Old 08-23-2008, 01:33 AM   #1 (permalink)
My Ride: TSX/2004/Silver
DPesso can only hope to improve, or face mass condemn.
Is this normal?
I was just wondering, I have an 04 TSX, I used to have an 02 Maxima and when I was cruising on the highway at speeds of 70+ if i let go of the gas, the car still coasts and doesnt decelerate until a couple seconds and if it does it decelerates slowly. I was cruising today on the highway going about 75 and I notice once I let go of the gas the car decelerates quite fast compared to my maxima. Is that how its supposed to be with this car or should it still coast? Can there be a problem? Thank you.
DPesso is offline   Reply With Quote
Old 08-23-2008, 02:37 AM   #2 (permalink)
code85's Avatar
My Ride: '05 Acura TSX
code85 is either technically knowledgeable, or well loved.code85 is either technically knowledgeable, or well loved.code85 is either technically knowledgeable, or well loved.code85 is either technically knowledgeable, or well loved.code85 is either technically knowledgeable, or well loved.code85 is either technically knowledgeable, or well loved.
I get that too.. I presume it's normal.
5AT '05 Premium White Pearl TSX
code85 is offline   Reply With Quote
Old 08-23-2008, 03:35 AM   #3 (permalink)
Clutch Dump of Death!!!
My Ride: 2004 TSX 6MT
ATX-TX Speed is neutral and has a clean balanced record.
Manual or Auto???
'04 CGP 6MT Non-Navi
K&N CAI, Cusco TypeII & Strut Brace
Progress RSB, MB Boost GM 17X7, Nitto NeoGen
CT Header, T1R TestPipe,
Eibach/Tokico, Wicked Camber
TB Bypass
Ingalls ETD, NST Pulleys
Axxis Ceramic, D/S Rotors
CT S-S
HONDATA-licious
ATX-TX Speed is offline   Reply With Quote
Old 08-23-2008, 04:16 PM   #4 (permalink)
2K5TSX's Avatar
My Ride: 2005 Acura TSX 5AT
2K5TSX is neutral and has a clean balanced record.
sounds like it might be a seized caliper... something is dragging slowing your car down more than normal... does it roll at idle?
Premium White 2005 Acura TSX 5AT
Mods:
35% & 15% Pinnicle Ceramic F1 Tint
Dryflow AEM SRI
3M Chip Guard
Gislaved Nordfrost 5 tires on RSX-S alloys
Hawk Performance Ceramic Pads
Mountain Rotors
Planned:
M3 Rear Lip Spolier
A-Spec Kit
2K5TSX is offline   Reply With Quote
Old 08-23-2008, 04:41 PM   #5 (permalink)
Un-Civil Engineer
griffojm's Avatar
My Ride: TSX/2004/MSM
It could just be the automatic transmission downshifting or the torque converter unlocking (or locking, not sure how that works) causing the speed loss. Its probably normal so that when you let off the gas, the car begins the slow-down process.
(I'm not positive about this, but it kinda makes sense to me. Please correct me if I am wrong....I don't want to give out bad info.)
Old 08-23-2008, 04:55 PM   #6 (permalink)
nyc06tsx's Avatar
My Ride: acura/tsx/2006
nyc06tsx has a spectacular aura and a relevant respect from many.nyc06tsx has a spectacular aura and a relevant respect from many.nyc06tsx has a spectacular aura and a relevant respect from many.nyc06tsx has a spectacular aura and a relevant respect from many.nyc06tsx has a spectacular aura and a relevant respect from many.
that is call DRIVE BY WIRE... do to our throttle body are control by wire, well it takes a few seconds for it to recognize that you let go the gas..
NEWIMAGEMOTORSPORTS.COM
nyc06tsx is offline   Reply With Quote
Old 08-23-2008, 06:58 PM   #7 (permalink)
Not A MOD3RATOR
chuson's Avatar
He was referring as TSX decelerate FASTER than Maxima when he let go the gas, not the other way around.
It really depends on what speed, what gear you are cruising on. When you let go the gas, the throttle body butterfly does not close completely, instead there will be gap and resting @ the "Resting position" of the DBW TB, not "closing position" unless you also step on the brake completely.
The Maxima has a V6, which is 2 cyclinder more than our TSX I-4. Thus it will be able to cruise @ a higher speed @ a lower rpm compare than our I-4 (also depends on gear setting), even when both TB @ the same "resting position", the maxima will still able to run @ a higher speed, which is what you used to your regular cruising speed.
Old 08-23-2008, 07:03 PM   #8 (permalink)
i have an auto, i doubt its a sticking caliper because when im going 20 or 40 the car coasts for a while, or wen im idling it coasts, if i had a sticking caliper it wudnt even idle good. correct? so is this normal you guys are saying?
Old 08-24-2008, 02:59 PM   #9 (permalink)
My Ride: 2004 SSM TSX
CoopEuroR , with enough acceptance, will soon become famous.CoopEuroR , with enough acceptance, will soon become famous.
Well, i've never driven a maxima but my TSX seems like it coasts pretty good... My last car was a 95 accord and I dont notice any significant difference in the way the TSX acts when i let off the gas... maybe its just what you're used to from driving the maxima.
*shrug* doubt anything is wrong with the car, at least I hope there isn't good luck
CoopEuroR is offline   Reply With Quote
Old 08-25-2008, 01:30 AM   #10 (permalink)
Forum Vendor
Forum Vendor
MrHeeltoe's Avatar
My Ride: 90 Integra
MrHeeltoe has a spectacular aura and a relevant respect from many.MrHeeltoe has a spectacular aura and a relevant respect from many.MrHeeltoe has a spectacular aura and a relevant respect from many.MrHeeltoe has a spectacular aura and a relevant respect from many.
Comparing the TSX to a Maxima is apples and oranges. I suspect the difference has to do with vehicle momentum and different amounts of engine braking between the two cars at different rpms.
HeeltoeAuto.com, ACURA SPECIALIST
Enter Coupon Code tsxrocks for 5% off!
DO NOT PM!
MESSAGE ME HERE
EXCLUSIVE ACURA Parts
1G TSX
2G TSX
Get your driving socks here
Swtichblade Keys : ATLP Distributor : TEINS : Racingbrake Rotors
Parts Broker Extraordinaire! Matching you up with the right parts at the right price!
Click here for all our sales, specials, promotions and group buys!
http://tsxclub.com/forums/heeltoe-automotive/
MrHeeltoe is offline   Reply With Quote
Old 08-27-2008, 03:08 AM   #11 (permalink)
2K6TSX , with enough acceptance, will soon become famous.2K6TSX , with enough acceptance, will soon become famous.
I also just came from a maxima, I think it could have something to do with the fact that the maxima (mine anyway, a 2003) is bigger and heavier so it gains more momentum and can therefore keep coasting longer?
2006 TSX/6MT/Aspec/Navi
2K6TSX is online now   Reply With Quote
