10-23-2008, 03:32 PM
#1 (permalink)
2004 Clutch replacement
I wanted to know if someone can direct or pm me to a link on replacement of the MT clutch/flywheel. At 140,000 it's about due.
Thanks
10-23-2008, 04:14 PM
#2 (permalink)
Bork Bork Bork
You try looking at the Acura OEM replacement websites?
http://www.acuraoemparts.com/delray/...atcgry5=clutch
It was very easy to find.
10-23-2008, 05:01 PM
#3 (permalink)
Why not just after market.
10-23-2008, 07:37 PM
#4 (permalink)
Forum Vendor
My Ride: Multiple Honda's
If you're looking for an OE replacement clutch kit check out the Exedy setup. It even includes a flywheel.
http://store.excelerateperformance.c.../i-126223.aspx
EXCELERATE PERFORMANCE - Official TSXClub Vendor and Acura Performance Parts Specialist!
See our Comptech, ROTORA, Unorthodox Racing, Progress, TOKICO, Innovative Mounts, AEM, P2R, KAIXEN HID, TEIN, Random Tech, Injen, DC Sports, K Sport, Ingalls Sales at The Excelerate Performance Forum
NEW WEB STORE: Store.ExceleratePerformance.com
AIM: Excelerate04 Phone: 203-483-6100
http://www.ExceleratePerformance.com
10-23-2008, 08:10 PM
#5 (permalink)
Doesn't Exeddy make OEM clutches for honda. I thought i heard that some where...
10-24-2008, 12:42 AM
#6 (permalink)
My Ride: 2005 Acura TSX 6MT
Is the clutch going out or something? Clutches don't really have a set mileage to be replaced at. A clutch is due for replacement when it is failing. If you're nice to it, it could last several hundred thousand miles. Probably more. Not to mention it's expensive!
If you are set on putting in another clutch, get a lightened flywheel if you want some more performance. The stock one feels heavy...
lookin good, classy not hood
10-24-2008, 03:39 AM
#7 (permalink)
Forum Vendor
Yes, and you'll also find that their replacement "organic performance clutches" aren't much better than OEM ones either.
We offer a host of Clutchmasters kits:
http://www.heeltoeauto.com/home.php?cat=3373
The FX300 is supposed to work really good in these cars:
http://www.heeltoeauto.com/Clutchmas...-pr-63105.html
Marcus
10-24-2008, 11:11 AM
#8 (permalink)
Clutch replacement
Sorry Guys,
I was trying to find a link to the service manual or instructions on changing the clutch. I just bought a Gredy Stage 1 clutch. I'm keeping the stock flywheel. I autocross and don't want to move out of stock class. Any help would be appreciated. Thanks.
10-24-2008, 01:35 PM
#9 (permalink)
I am the SneakHerHunter
uhhhhhhhhhh since when will a flywheel upgrade actually put you in a whole other class??????
Photograffy= Sony ALpha A100 18-70mm/75-300/11-18mm/ 50mm 1.4
PHAZE 2+ DOODS is tizzzzite
HOT STUFF INTERNATIONAL 2009
THE CHRONICLES.....Honda/Acura BLOG
http://www.stickydiljoe.com
10-24-2008, 03:13 PM
#10 (permalink)
It's the SCCA rules for Solo2. Lightened flywheel was never allowed in Stock and Street Touring classes. To the OP, you may want to check the rules on the clutch for Stock class also. IIRC, you can only use OEM-spec aftermarket clutches.
| Thread Tools |
| Display Modes |
Linear Mode
