Old 08-06-2008, 01:36 PM   #1 (permalink)
My Ride: 2006 Acura RSX Type-S
jacekrsx is an unknown soldier, or on the road to either parallels.
tsx supercharger
Hi,
I'm writing this for my friend, he has Euro version of 2006 Accord CL9, he wants to get supercharger like this:
http://www.clubrsx.com/cr/CTE-TSXSC-p-TSXSC.html
now, few question, will it fit his car?
his ECU needs to be reflashed, does he need new ECU from US TSX or can he use his own?
anyone ever installed this kit on Euro Accord?
Thanks!!!!
jacekrsx is offline   Reply With Quote
Old 08-06-2008, 02:37 PM   #2 (permalink)
(9)
Ex-Moderator Emeritus
narci's Avatar
My Ride: TSX/NAVI/05/GP
narci is either reputation whoring, or truly reaching the elite club.narci is either reputation whoring, or truly reaching the elite club.narci is either reputation whoring, or truly reaching the elite club.narci is either reputation whoring, or truly reaching the elite club.narci is either reputation whoring, or truly reaching the elite club.narci is either reputation whoring, or truly reaching the elite club.narci is either reputation whoring, or truly reaching the elite club.narci is either reputation whoring, or truly reaching the elite club.narci is either reputation whoring, or truly reaching the elite club.narci is either reputation whoring, or truly reaching the elite club.
Originally Posted by jacekrsx View Post
Hi,
Thanks!!!!
Depends on what motor he has. The Euro Accord has multiple motor lines as the TSX only has one.
Originally Posted by VorteC
narci is offline   Reply With Quote
Old 08-06-2008, 04:09 PM   #3 (permalink)
Hayai
kuma912's Avatar
My Ride: EP3-RR8-CL9
He'll definitely need a us spec ecu anc gauge cluster.
kuma912 is online now   Reply With Quote
Old 08-06-2008, 05:12 PM   #4 (permalink)
he has k24a3 2,4 190PS,
isn't that the same?
I don't own TSX personally, that's why I'm not sure.
but I have RSX Type-S
http://bp1.blogger.com/_OqN3tFJtWsg/...h/DSC01933.JPG
Old 08-06-2008, 10:40 PM   #5 (permalink)
Hayai
kuma912's Avatar
The motor is not the same. The tsx has the k24a2. Its similar to the k24a3. But they have different redlines and vtec engagement. That means the ecu is different.
Old 08-07-2008, 12:48 AM   #6 (permalink)
could he buy here ECU from TSX, flash it and install in his accord? or it won't work like that?
I also heard there might be problem with A/C...
Old 08-07-2008, 03:29 AM   #7 (permalink)
Hayai
kuma912's Avatar
Cant exactly tell what will go wrong. If he really wants it. He can try.
Old 08-07-2008, 10:26 AM   #8 (permalink)
ok, thanks for help
Old 08-07-2008, 10:37 AM   #9 (permalink)
he also says, he sent his ECU to US before to get Hondata and it works fine,
red line starts from 7600 and vtec from 4600, I don't know if it matters.
Old 08-07-2008, 11:48 AM   #10 (permalink)
Spoony's Avatar
My Ride: Accord 2003
Spoony is neutral and has a clean balanced record.
Hondata canīt reflash the ECU from the European Accord.With US Ecu, you have 3 Errorīs at the ECU.
Installing is not the problem, but programming the ECU.
03īGerman EuroR
Spoony is offline   Reply With Quote
Old 08-07-2008, 08:18 PM   #11 (permalink)
Not A MOD3RATOR
chuson's Avatar
My Ride: 2005 Acura TSX 5AT
I think Hondata might able to take care of it, send them a msg to ask.
Hondata has brought ECU Reflash to Aust, and have 3 different level of reflash too. It might only avaliable for Euro-R, but from what I read CL7/CL9 spec Accord can use it too.
Old 08-08-2008, 05:22 AM   #12 (permalink)
Spoony's Avatar
Problem ist the VSA,Navi and the gauges.It doesenīt work with the TSX ECU in the European Accord.
03īGerman EuroR
Old 08-08-2008, 01:34 PM   #13 (permalink)
bluecarbonfiber's Avatar
My Ride: acura/tsx/2005/cgp/at
bluecarbonfiber is neutral and has a clean balanced record.
anyone know the difference between the K20 (for rsx type s) comptech supercharger and the k24? I know the port holes on the heads are the same and so is the bolt pattern.. so other then the throttlebody being bolted on to it is there any differences? pulley size? boost different?
Friends dont let friends drive stock.
Interested in a cf mugen air spoiler click here>>>>>>http://www.tsxclub.com/forums/showthread.php?t=28649
bluecarbonfiber is offline   Reply With Quote
