Old 04-12-2009, 05:07 PM   #1 (permalink)
The Swede
Stardragon's Avatar
My Ride: 07 Accord Type-S
Stardragon has a slight shameless behaviour in his/her past.
How to successfully ruin a fully functional engine
So when browsing diffrent car forums, and you've been around for a while on these. You start to notice that the same problems returns over and over from various people trying to modify their car. Maybe not so much on this one, since the audience here seems a bit more mature from what i've experienced. But it might help someone atleast. ;)
Usually it's the same deal. Some young dudes just watched the F&F movie and went to buy some expensive, shining stuff from some well known retailer with a fancy name. The same kind of problems strike them, more often than not:
Classic #1:
Scotty 22 years, just bought a fancy intake from his local dealer around the corner. Of course he got the one that matches the trim color of his car. As long as the color is right, nothing can go wrong.
Then he notice one or a few of the following problems (if not all):
1. His car runs like a combine harvester.
2. The engine doesnt run higher than 4500 RPM.
3. The engine doesn't feel as strong as it used to on higher RPMs, even though he got the really sweet intake sound.
Well, his super fancy intake he bought from "Steves racing and ice cream" has:
1. Let so much dust through the pores that the engine that were in mint condition before, now needs a complete work over.
2. The oil he sprayed on the intake (and of course a little extra "just to be sure") has clogged the wolframstring in the air flow sensor, wich eventually snapped. The injection box did of course notice this and switched to emergency mode. That's why he cant exceed 4500 RPM, plus there is now steam comming out from his car.
3. Hot air is beeing sucked into the intake from around the engine. This due to poor design/emplacement of the intake, wich makes the engine lose its effect.
4. 1 combined with 3.
Solution:
He should build some kind of heat shield around the intake. Or even better, connect the intake in a way so that it only get cold air from the wheel housing. Possibly by drilling a hole in the engine room wall.
Don't add too much of that oil spray on the intake. Obviously.
Don't buy a cheap random brand from around the corner, of course even the well known brands might be just as bad. But it's usually a safer bet.
Or simply leave it as it is. The ones who once built the car usually did a good job...
Classic #2:
Mike 21, has decided to get himself a new exhaust system. After watching F&F a few hours he realizes that "3 inch is the way to go!". The day after, Mike drives down to his local exhaust dealer. Robert there, draws him a tailor made exhaust for an insane amount of money. When later popping the hood he figure that it's a bit tight around the engine and the outlet manifold, downpipe and whatnot is probably hard to remove and everything will probably become complicated. So 3 inch behind the cat should probably be just as good. It saves him some money too!
So a few weeks later, (the dealer had alot to do) there it is. Shining under his car. Thick... Chromed... 3.5 inch. Everything he ever wanted. (Non-perforated of course. Otherwise it was way too expensive.)
So with light steps he skips into his car, turns the ignition key. And... It sounds... Diffrent... And it sure sounds alot too.
A few days later Mike realizes that, maybe this wasn't the best of ideas after all. First of all his car sounds like a truck in a can. Theres some bang sounds comming out from behind the car when he releases the throttle. And his friends Jeff and Jennifer in the back seat feels a bit nauseous after a while when riding in the car.
Was his exhaust installation such a smart move? --- Nah.. Not so much.
What he failed to take into calculation was:
1. His non-turbo engine.
2. Stock outlet manifold and cat.
3. Randomly positioned transition from his stock 1.7 exhaust to his new 3.5. Robert, the exhaust dealer, just joined the pieces together wherever it was easier for him to weld.
This "upgrade" gave Mike a slightly higher top effect, but maladjusted exhaust pipes will result in all kinds of resonance in the car and some pretty wierd dyno charts too.
So what should our dear Mike have done in the first place?
Well. A well made header, connected trough soft elbows to a high flow cat. Then 2 inch pipes to a freer flowing muffler. If he feels that he needs a shiny end pipe, he should make sure to get a perforated one to get rid of the resonance.
The size of his trunk and the resonance at 3000 RPM at 70 mph happens to be the exact resonance frequency of the craniums of his two friends. That's why they don't feel too good after a while.
Exhaust fumes are hot when they first leave the engine and gets cooler as they travel back trough the system.
The ideal gas law (pV=nRT) tells us that the volume of hot gas is greater than the volume of cold. Wich means that it's the first section of the exhaust system that matters. Header, down pipe, etc. And that's where you want to have your thicker pipes. Not at the end.
(Turbo charged cars have diffrent exhaust rules, but I'll skip that part since the TSX comes without.)
Please do consider that english isn't my mother tongue. Some of the terms might be wrong.
Either bare with me or point me in the right direction, I'm always keen to learn ;)
Stardragon is offline   Reply With Quote
Old 04-12-2009, 08:21 PM   #2 (permalink)
Un-Civil Engineer
griffojm's Avatar
My Ride: TSX/2004/MSM
I think you described 2 people in my neighborhood.
Oh, and your English was pretty good!
