Originally Posted by hdiddy
A little off topic but still along the same line, anyone use oil additives or ocatane booster regularly? I use Lucas brand stuff and it seems to work well
Additives are totally unneccessary. I use 1/3 pint of Sea Foam in the intake track and 1/3 pint in the gas tank every 50,000 miles.
04 CGP 6spd MT
