Old 10-01-2008, 08:16 PM   #1 (permalink)
Phixnation's Avatar
My Ride: Acura/TSX/2004
Phixnation is an unknown soldier, or on the road to either parallels.
Clutch clicking
My car has 67k miles and the clutch pedal is starting to make clicking noises. I went to the dealership and they said it was the clutch master cylinder estimating a cost of 320 to 350 dollars to replace.... Does anyone know if the clicking caused by the cylinder will cause further damage or if there is a cheaper solution to this?
Phixnation is offline   Reply With Quote
Old 10-01-2008, 10:18 PM   #2 (permalink)
iVTEC no koe
HoRRo's Avatar
My Ride: Acura/TSX/2005
Does the clutch only "click" at the bottom/fully depressed (or top)?
My car is stock, I promise.
Old 10-02-2008, 10:17 PM   #3 (permalink)
My Ride: 2006 TSX
yonseispeed is neutral and has a clean balanced record.
could also be the release bearing.
yonseispeed is offline   Reply With Quote
Old 10-02-2008, 11:00 PM   #4 (permalink)
gmchu's Avatar
My Ride: n/a
gmchu , with enough acceptance, will soon become famous.gmchu , with enough acceptance, will soon become famous.
here is a DIY I followed this past weekend to fix this issue. Took no longer than 15 min. most of that time was spent looking around down there. If you don't want to DIY, I believe there is a TSB regarding this so do not pay your dealership to replace the clutch master cylinder, they should be doing that for free. I also do not believe the clicking is doing any damage...it is just annoying.
Originally Posted by JimDaugherty View Post
Though many owners have written about the “clutch click,” I am unable to find a how-to-do-it thread on the clutch click repair. My clutch had a pronounced click near the bottom of the travel.
It took me about 30 minutes to do this repair and take pictures with my phone. I suspect that this repair is similar to the dealer’s “lubricate clutch linkage.” If this procedure stops the click, you do not need a clutch master cylinder replacement.
In addition to some lubricant, you will need a light and a Philips screwdriver. Here, remove the one screw in the cover below the steering column. (The two metal fingers in the right bottom is the light's hook.)
This cover is held in place by this screw and 3 or 4 plastic clips (my index finger) which are inserted in the square holes (my pinky). I pulled the cover off being careful not to twist the cover and break the clips.
The kick panel over the footwell is held in place with the same kind of clips. Carefully pull it down at the clips at the edge closest to you.
When this edge is down, you can pull the kick panel toward you. The attachment at the firewall is just two pins that slide slots attached to the firewall.
I needed a light to see the clutch linkage while lying on my back in the footwell. My index finger points to the pad for the top switch (cruise control release). This switch made an audible click. There was no lack of yellow grease on the joints of the clutch linkage. I just smeared the grease that was there back into the link pins. This did not help the click at the bottom of the travel.
Here the clutch pedal is depressed. I also smeared the grease into the top switch (at the center of the picture, the switch pushrod is extended). This is probably not recommended, but it did make the switch click much softer. Here you can see the base of the clutch master cylinder (about three inches to the right and above the pad for the top switch). I squirted silicone spray lubricant into the base of the clutch pushrod using a tube from a can of WD-40 to keep from spraying the stuff all over the car’s interior. (Note that there is almost no chance of contaminating the clutch fluid doing this.) I suppose that about any lubricant would work; though some would last longer than others would. (Think Lubriplate, WD-40, lithium grease, Vaseline, wheel bearing grease, etc). You save yourself the pain of disassembling and reassembling the linkage if you can squirt something into the clutch master cylinder where the pushrod goes in. (I suspect the fix would last for years if you can get some wheel bearing grease where the clutch pushrod meets the base of the clutch master cylinder piston.) Without a doubt, other posters will provide some suggestions on appropriate lubricant.
The closest dealer is a 50-mile round trip and takes the better part of a morning for any task. Even if this fix is temporary, it would only take me ten minutes to do it again. However, the next time I would get a more durable lubricant before I started.
I hope this helps.
gmchu is offline   Reply With Quote
Old 10-02-2008, 11:45 PM   #5 (permalink)
Phixnation's Avatar
Thanks man I'll try this out when I have time.
Old 10-03-2008, 01:04 PM   #6 (permalink)
Luwin1026's Avatar
My Ride: 2005 Acura TSX
Luwin1026 is either technically knowledgeable, or well loved.Luwin1026 is either technically knowledgeable, or well loved.Luwin1026 is either technically knowledgeable, or well loved.Luwin1026 is either technically knowledgeable, or well loved.Luwin1026 is either technically knowledgeable, or well loved.Luwin1026 is either technically knowledgeable, or well loved.
I had this same issue and had my dealer replace the master cylinder and the pedal assembly while they were at it. (under warranty) - this was around a month ago - and no more click.
