1-2hp at the most. And you are not gonna feel that. Using race oil, you'll need to change the oil like every 500-1000miles. You definitely can't go extended range on race oils. Ask me how I know? I spoke with Quaker State's race division engineer at NOPI two years ago and he warned of using race oil in street cars. And he stated if you use race oil, you need to change the oil more frequently. He told me that they reformulated Ken Tran's drag car and drop the viscosity down from like 20-50 to 15-30 and were able to pick up an extra 100-150hp but his engine already produced in excess of 1000hp. Race oil are designed for minimum friction and viscosity where the engine only sees 150-500miles on a oil change, so they designed it without any detergents and additives a street engine needs. In conclusion, power to you and hope you have the money.
"He who exercises government by means of his virtue may be compared to the north polar star, which keeps its place and all the stars turn towards it"
2007 Acura TSX 6spd non-navi.
Ding on the hood
03-16-2008, 06:11 PM
#6 (permalink)
Not A MOD3RATOR
My Ride: 2005 Acura TSX 5AT
I think jrhonda is experiencing placebo effect on all his mod... lol...
I use Motul engine oil in summer too and somehow, I do feel my car less sluggish (more responsive) than using Mobil 1 Syn oil.
03-16-2008, 07:39 PM
#7 (permalink)
Hayai
I 'll stick with royal purple and hamp.
03-16-2008, 11:53 PM
#8 (permalink)
Shaka!
Just wish I could Dyno it... but I understand, maybe it is a placebo effect... one thing is for sure tho' the intake and exhaust is definitely noticeable. I actually switched to Royal purple 2 day. just for engine safesake, i read more into Motul race oil
03-17-2008, 04:18 PM
#9 (permalink)
Not A MOD3RATOR
There's only good quality syn oil, and bad quality syn oil. And when you are using the top of the line stuff(s), the result are pretty much the same. Just keep up w/ the maintanence (oil change etc) and your engine will be fine...
03-17-2008, 04:23 PM
#10 (permalink)
Shaka!
I agree.
03-18-2008, 01:51 AM
#11 (permalink)
$29 for an oil filter? i'll pass on the placebo effect. HAMP oil filters and royal purple work just fine on my car.
07 tsx (cgp)
| Thread Tools |
| Display Modes |
Linear Mode
