Old 05-05-2009, 01:19 PM   #1 (permalink)
JDM all day Everyday
InLine4's Avatar
My Ride: 2008 EVO X
InLine4 is an unknown soldier, or on the road to either parallels.
Exclamation CT ICE BOX With P2R Spacer
Hey guys
Just wanted to know if anyone has Installed the CT ICE BOX with the P2R Spacer without any issue.
If there will be an Issue how can i solve it
Just wanted to know before i purchase the P2R spacer
Thanks-inline4
InLine4 is offline   Reply With Quote
Old 05-05-2009, 01:24 PM   #2 (permalink)
TOTM 2009
IntegraGSR23's Avatar
IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.
I installed the spacer for another member no issues at all.
February 2009 TOTM The Sleeper!
The Only Easy Day Was Yesterday"
SoCal folks need parts installed? Hit me up!!
Old 05-05-2009, 01:26 PM   #3 (permalink)
reflash before i die plz
xjohnkdoex's Avatar
My Ride: Acura/TSX/2007
it'll be a tighter fit for the stock air tube going from the CT box to the IM, but it's fine. you just have to play around with it.
Old 05-05-2009, 01:37 PM   #4 (permalink)
InLine4's Avatar
My Ride: 2008 EVO X
Thanks for the input...is there anyway that i could use another tube from the IM to the CT BOX other than the stock plastic one?
Old 05-05-2009, 01:56 PM   #5 (permalink)
xjohnkdoex's Avatar
why would you need another tube? the stock one works fine.
Old 05-06-2009, 04:49 AM   #6 (permalink)
Benz's Avatar
My Ride: Acura/TSX/2005
Benz is either technically knowledgeable, or well loved.Benz is either technically knowledgeable, or well loved.Benz is either technically knowledgeable, or well loved.Benz is either technically knowledgeable, or well loved.Benz is either technically knowledgeable, or well loved.Benz is either technically knowledgeable, or well loved.Benz is either technically knowledgeable, or well loved.
what is this P2R spacer for?? What's the purpose? i see people selling it...is it the Hondata gasket spacer?
Old 05-06-2009, 04:59 AM   #7 (permalink)
Metal Head
1TSXer's Avatar
It'll work just fine. I'm running this set-up. It's a tight squeeze, but it will work.
04 CGP 6spd MT
ENGINE: Hondata Reflash, CT-E Header, Random Tech high flow cat, Apexi WS2 Exhaust, Comptech Ice Box, NST Lightwieght Crank Pulley, P2R TB Spacer/Gaskets, Hondata I.M. Gasket, Mugen oil cap, Mugen Radiator Cap, Mugen Resevoir covers, Mugen Thermo-Switch, JDM Honda Valve cover/Plug cover, Buddy Club Voltage Stabilizer/Grounding Kit,
WHEELS/TIRES: Mugen GP 18x7.5 +48 w/15mm spacers w/Hankook Ventus V12 EVO 225/40/18 2nd set:Gram Lights 57Optimise 18x7.5 +45F/+40R w/Yokohama S-Drives 225/40/18, Project Kics R40 Neo Chro Lugs
Old 05-06-2009, 10:26 AM   #8 (permalink)
xjohnkdoex's Avatar
the spacer and gaskets sit right between where the IM and TB meet.
it creates more volume for the IM (more air), and the gaskets help to reduce some heatsoak.
this is different from the hondata gasket. that's specifically for the intake manifold. incidentally, p2r makes a IMG gasket that sits in the same spot, in addition to another IMG gasket that sits in the injector base.
Old 05-06-2009, 02:24 PM   #9 (permalink)
Not JDM
evertp1's Avatar
My Ride: My Ride
is this a good mod?
-Dr. Seuss
Robert G. Allen
Old 05-07-2009, 04:07 AM   #10 (permalink)
ProjectTSX-N54's Avatar
My Ride: TSX/06/White
ProjectTSX-N54 is neutral and has a clean balanced record.
is there a picture of it? and were i can get one?
ProjectTSX-N54 is offline   Reply With Quote
Old 05-07-2009, 07:29 AM   #11 (permalink)
Metal Head
1TSXer's Avatar
corsportusa.com = showed 4HP to the wheels on a Civic Si
04 CGP 6spd MT
Old 05-07-2009, 10:34 AM   #12 (permalink)
xjohnkdoex's Avatar
i don't know if anyone ever dyno'ed before/after, but for $100 and change, it's a pretty cheap mod, and any added effect (whether hp, torque, better throttle response) would easily make it worth it.
Old 05-07-2009, 12:29 PM   #13 (permalink)
Premium Club Member
lcrazyaznl's Avatar
My Ride: Acura/Tsx/05 AT
I had good results with it the install got me stuck where i had to reverse the screws to get the original bolts off.
plus my oem gasket was fused on to the tb.
After install i noticed some better torque and throttle response also with my brockway sensor the intake temps were slightly lower than it was.
I was talking to cccolt he has the same sensor but the navi version, and our car reads the intake and engine coolant temps at such a high number.
Northeast Tsx Group
Flickr
lcrazyaznl is offline   Reply With Quote
Old 05-07-2009, 01:33 PM   #14 (permalink)
xjohnkdoex's Avatar
that's pretty good to know that the gaskets are helping.
do they still make the model you have? all i see are the huge navi ones, and i don't see the smaller/older unit anywhere.