2005 Acura TSX 6-spd
2006 Honda Pilot EX-L Navi
Luwin1026 is offline   Reply With Quote
Old 10-03-2008, 01:26 PM   #7 (permalink)
Forum Vendor
Forum Vendor
MrHeeltoe's Avatar
My Ride: 90 Integra
MrHeeltoe has a spectacular aura and a relevant respect from many.MrHeeltoe has a spectacular aura and a relevant respect from many.MrHeeltoe has a spectacular aura and a relevant respect from many.MrHeeltoe has a spectacular aura and a relevant respect from many.
gmchu, nice diy....done like a former BMW owner....it is so?
HeeltoeAuto.com, ACURA SPECIALIST
Enter Coupon Code tsxrocks for 5% off!
DO NOT PM!
MESSAGE ME HERE
EXCLUSIVE ACURA Parts
1G TSX
2G TSX
Get your driving socks here
Swtichblade Keys : ATLP Distributor : TEINS : Racingbrake Rotors
Parts Broker Extraordinaire! Matching you up with the right parts at the right price!
Click here for all our sales, specials, promotions and group buys!
http://tsxclub.com/forums/heeltoe-automotive/
MrHeeltoe is offline   Reply With Quote
Old 04-19-2009, 05:29 PM   #8 (permalink)
100% rooster
ricky rooster's Avatar
My Ride: 05 TSX pwp/05 GSXR 1000
ricky rooster has a spectacular aura and a relevant respect from many.ricky rooster has a spectacular aura and a relevant respect from many.ricky rooster has a spectacular aura and a relevant respect from many.ricky rooster has a spectacular aura and a relevant respect from many.
worked great write up
ricky rooster is offline   Reply With Quote
Old 07-25-2009, 01:30 AM   #9 (permalink)
My Ride: TSX / 2009 / Carbon Grey Pearl
TXPTuff is an unknown soldier, or on the road to either parallels.
For me the dealer replaced the master and slave clutch cylinders three times. I think I'm on revision #4 or #5 for the parts. Unfortunately, I'm outside my warranty so, every 3 months I spray white lithium grease or some special silicone stuff following gmchu's instructions. I know it's time for a treatment when I start feeling small popping or hear a rubber squeaking sound when I push/release the clutch. Not as bad during the colder months.
TXPTuff is offline   Reply With Quote
Old 07-25-2009, 01:47 AM   #10 (permalink)
My Ride: acura/tsx/2006
aeon is neutral and has a clean balanced record.
what exactly is this clicking noise? I've been driving with it for a long time now. Doesn't bother me too much though. should I look into getting it fixed?
aeon is offline   Reply With Quote
Old 10-04-2009, 07:29 PM   #11 (permalink)
My Ride: 2004 Milano Red TSX
Acuramaru is an unknown soldier, or on the road to either parallels.
Thumbs up
Why isn't this a sticky? This thread just saved me $500 that the dealer wanted to replace the clutch pedal.
Thanks!
Acuramaru is offline   Reply With Quote
Old 10-04-2009, 07:57 PM   #12 (permalink)
My Ride: TSX/05/Silver
CraZie , with enough acceptance, will soon become famous.CraZie , with enough acceptance, will soon become famous.CraZie , with enough acceptance, will soon become famous.
hmm mines clicks also. Should have the dealer check it out. Where can i go to check if my vehicle has any recalls or TSB?
FS: Falken Torque 5's 19" FK452
- 20% tint - BlueBat Overlays - Painted Calipers - Russell SS Brake Lines - Hawk Ceramics Pads - Rotora Slotted F/R Rotors - iSimple - JDM Fog Lights
CraZie is offline   Reply With Quote
Old 10-04-2009, 09:17 PM   #13 (permalink)
Age
X1000r/min
Age's Avatar
My Ride: 2007 TSX MT
Age is either technically knowledgeable, or well loved.Age is either technically knowledgeable, or well loved.Age is either technically knowledgeable, or well loved.Age is either technically knowledgeable, or well loved.Age is either technically knowledgeable, or well loved.Age is either technically knowledgeable, or well loved.
Funny that I just fixed my creaking/ clicking clutch pedal this morning. I put a big glob of lithium grease in the cylinder that goes through the firewall and worked it in with my finger while pressing the clutch in.
Noise is gone.
Veni, Vedi, Abeo
Age is offline   Reply With Quote
Old 10-05-2009, 02:00 PM   #14 (permalink)
Boost Enthusiast
audioserf's Avatar
My Ride: Boosted 04 6MT
My clutch has done this for at least two years. Hasn't seemed to hurt anything or get any worse. 04 with 57k miles. I just deal with it because I hate going to the dealership.
Old 10-05-2009, 02:43 PM   #15 (permalink)
ridiculously good looking
tsx 2 nv's Avatar
My Ride: Acura TSX 2004
tsx 2 nv is an unknown soldier, or on the road to either parallels.
same here...04 with 82k miles
tsx 2 nv is offline   Reply With Quote
