Old 03-30-2008, 03:06 AM   #1 (permalink)
BB
sidetrak06's Avatar
My Ride: Acura TSX 2004
sidetrak06 is an unknown soldier, or on the road to either parallels.
Question DC header no flex pipe
I have a version 1 DC header with RT cat and the flex was bad. After putting in another flex it continued to buzz. Now with just a test pipe (no flex) the gaskets began to leak at the primary and secondary connection from vibrations. Does anyone have any suggestions on how to get rid of this buzzing noise? Thanks
04' MT
~Mods~
Performance:
-Injen CAI
-DC Sports Header (Flex Pipe removed)
-Random Technologies CAT
-1st exhaust resonator removed
-Comptech Short Shifter
-NST Underdrive Pulleys
Exterior:
Painted Calipers (Red)
Debadged ("Acura" & "TSX")
sidetrak06 is offline   Reply With Quote
Old 03-30-2008, 06:08 AM   #2 (permalink)
iVTEC no koe
HoRRo's Avatar
My Ride: Acura/TSX/2005
If you do replace the flex, be sure to replace it with double-braided flex pipe. Some people have installed something like this with no issues:
http://cgi.ebay.ca/ws/eBayISAPI.dll?...MEWA:IT&ih=009
Can't confirm if that's the correct size, but you want a double-braid/inner-weave flex pipe.
My car is stock, I promise.
Old 03-30-2008, 03:23 PM   #3 (permalink)
Not A MOD3RATOR
chuson's Avatar
My Ride: 2005 Acura TSX 5AT
The size is correct, but how do you know they are double-braid/inner-weave?
I'm going to HotRodScott this coming week to chop my flexpipe and replace a new one. Not sure if I should order online, or use his.
Old 03-31-2008, 02:18 PM   #4 (permalink)
raheel616's Avatar
My Ride: TSX/acura/2006
raheel616 is either technically knowledgeable, or well loved.raheel616 is either technically knowledgeable, or well loved.raheel616 is either technically knowledgeable, or well loved.raheel616 is either technically knowledgeable, or well loved.raheel616 is either technically knowledgeable, or well loved.raheel616 is either technically knowledgeable, or well loved.
im removing my headers at idle they shake violently causing a squeaky and loud rattle
06' CGP TSX w/ NAVI
-35% tint all around
-NST Overdrive Alternator Pulley
-NST Underdrive Crank Pulley
-Injen Cold Air Intake w/MR Technology
-T1R Earthing kit
-Topspeed header
-StrutKing Racing Stainless Steel Pedals
raheel616 is offline   Reply With Quote
Old 03-31-2008, 04:36 PM   #5 (permalink)
Not A MOD3RATOR
chuson's Avatar
Really? My DC Header (ver 2.) never shake @ Idle, no squeaky sound of loud rattle, I thought they should only happens on Comptech Header. I'm going to replace the flexpipe soon and get rid of those hissing sound.
Old 03-31-2008, 05:27 PM   #6 (permalink)
Clutch Dump of Death!!!
My Ride: 2004 TSX 6MT
ATX-TX Speed is neutral and has a clean balanced record.
the ebay linked flex pipe is 6" of flex pipe & 2" steel pipe at each end. Should work for the TS & DCsports headers. The original pipe from DC and TS is short, thus the cracking. for less than $30 shipped it is worth a try.
'04 CGP 6MT Non-Navi
K&N CAI, Cusco TypeII & Strut Brace
Progress RSB, MB Boost GM 17X7, Nitto NeoGen
CT Header, T1R TestPipe,
Eibach/Tokico, Wicked Camber
TB Bypass
Ingalls ETD, NST Pulleys
Axxis Ceramic, D/S Rotors
CT S-S
HONDATA-licious
ATX-TX Speed is offline   Reply With Quote
Old 04-01-2008, 03:50 PM   #7 (permalink)
raheel616's Avatar
i just found out yesterday that the rattle with the squeaky noise was from the heatshield on the cat, it apparently cracked due to the vibrations from being at idle in gear
06' CGP TSX w/ NAVI
-T1R Earthing kit
-Topspeed header
Old 04-01-2008, 06:33 PM   #8 (permalink)
Shady_ TSX is neutral and has a clean balanced record.
How do you know if you have the first or second make of the DC headers.. is there something that you can use to decifer ? Cause i bought one from a coompany but not sure which version it is. Any help would be great .. Im installing it tomorrow and don't know if I should bothere gettnig it welded.
Shady_ TSX is offline   Reply With Quote
Old 04-01-2008, 06:48 PM   #9 (permalink)
Not A MOD3RATOR
chuson's Avatar
I can conclude that ANY version of DC header should get a new weld flexpipe, unless you plan to change soon.
The easiest way to find out if you have V.2 is the manufacture date; anything after Mar/April 06 is the newer one.
Or, compare your flexpipe to the V.1 online, you will spot the differences near the welding of flexpipe.
Old 04-01-2008, 07:07 PM   #10 (permalink)
but either way you think that I should get it welded anyways ?
Old 04-01-2008, 07:18 PM   #11 (permalink)
Staff: Rank 2
Chief SuperModerator
Entertainment
pcdawg's Avatar
My Ride: TSX
pcdawg is either reputation whoring, or truly reaching the elite club.pcdawg is either reputation whoring, or truly reaching the elite club.pcdawg is either reputation whoring, or truly reaching the elite club.pcdawg is either reputation whoring, or truly reaching the elite club.pcdawg is either reputation whoring, or truly reaching the elite club.pcdawg is either reputation whoring, or truly reaching the elite club.pcdawg is either reputation whoring, or truly reaching the elite club.pcdawg is either reputation whoring, or truly reaching the elite club.
Better to get it done now that its not on ur car. The quality of the DC is not as good as the comptech as it is ceramic but with it being welded, will make it last longer.
pcdawg is offline   Reply With Quote
Old 04-01-2008, 07:29 PM   #12 (permalink)
Alright sounds like a plan and the welding should be done inside the piece with the flex pipe right ?
Old 04-01-2008, 07:42 PM   #13 (permalink)
BTW Chuson, what Weds rims do you have ? And where did you go to get them ?
Old 04-01-2008, 07:48 PM   #14 (permalink)
Not A MOD3RATOR
chuson's Avatar
There's 2 type of weld.
Tad weld - Re-inforce the original weld and use the same flexpipe.
Re-Weld - Chop the existing flexpipe & runner to replace a stronger one.
I got my WEDs off Tony (infamous206) on this forum. You can also order it thru rims shop.
Old 04-02-2008, 12:45 AM   #15 (permalink)
BB
sidetrak06's Avatar
I guess I didn't know you could get a stronger flex pipe. If that is the case then you don't expect any hissing our buzzing out of a double braided flex? Thanks guys
04' MT
~Mods~
Performance:
-Injen CAI
Exterior:
