Old 09-12-2008, 05:51 PM   #1 (permalink)
My Ride: acura tsx 2004
eurortsx is an unknown soldier, or on the road to either parallels.
OEM Cat
Any of you guys know where i can get an OEM Cat ...cheap or if you know anyone that is selling theirs after putting on a highflow cat on. I ran over a brick and it crack it. Long story!!! Now i got CEL o2 sensor code. thanks
eurortsx is offline   Reply With Quote
Old 09-13-2008, 12:20 AM   #2 (permalink)
Not A MOD3RATOR
chuson's Avatar
My Ride: 2005 Acura TSX 5AT
You sure it's the cat problem?
The O2 sensor (along w/ wires) might hang low and you might actually break the sensor (or wires) instead of the cat, thus it will throw up a CEL too.
Old 09-13-2008, 04:43 AM   #3 (permalink)
Bork Bork Bork
zhieson's Avatar
My Ride: Acura/TSX/2005
Unless you find someone trying to get rid of their stock for cheap, get Magnaflow or Random Technologies. More free flowing and probably cheaper than OEM. Also, if you do go OEM, make sure its an 06+. 06+ are better flowing than the 04-05s.
Old 09-14-2008, 11:30 AM   #4 (permalink)
KingTSX's Avatar
My Ride: 04' Acura TSX M6
KingTSX is neutral and has a clean balanced record.
Where are you located? I have stock cat off of a 04'TSX with just a hair over 50k on it. PM me if interested, if outside the US, shipping could be a higher cost.
04' NBP 6-speed TSX..mods to follow shortly
KingTSX is offline   Reply With Quote
Old 09-15-2008, 11:50 AM   #5 (permalink)
oh its definitly the cat because when i took it off. . all the mesh in the inside use gone. when i hit that brick it must of broke it all up a shot it out the exhuasted pipes. Pretty crazy right!!!. Not to mention it hit the header as well.
Old 09-15-2008, 07:28 PM   #6 (permalink)
Not A MOD3RATOR
chuson's Avatar
Did it bent the header too or just minor scratches?
Anyways, you need a new cat. For the same price (I mean retail) get 06 Cat, OEM quality and less restricted than 04/05. 06 has 400cells vs 800cells, so consider this as a free mod and put a smile on your face w/out worry about the CEL problem.
Old 09-16-2008, 01:28 PM   #7 (permalink)
just some scatches.
