Old 11-01-2008, 01:40 PM   #1 (permalink)
My Ride: tsx 2004 silver
firebad is an unknown soldier, or on the road to either parallels.
Dbw
My biggest complaint (besides the seats) in the tsx is the dbw.
I hate the lag and the part throttle response is annoying.I heard the civic Si guys were converting back to cable, and this interests me where I'd like to look into it a bit more.
Is there any links or reading up I could do to get some more info on this. I think it would require a lot of work, but Im just curious to the full extent of it.
Thanks gang.
firebad is offline   Reply With Quote
Old 11-01-2008, 01:44 PM   #2 (permalink)
Another Honda Guy
H22A_CD5's Avatar
My Ride: 04 MSM 6MT
H22A_CD5 , with enough acceptance, will soon become famous.H22A_CD5 , with enough acceptance, will soon become famous.
Converting back to cable throttle means you have to convert to the rsx throttle body/cable/pedals/ecu. this means you would have the ablilty to use KPRO but you would lose VSA, Cruize, and maybe your gauge cluster. There is alot of info about this already out there, so start by searching here on the forum. If that doesnt satisfy you, move to google, and there is a wealth of info to be found elsewhere on the web as well.
04 TSX MSM/Quartz 6MT
91 Civic Hatch SOHC ZC (Stolen/Recovered, Sold) I am 2/4 now *sad i dont want to lose my TSX
95 Accord Sedan H22A (Stolen/Recovered, Sold)
05 Elantra Sedan (Wifey)
Arizona Meet Memorial Day Weekend in Phoenix
http://tsxclub.com/forums/south-west...y-weekend.html
H22A_CD5 is offline   Reply With Quote
Old 11-01-2008, 01:50 PM   #3 (permalink)
That's a start. Thanks.
Old 11-01-2008, 01:57 PM   #4 (permalink)
Another Honda Guy
H22A_CD5's Avatar
My Ride: 04 MSM 6MT
no problem
Old 11-01-2008, 02:37 PM   #5 (permalink)
Hayai
kuma912's Avatar
My Ride: EP3-RR8-CL9
You won't necessarily lose your gauges. Get an electrical manual and figure out the wiring. As for reverting to cable. I don't know why you would do such a thing.
Old 11-01-2008, 02:41 PM   #6 (permalink)
Hayai
kuma912's Avatar
1. RSX Type S throttle body with RBC adapter plate OR accord TB should bolt directly
2. throttle cable (EP3 should fit)
3.) older k-series ECU - preferably K-pro'd make sure to get a version with the speedo correction b/c '06 si runs different VSS than older K-series
Because the Si has a digital speedo, you would probably need to have it K-Pro'd (just a guess, since the RSX and older EP3s did not have a digital speedo).
Here is more info on the K-Pro: K-Series Programmable ECU
If there is any more that needs to be done, I will post here, and let you guys know. So far, since this is such new technology, we are still exploring it.
If you want to do this to fix the infamous "RPM hang", there is a ECU modification for that, and you do not need to change the DBW system.
DBW is a new throttle control system, and currently it's not "ideal" for racing or high performance, but as we learn more, it might be the best setup... currently people are not happy with it due to the delay of foot hits pedal, pedal tells ECU to open throttle, throttle opens.
Just an FYI. The NSX uses dbw.
