Here are some side by side pics before I installed it compared to the factory shifter.
I wish I had bigger ones but you can see how the Mugen one has solid shifter bushings for the base mounting points, the shifter is perfectly straight with no bends and is also slightly shorter in length.
I found it does make a difference in case you were wondering.
