Old 08-09-2008, 04:58 AM   #1 (permalink)
falken's Avatar
My Ride: cl7
falken is neutral and has a clean balanced record.
04 vs 05 accord (oem mods)
the 04 accord his throttlebody is smaller than the 05 is this only for the throttle response or are there other reasons honda did that? on the european 2L class. and are there other chances made as well?
falken is offline   Reply With Quote
Old 08-09-2008, 05:03 AM   #2 (permalink)
human668's Avatar
My Ride: Acura/TSX/2004
human668 is neutral and has a clean balanced record.
I'm not familiar with Accord in Europe. There are some improvements on 06 TSX (CL9) in North America.
http://hondata.com/reflash_tsx_06.html
The 06 TSX has the following improvements:
Increased intake flow:
* Intake valve + 1 mm oversize
* Intake cam High lift lobe with 0.9 mm more lift and 12 degrees more duration
* Throttle body increased from 60-64mm
* Radius on some intake pipes increased from 70-80mm
Increased exhaust flow
* Exhaust Head pipe increased from 60-65mm
* Higher flow catalytic converter
* Main (single) exhaust pipe increased from 54-57mm
* Rear (twin) pipes increased in diameter from 42.5 to 45mm
Block improvements:
* Additional air passages in crankcase for reduced pumping losses
Other
* Stronger connecting rods
* New crankshaft with more counterbalance weight
* Revised pistons with more valve-piston clearance
04 TSX and 06 TSX comparison
This compares a stock 06 MT TSX with a stock 04 MT TSX. Both cars had less than 1000 miles at the time of the dyno. As you can see differences are mainly at the top end on the high cam. On the high cam, the 06 generates about 15HP more
Hondata
J's Racing Fender Brace
LED headlights by Zhieson
Resonator removal
Weather-tech windows visors
Rear M3 style spoiler
A-spec suspension
Front Rotors: Racingbrake Ultra Performance (Slot)
Rear Rotors: Racingbrake High Performance (Slot),
Front and Rear Pads: Hawk HPS
Buddy Club Racing Spec Condenser Ground System
Progress RSB
Mugen Air Cleaner Box Kit
Coming up: none
human668 is offline   Reply With Quote
Old 08-09-2008, 05:09 AM   #3 (permalink)
falken's Avatar
My Ride: cl7
i dynod my this week but my k engine doenst have is horsepower that are on paper ? is that possible ...
Old 08-10-2008, 11:17 AM   #4 (permalink)
Mugen's Avatar
My Ride: Currently none
Mugen has a spectacular aura and a relevant respect from many.Mugen has a spectacular aura and a relevant respect from many.Mugen has a spectacular aura and a relevant respect from many.
like every other car, it's pretty nomal not to see the same amount of HP as the brochure tells you.
Sign by Danasoft - Get Your Free Sign
Mugen is online now   Reply With Quote
Old 08-10-2008, 11:22 AM   #5 (permalink)
Mugen's Avatar
maybe you could check your engine type.
The accord (euro) models were given quite a few engines of the last few years.
Look it up on the internet, there are alot of Honda forums that can tell you what changed.
My CL7 is one from the latest Gen, and the engine was chaned alot compared to the previous ones. Mine only use 3 valves instead of the usual 4 when cruising, but when i floor it it switches over to all 4 valves per cylinder.
Old 08-10-2008, 12:09 PM   #6 (permalink)
falken's Avatar
My Ride: cl7
thx for the info if anyone has some dyno's from the 2L you may contact me
i know also that horsepower isn't correct but if its alot beneath it
Old 08-10-2008, 02:07 PM   #7 (permalink)
Mugen's Avatar
Ik denk het niet, de meeste hier allemaal een TSX met de 2.4 motor
I don't think so, most people here have a TSX, wich has the 2.4 motor
Old 08-11-2008, 03:29 AM   #8 (permalink)
TheAc's Avatar
My Ride: Acura TSX 2004
TheAc is an unknown soldier, or on the road to either parallels.
the brochure tells u hp to the crank rather then at the wheels which im guessing how you dynoed, because its more.. making the car sound faster then what it really is
2004 Acura TSX
Navigation
Hondata
AEM SRI
Comptech Header
JDM headlights
18" ASA AR9
TheAc is offline   Reply With Quote
Old 08-11-2008, 12:42 PM   #9 (permalink)
falken's Avatar
My Ride: cl7
i have my wheel horse powers and my flywheel horseppowers and the flywheel its 152 with tuning of the engine