Old 04-12-2009, 08:28 PM   #3 (permalink)
Not JDM
evertp1's Avatar
My Ride: My Ride
Interesting topic! What would you suggest for someone planning on installing camshafts?
and yea, you have described a couple rice boys in my area as well
-Dr. Seuss
Robert G. Allen
Old 04-12-2009, 09:16 PM   #4 (permalink)
I LUV JDM
tsx4life's Avatar
My Ride: CL9 2006
tsx4life is either reputation whoring, or truly reaching the elite club.tsx4life is either reputation whoring, or truly reaching the elite club.tsx4life is either reputation whoring, or truly reaching the elite club.tsx4life is either reputation whoring, or truly reaching the elite club.tsx4life is either reputation whoring, or truly reaching the elite club.tsx4life is either reputation whoring, or truly reaching the elite club.tsx4life is either reputation whoring, or truly reaching the elite club.tsx4life is either reputation whoring, or truly reaching the elite club.
we have a couple of those around my way...actually we have a lot...lol
" I Love JDM "
tsx4life is offline   Reply With Quote
Old 04-12-2009, 10:24 PM   #5 (permalink)
Donating member
My Ride: 05, Auto
Ricers are everywhere these days
Old 04-12-2009, 11:50 PM   #6 (permalink)
Premium Club Member
lcrazyaznl's Avatar
My Ride: Acura/Tsx/05 AT
Well put my friend. I always told myself and others not to go cheap or you will pay in the long run.
Northeast Tsx Group
Flickr
lcrazyaznl is online now   Reply With Quote
Old 04-13-2009, 01:11 AM   #7 (permalink)
RML-R6Staff: Rank 5
Moderator
Entertainment
Carbon's Avatar
My Ride: 2007 CGP Acura TSX
Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.
Originally Posted by TSX_WS View Post
This reminds me of how I once drove through a Latino neighborhood.
Just a few mods...
Carbon is offline   Reply With Quote
Old 04-13-2009, 10:42 AM   #8 (permalink)
Tofu
My Ride: 2005/TSX/MT/Black/Non-navi
t5a1 is an unknown soldier, or on the road to either parallels.
Haha, this reminds me of high school.
t5a1 is offline   Reply With Quote
Old 04-13-2009, 04:37 PM   #9 (permalink)
I LUV JDM
tsx4life's Avatar
My Ride: CL9 2006
wow... it still exist... were talking about cars in general and you talking about race and singled out a nationality....
" I Love JDM "
Old 04-13-2009, 04:46 PM   #10 (permalink)
i2ide's Avatar
My Ride: Acura TSX/2004/ CGP
^^ lol i was just going to say that.
'04 TSX l 5AT l CGP
CLICK HERE!
i2ide is online now   Reply With Quote
Old 04-13-2009, 05:25 PM   #11 (permalink)
ProjectTSX-N54's Avatar
My Ride: TSX/06/White
ProjectTSX-N54 is neutral and has a clean balanced record.
Classic #1:
Solution:
Classic #2:
All of us been there
ProjectTSX-N54 is offline   Reply With Quote
Old 04-13-2009, 05:36 PM   #12 (permalink)
C.R.E.A.M.
tekneek's Avatar
My Ride: 06 ASM
tekneek has a spectacular aura and a relevant respect from many.tekneek has a spectacular aura and a relevant respect from many.tekneek has a spectacular aura and a relevant respect from many.tekneek has a spectacular aura and a relevant respect from many.tekneek has a spectacular aura and a relevant respect from many.
Racism = bad
Lets just leave it at that.
tekneek is offline   Reply With Quote
Old 04-13-2009, 05:37 PM   #13 (permalink)
Donating member
My Ride: 05, Auto
That memory just suddenly popped up in my head bc when I drove through that neighborhood, there was this guy in an integra with unpainted front bumper, 2 rims in the back and 2 stock wheels in the front, fart can and he tried to race me. Further down the street there was an old rusted 240SX with a fart can and painter,black, steel wheels. There were like 5 people in it and the driver kept driving between cars at like 10 miles above the speed limit. that is why I thought of that neighborhood when I started reading this topic. Then I remembered 2 guys from my church. 1 drives a lime green, automatic altima with a wing, body kit, and muffler. The other one drives a Mercury Cougar with a very bright paint job and badges EVERYWHERE. He stuck Mercedes Benz badges on it and a small antenna on the hood and it points ahead... Then I remembered this dude from my neighborhood with an old, boxy Lude with cut springs and muffler tip cut off. I didn't mean to point out a nationality or anything, just told u about the 1st memory that popped up
Old 04-13-2009, 05:39 PM   #14 (permalink)
Donating member
My Ride: 05, Auto
Originally Posted by tekneek View Post
seriously, what were you trying to prove by saying that?
Racism = bad
I am not a racist.... come on, I just said what I remembered. I have ricers around my own neighborhood too.
Old 04-13-2009, 05:51 PM   #15 (permalink)
C.R.E.A.M.
tekneek's Avatar
My Ride: 06 ASM
Before this gets out of hand, just think before you post. If I was latino, I'd probably be offended by that, regardless of your intentions.
Enough said.
