Old 05-05-2009, 03:34 PM   #1 (permalink)
nizmot's Avatar
My Ride: Honda Accord 2003
nizmot is neutral and has a clean balanced record.
Comptech SC problem
Hello I'm also having problems with my SC kit. Everything was installed correctly. We tried everything from timing to iVTEC,VTEC and the car has less HP than before SC.
Mods:
Injen CAI
Header
Exhaust
No cat
We use Unichip
Any suggestion?
Maybe some sensor?
nizmot is offline   Reply With Quote
Old 05-05-2009, 03:36 PM   #2 (permalink)
Premium Club Member
My Ride: TSX/05/Charcoal
Giovanni is neutral and has a clean balanced record.
what kind of problems?
Giovanni is offline   Reply With Quote
Old 05-05-2009, 03:40 PM   #3 (permalink)
nizmot's Avatar
I have much less HP than without the SC. No CEL.
Old 05-05-2009, 04:02 PM   #4 (permalink)
TOTM 2007
Tsx536's Avatar
My Ride: Acura TSX 2004
Your using Unichip to tune? What kind of air/fuel ratios are you getting?
Can the unichip control the cam angle?
K-E-N-N-Y
04 TSX CGP 5AT 265hp / 199tq
Tsx536 is online now   Reply With Quote
Old 05-05-2009, 04:05 PM   #5 (permalink)
My Ride: TSX 04 ABP
HI OFECR is neutral and has a clean balanced record.
Maybe its this "Exsaust" thing your talking about. lol
HI OFECR is offline   Reply With Quote
Old 05-05-2009, 04:07 PM   #6 (permalink)
nizmot's Avatar
Yes it can control till 20 degrese. 12:1 ratio i think I'm not sure
I should ask the tuner. But we have no clue what could be wrong.
I had like 220Hp before SC and now I have less. 215 hp
I'll ask the tuner so I can post.
Everything confirmed.
Misstyped Exhaust
Old 05-05-2009, 04:07 PM   #7 (permalink)
Boost Enthusiast
audioserf's Avatar
My Ride: Boosted 04 6MT
Check your belt tension and hook up a boost gauge to make sure you're making proper boost.
What's your a/f look like? Hopefully you got that with your dyno printout (unlike me!)
What's Unichip? Can it properly control cam changeover, fuel delivery, boost, and clamp the MAP signal? Why don't you have some kind of ECU reflash? That's included in the price of the Comptech S/C...
Edit: What Octane fuel are you using? Did you change sparkplugs when installing the S/C?
Old 05-05-2009, 04:12 PM   #8 (permalink)
TOTM 2007
Tsx536's Avatar
Yeah, try to get more specifics on unichip. I'm not sure if it can control cam angle and that is very important in our engine.
Have you ever thought for running K-Pro?
There is a guy with an Accord that made his own adapter harness. I think he sells it too. Look for his name on K20a.org
Turbo Accord K24 Kpro - V6 Performance.net Forums
K-E-N-N-Y
Old 05-05-2009, 04:14 PM   #9 (permalink)
nizmot's Avatar
I got everything with the SC kit but I'm from Europe and I can't get a reflash. And I can control everything u can with KPro. Tommorow I'll post all the plots. It is 0,4 bar(6 psi). 100 Octabe here in Slovenia. And we changed the sparkplugs.
Old 05-05-2009, 04:15 PM   #10 (permalink)
Boost Enthusiast
audioserf's Avatar
Also do you have a dyno before the S/C, or are you just guessing you had 220hp?
(I made 200whp on the dyno last week too, which I'm hoping is just caused by having had a faulty knock sensor putting the car in limp mode+CEL).
Old 05-05-2009, 04:19 PM   #11 (permalink)
nizmot's Avatar
Dynoed 217 HP on same dyno.
:: Preglej forum - Dyno tuning
Here u can see what he has done till now. It's in slovene use google translate
I have no CEL and every run is different +-20Nm(torque don't know Lb-Ft)
Old 05-05-2009, 04:22 PM   #12 (permalink)
Boost Enthusiast
audioserf's Avatar
Do you know what kind of dyno it is? (Dynojet, Mustang, etc)
Different dynos read high/low compared to others. I think Dynojet's the most common baseline, and Mustangs read a lot lower than that.
Your problem sounds a lot like what I was experiencing, honestly. Every run would be nearly identical in terms of torque (which was where it should be, give or take a few lb-ft), but HP was all over the place, and never over 200whp.
Old 05-05-2009, 04:25 PM   #13 (permalink)
nizmot's Avatar
Mustang dyno. It can read 1200HP
Mustang MD250.
If we do 5 runs they are all different. It's not like 2-3Hp it's like 20 and more.
Old 05-05-2009, 04:32 PM   #14 (permalink)
nizmot's Avatar
Did u try with the new knock sensor? Any better?
Old 05-05-2009, 05:00 PM   #15 (permalink)
Boost Enthusiast
audioserf's Avatar
If it was a Mustang, then you're right where you should be with a supercharger in terms of WHP. 210-215 on a Mustang is going to be closer to 250whp on a dynojet (DAYTA or Kenny, correct me if I'm wrong).
What I'd be concerned about is the different readings each dyno run.
No, I haven't been back on the dyno since replacing the knock sensor. I plan to run again next week (possibly on Saturday, though) and see what I get.
