03-26-2008, 05:06 PM
#1 (permalink)
Not Fast Enough...
My Ride: Acura TSX 2004 6mt navi
Exedy Stage 1 Clutch...
I wanting to buy a Exedy stage 1 clutch, and want to know if I have to get a new flywheel; or can I use the stock one.
04' CGP 6MT Navi...
Performance| Injen SRI,Topspeed Header,Topspeed Exhaust,T1R Test Pipe,P2R Thermal IM Gasket,TB Bypass,Comptech Short Shifter
Apperance| 17x7 TenzoR Mean-6,Kuhmo SPT,EuroR Grill,EuroR Badges,M3 Lip Spoiler,20%/35% Tint
Brakes| R1 Slotted/Drilled Rotors,Hawk HP Pads
Suspension| Progress RSB
Lighting| JDM Hybrid D2C 8000k Bulbs, JDM Yellow Fog Lights w/ Nokya 2500K,Blue LED Interior Bulbs
03-26-2008, 05:10 PM
#2 (permalink)
 Moderator Marketplace
Any time you change the clutch you don't NEED to change the flywheel. But, if I was you, I'd do it. Better acceleration  Fidanza would be a good choice.
Palm Beach Hot Rods
Speed-Theory 973-227-2119
^Honda shop in Fairfield NJ
03-28-2008, 01:18 AM
#3 (permalink)
i bought my exedy stage 1 clutch from ebay for $250 new with a new flywheel and clutch alignment tool
03-28-2008, 01:59 PM
#4 (permalink)
Metal Head
I had heard that if you change to an aftermarket clutch for the TSX like the Exedy, you'd have to change the flywheel because they will not mate up. The Exedy kit that comes with a new flywheel like the member above stated is the way to go
04 CGP 6spd MT
03-28-2008, 02:19 PM
#5 (permalink)
 Ex-Moderator Emeritus
Originally Posted by VorteC
| Thread Tools |
| Display Modes |
Linear Mode
