05-11-2009, 01:26 PM
#1 (permalink)
My Ride: UK Accord 2003. Indigo Blue Pearl
Engine Management Light! Help!
Hi folks,
I had my high flow sports cat installed over the weekend on my UK spec Honda Accord 2.0 K20A6.
I left work at 4pm today and the engine management light has popped up. It was on constantly until i got home just after 5pm/ Is there any way i can bypass this?
I have been told to obtain an o2 sim sensor?
Any help would be much appreciated.
Thanks,
Faz
UK Accord (CL7) Indigo Blue Pearl
Engine Injen CAI, Alutec strut brace, High flow sports cat system, Throttle body by-pass
Ice x2 12" kicker subs, Hifonix BX1608 amp, 2F capacitor, Alpine 9880R headunit, Acura radio replacement unit
Exterior Limo black tints, 8000k HIDs, White LED's
Wheels & Suspension Alutec strut brace, Eibach pro-kit springs, Inovit DTM matt black / red lip
Interior Comptech shifter, Skunk2 knob, White LED's
05-11-2009, 01:33 PM
#2 (permalink)
mate i got it too next week i'm gonna try the defouller trick
if it works for me i let you know how to do it and will contact yyou on thaoc
in mean time just pull the battery negative for reset
05-11-2009, 01:35 PM
#3 (permalink)
Is it dangerous to drive the car with the engine management light on??
05-11-2009, 07:24 PM
#4 (permalink)
No. The problem is that the second o2 sensor see's the same temp as the first, so it thinks the cat isn't working.
Use defouller and it will solve your issue.
05-11-2009, 07:35 PM
#5 (permalink)
Donating member
Not at all. Buy a defouler. U can get 1 from Vibrant's website
05-12-2009, 03:44 AM
#6 (permalink)
Can i buy a spacer instead of teh defouller? Or does it not matter other than the price.
05-12-2009, 03:45 AM
#7 (permalink)
What is Vibrant's website link bud
05-12-2009, 03:49 AM
#8 (permalink)
Falken,
How long should i disconnect the battery for?
05-12-2009, 04:14 AM
#9 (permalink)
Donating member
Here.
 This should help.
05-12-2009, 04:36 AM
#10 (permalink)
Retired
Falken,
10-20 sec is all it takes for the ecu to reset iirc. Make sure you have your radio code + navi code since you will have to input those again
parting out! http://tsxclub.com/forums/tsx-classi...-part-out.html
2005 CGP AT w/ Navi
Audio | Hertz HSK165 Components | Hertz HCX165 Coaxials | Sundown SAX 100.4 | Sundown SAZ 1500D | Two - 10" SSA Icon D1 | Mercman's Harness & Balun | Dynamat Xtreme | Dice R4 w/ Text | Optima YT D35
Suspension | Progress Rear Sway | Neuspeed Strut | Buddy Club RSD Coilovers | Ingalls Rear Camber kit | Works VS-XX Hypersilver 18x7.5 +45 // 18x8+50 | Falken FK452 | Bridgestone RE960 | MOOG Endlinks | Hawk HPS | Brembo Blanks w/ X-Drill & Slotted |
Aero/Cosmetics | | Mugen Grill | JDM Hoodtrim | 20% Tints all around | Work Extended Blue Lugs | Mugen Emblem | Euro-R Front // A-spec Rear + Side Underspoilers| Window Trim DIY Blackout | Mugen Visors | Rear window spoiler | Painted IM Cover | Yakima Ski Rack |
Lighting | 05 FishDM Headlights | EDM Taillights w/ Foglights | 4300K HID Fogs | Polarg 6000k LED 194 Corners| PIAA 7440 Mirror Orange Turns
Performance | Hondata Reflash | NST Pulleys | Modded Comptech Icebox | Comptech Header | 06 Cat/Exhaust| TB Bypass
To come... | Refinish wheel lips & Powdercoat bronze
Bay area detailin holler at me!
05-12-2009, 06:13 AM
#11 (permalink)
Thanks mate.
05-12-2009, 06:14 AM
#12 (permalink)
I have an after market install so codes will not be required bud.
Cheers
05-12-2009, 10:35 AM
#13 (permalink)
Disconnected the battery at lunch for 20 mins. Seems to have done the trick no more ECL  Let's see how long it last for though.
05-12-2009, 12:24 PM
#14 (permalink)
its no dangerous but i notice if mine engine light is on in running richer on fuel
05-12-2009, 03:01 PM
#15 (permalink)
Ok another update folks. I drove home and the light has not come on, which is a good sign but i have noticed that the revs are a little on the low side around 6-700rpm where it should be just under 1000rpm. Is this because the ECU needs time to programme itself again? If somebody can explain this.
Cheers
| Thread Tools |
| Display Modes |
Linear Mode
