Originally Posted by Tsx536
Hey Matt,
The flashing CEL does indicate knock with the SC setup. That's why no DTC codes were stored. You were getting knock. I ran into the same thing before with the SC setup. It would happen if I downshifting, was heavy on the throttle, and then all of a sudden let go. This seems to cause knock. I think this is because you have a lot of load on the engine, manifold pressure is built up in the manifold, and then all of a sudden you let off but the pressure is still there.
Not sure if that's the exact cause but I noticed it would only occur if I was at high RPMs and a had heavy load on the engine and suddenly let off the gas. I learned to let off the gas more progressively. Am I'm not sure if the ECU eventually learned because I didn't run into that issue in the last year or two. So anyway, this isn't a show stopper. Just try to transition more smoothly off the throttle if you're in a similar situation. I eventually learned to not get the engine reved up like unless I was for sure ready to go. Just get over and wait an extra second before getting on it, you'll be leaving those cars in your rear view anyway
Kenny, you kick ass. You've put my mind at ease with this BIGTIME. I'm glad it's a common "feature" to the reflashed S/C setup among DAYTA, yourself, and I. I'll just make sure to shift more fluidly and plan not to ride the car high in the RPM range without shifting.
Provided I attain more pleasing dyno numbers (in the vicinity of 240whp is what I'm hoping for) on my next run (next week some time), I'll be able to say I'm running A-OK.
