Old 08-13-2008, 08:54 PM   #1 (permalink)
nyc06tsx's Avatar
My Ride: acura/tsx/2006
nyc06tsx has a spectacular aura and a relevant respect from many.nyc06tsx has a spectacular aura and a relevant respect from many.nyc06tsx has a spectacular aura and a relevant respect from many.nyc06tsx has a spectacular aura and a relevant respect from many.nyc06tsx has a spectacular aura and a relevant respect from many.
i need help...I am having problems with my RBC manifold
well this is the problem.. after installing my RBC manifold i got a EVAP code on my dash.. The problem is that there is two vacuum lines coming off the left side of the fuel rail, one is connected somewhere to the block under the intake manifold, and the second one WAS connected to the original intake manifold but the new RBC manifold doesnt have a place to connect that other line so because of that i am getting that code and the car is running at 1500 RPM when is in park...
can some one help me where to connect that other line.
NEWIMAGEMOTORSPORTS.COM
nyc06tsx is offline   Reply With Quote
Old 08-14-2008, 11:41 AM   #2 (permalink)
nyc06tsx's Avatar
another bump.. need this fix.. i know some one out there has installed the RBC manifold on their TSX
Old 08-14-2008, 12:44 PM   #3 (permalink)
My Ride: 2004 SSM TSX
CoopEuroR , with enough acceptance, will soon become famous.CoopEuroR , with enough acceptance, will soon become famous.
Maybe you can find your answer in this article... it talks a little bit about the k24 intake manifold. http://www.hondata.com/tuning_k24a2_tsx_engine.html
CoopEuroR is offline   Reply With Quote
Old 08-14-2008, 12:54 PM   #4 (permalink)
Shaka!
jrhonda's Avatar
My Ride: HondaBishi
I beleive you are going to need some type of tuning ability to make sure that RBC works right.
2006 Evo IV MR "Stock"
Old 08-14-2008, 06:09 PM   #5 (permalink)
My Ride: acura/tsx/2004
luder917 is neutral and has a clean balanced record.
you try plugging the hose? or put it to a vacuum?
18*8+30 225 40 18 (now with 15mm spacer in the rear)
are you sure they dont fit???
http://www.tsxclub.com/forums/showth...316#post400316
+22 coming soon...
luder917 is offline   Reply With Quote
Old 08-15-2008, 12:18 AM   #6 (permalink)
nyc06tsx's Avatar
i did and i disconnect the battery and then connect it back again.. but after about 2 hours it comes back on. i try it again to another vacuum line and the same thing happens
Old 08-15-2008, 02:22 PM   #7 (permalink)
Not A MOD3RATOR
chuson's Avatar
My Ride: 2005 Acura TSX 5AT
What's an EVAP code?
Did you install the RBC manifold yourself and is it a proper install? I knew several people w/ RBC installed but never have the problems you had.
I did had 1500rpm idling issue awhile ago, that's because I have swapped in a 06 IM/TB + bored it out to 71mm. The throttle body resting position (NOT the TB itself but rather the mechanical flip inside) was off, it's not been fixed.
It seems like you missed something in between.
Old 08-18-2008, 09:39 AM   #8 (permalink)
My Ride: CL9/08/PWP
JDM_CL9 is neutral and has a clean balanced record.
One Vac. line is for the front engine mount, I forget what the other one is for but on the RBC manifold, I know for atleast one of the vac. lines, you have to tap a hole under the manifold in order to run it properly.
"TURTLE on K"
2002 ES1 TypeS
2008 CL9 EuroR
JDM_CL9 is offline   Reply With Quote
Old 08-20-2008, 11:42 AM   #9 (permalink)
Not JDM
evertp1's Avatar
My Ride: My Ride
you need a hondata intake gasket
-Dr. Seuss
Robert G. Allen
Old 08-20-2008, 11:45 AM   #10 (permalink)
nyc06tsx's Avatar
I have the hondata intake gasket
Old 08-20-2008, 02:35 PM   #11 (permalink)
Not A MOD3RATOR
chuson's Avatar
Have you fixed the problem yet?
Does our throttle body fits on RBC perfectly? Maybe it needs a throttle body adaptor for RBB TB to fit on RBC IM.
Old 08-20-2008, 03:00 PM   #12 (permalink)
nyc06tsx's Avatar
The TB fits perfect with no problem... and yes i still have the problem.. but is ok... i dont mind the high rev but just that stupid check emission light is on
Old 08-20-2008, 03:57 PM   #13 (permalink)
My Ride: CL9/08/PWP
Did you use a new Throttle Body gasket? Usually when you remove the throttle body from the intake manifold, the gasket gets damaged or will not reseal properly which causes a small vac. leak..
"TURTLE on K"
2002 ES1 TypeS
2008 CL9 EuroR
Old 08-20-2008, 06:44 PM   #14 (permalink)
nyc06tsx's Avatar
i used a new one..
Old 08-21-2008, 09:56 AM   #15 (permalink)
damn... this is stumping everybody huh?
