Old 03-29-2009, 06:35 PM   #1 (permalink)
I love my honda.
Rivalry's Avatar
My Ride: 2004 6MT NBP
Rivalry has a spectacular aura and a relevant respect from many.Rivalry has a spectacular aura and a relevant respect from many.Rivalry has a spectacular aura and a relevant respect from many.
possible engine problem, help before I ruin something.
Hey whats up guys, so I just changed the valve cover on my car because I'm sending my stock one out to get painted. Here the problem, I broke on of the bolts that holds the spark plugs down and one of the bolts that holds the actual valve cover down. What I need to know is, first, how can I fix this, and second, is it safe for me to drive like this. I have a 40 mile round trip to school tomorrow so I sure hope I can. Also, the broken spark plug bolt is stuck, I cant get it out. Should I take it to honda or a mechanic and see what they can do or what? Need your help again guys.
thanks.
Rivalry is offline   Reply With Quote
Old 03-29-2009, 06:50 PM   #2 (permalink)
hoplessly addicted to JDM
MMsTSX's Avatar
My Ride: 08 CGP Quartz AT Navi CL9
MMsTSX , with enough acceptance, will soon become famous.MMsTSX , with enough acceptance, will soon become famous.
gra-bit bits.
http://www.4grabit.com/Default.asp?bhcp=1
next up: 20x9/10 +35 Volk G2's for my G.
MMsTSX is offline   Reply With Quote
Old 03-29-2009, 07:05 PM   #3 (permalink)
I love my honda.
Rivalry's Avatar
Originally Posted by MMsTSX View Post
gra-bit bits.
Order Here!
But I gotta drive my car tomorrow basically, and although that is help and thanks, that only solved the issue of the stuck bolt. Can I drive the car safely like this or no?
Old 03-29-2009, 07:53 PM   #4 (permalink)
Metal Head
1TSXer's Avatar
You'll be alright dude. I've done this on several of my previous hondas. The stud bolts cost around $9-$15. I always buy a couple of extra. Get yourself a torque wrench so you can torque those to spec and not snap any in the future.
04 CGP 6spd MT
Old 03-29-2009, 07:54 PM   #5 (permalink)
Metal Head
1TSXer's Avatar
You should also be able to get that broken off bolt out when you remove the valve cover again.
04 CGP 6spd MT
Old 03-29-2009, 08:00 PM   #6 (permalink)
I love my honda.
Rivalry's Avatar
Alright thanks a lot man.
And i'm assuming I can just get one of the stud that hold the valve cover down at any auto part stores? you know off hand is there is a part number?
Old 03-29-2009, 08:10 PM   #7 (permalink)
Metal Head
1TSXer's Avatar
Sorry, I don't know the PN. I don't think you will find it at any parts store. You'll definately need to go to the dealership. I always ordered mine online.
04 CGP 6spd MT
Old 03-29-2009, 09:07 PM   #8 (permalink)
I love my honda.
Rivalry's Avatar
You got a link to where I can order them?
Old 03-29-2009, 11:55 PM   #9 (permalink)
My Ride: 2004 TSX
a2dadamm is neutral and has a clean balanced record.
hey man, just shoot down to honda on 202 they might have it in stock and be able to help you.. should be cheap.. and u should be fine to drive it around..
just gotta be carefull with tthose bolts they snap easily and like said B4 u should get a torqe wrench so everything is to spec.
a2dadamm is offline   Reply With Quote
Old 03-30-2009, 12:02 AM   #10 (permalink)
I love my honda.
Rivalry's Avatar
any body know the proper amount to torque the bolts down?
Old 03-30-2009, 12:07 AM   #11 (permalink)
My Ride: 2004 TSX
not off hand but u should be able to get ahold of like a haynes manual for our cars or even online find it.. the manual u can usually find them online
Old 03-30-2009, 12:15 AM   #12 (permalink)
I love my honda.
Rivalry's Avatar
thanks, I'll see if I can find it.
I saw on clubrsx that someone said 7.2lbs. anyone know if that sounds right?
Old 03-30-2009, 12:20 AM   #13 (permalink)
My Ride: 2004 TSX
yeah prob about right they small and dont require much, u can do it without a torqe wrench just be sure that once u feel them snug and tight not to go anymore..
Old 03-30-2009, 12:29 AM   #14 (permalink)
I love my honda.
Rivalry's Avatar
sounds good thanks.
Old 03-31-2009, 01:28 PM   #15 (permalink)
I love my honda.
Rivalry's Avatar
still can't get the snap spark plug bolt out.
any suggestions before I just buy that thing MM suggested?
Edit, I order that tool anyway just incase anything else happens, but still looking for maybe a quicker fix.
