Old 06-05-2009, 10:00 PM   #31 (permalink)
My Ride: acura tsx 2006
flyhigh118 is neutral and has a clean balanced record.
I was wondering i heard about a lot of the headers being talked about now but has anyone have experience with the 5zigen header? Thanks
flyhigh118 is offline   Reply With Quote
Old 06-05-2009, 10:04 PM   #32 (permalink)
Donating member
My Ride: 05, Auto
Originally Posted by chuson View Post
I see gains (3-5wtq gains) in torque from all sorts of after-market exhaust, incl. our last GTA TSX dyno meet. You will see gains @ high rpm range.
Well, at very low RPMS, TQ decreases. Speaking of less than 3k.
Originally Posted by xjohnkdoex View Post
this is pretty much me, sans the reflash since it's unavailable for the 07/08's. i have to say, there is a difference even with jus tthe header/hi-flow cat.
i'm toying with the idea of getting a single outlet exhaust for the weight reduction and to maybe eke out a little more gain.
Yep, I got header and cat on my 05 and effect, even without reflash, is very much worth the money. I mean seriously, the car revs smoother, sounds deeper and pulls waaay harder in 3-5k range. VTEC is also very pronounced. I am not thinking, I am determined to get a single outlet cat-back. 2.5 inches and either hytech twin loop muffler or HKS carbon muffler or magnaflow 2.5 inch in/out muffler (less ricey than HKS' 4 inch tip).
Originally Posted by fanbanlo View Post
does highflow cat harm torque?
No, it only helps with both power and TQ.
Old 06-05-2009, 10:36 PM   #33 (permalink)
fanbanlo's Avatar
My Ride: Acura TSX '05 AT
fanbanlo is neutral and has a clean balanced record.
anyone tried SKUNK2 MEGAPOWER K-SWAP HEADERS?
Skunk2 Racing: SKUNK2 MEGAPOWER K-SWAP HEADERS
Works with TSX right?
How does it compare to Comptech's?
fanbanlo is offline   Reply With Quote
Old 06-05-2009, 10:46 PM   #34 (permalink)
Donating member
My Ride: 05, Auto
^ Its called K- SWAP header because its designed to connect K-series engine to the exhaust system of the vehicle it was SWAPPED into........ Anyone tried swapping a K series engine into a TSX?
Old 06-05-2009, 11:01 PM   #35 (permalink)
fanbanlo's Avatar
oh..... ok... nvm
Old 06-06-2009, 03:05 AM   #36 (permalink)
TOTM 2009
IntegraGSR23's Avatar
IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.
Twin loop HyTech aint going to happen. No clearance for it!
February 2009 TOTM The Sleeper!
The Only Easy Day Was Yesterday"
SoCal folks need parts installed? Hit me up!!
Old 06-06-2009, 03:06 AM   #37 (permalink)
TOTM 2009
Originally Posted by evertp1 View Post
IMHO, its not about having the best header... its the whole exhaust system from the header to the muffler if you know what I mean. the whole system has to work together and flow well. You can have the best header, and then bad piping with too many bends and a restrictive muffler, then the header would be useless.
ie. installing high lift and longer duration cams but not upgrade valve train, the valves will float
To every action there is an equal and opposite reaction
Very true!!!
Old 06-06-2009, 04:31 AM   #38 (permalink)
Donating member
My Ride: 05, Auto
Actually, u are right. That thing may have a small tip, but the muffler itself is huge. I guess I will get a $300 carbom muffler. Anyone here got 1?
Old 06-06-2009, 02:37 PM   #39 (permalink)
fanbanlo's Avatar
If I just want header and cat changed, (since I wanna keep stock exhaust and muffler for noise reason), I guess there's no point going all the way with Hytech right?
Maybe CT's + anti-rattle mod better?
Old 06-06-2009, 02:53 PM   #40 (permalink)
fanbanlo's Avatar
anyone tried these?
Acura Headers
K Series
Old 06-06-2009, 04:20 PM   #41 (permalink)
Not A MOD3RATOR
chuson's Avatar
My Ride: 2005 Acura TSX 5AT
anyone tried these?
Acura Headers
K Series
lol... Stop looking @ K-Swap type of header, this is not a Civic or Integra with a K20/K24 in it.
Basically, there's only 2 types of header you can choose, "regular" or "race" from various brand.
"Regular" = DC, Comptech, E-bay, TopSpeed etc.
"Race" = Maxim, SSR, Hytech, Mugen etc.
Regular will net minimal gain but gain you access to emission test. Race header deleted the CAT, net more gain (full potential will unlock by K-Pro) but you will have trouble for emission test.
*** K-SWAP type is NOT for TSX ***
You can also look for CL9/CL7 header, for CL7 you will need JDM cat or JDM exhaust to hook up in order to get it fit. Other than that there's nothing much to choose from. And if you pick race remember to get K-Pro down the road or else you might **** up ya car with not much gain.
Old 06-06-2009, 04:43 PM   #42 (permalink)
i2ide's Avatar
My Ride: Acura TSX/2004/ CGP
^^idk... doug at hondata is running the skunk2 header on his.
'04 TSX l 5AT l CGP
CLICK HERE!
Old 06-06-2009, 08:03 PM   #43 (permalink)
Not A MOD3RATOR
chuson's Avatar
O Yah, I guess I miss that, which TSX did he use it on?
If any header was on Doug's TSX I think it's the Hytech Full Exhaust System unless he switched to Skunk 2 recently?
I knew Skunk 2 has custom race header for Redline GramAm but they are not for sale.
Old 06-06-2009, 08:39 PM   #44 (permalink)
i2ide's Avatar
i didnt know he had more than one. his personal one is the silver one correct? and i heard he's running the skunk2 header on that.
'04 TSX l 5AT l CGP
CLICK HERE!
Old 06-07-2009, 12:35 AM   #45 (permalink)
04pwptehsex's Avatar
My Ride: 04 pwp tsx
04pwptehsex is neutral and has a clean balanced record.
someone find out ! i like the look of that skunk2 header
interior-giga squash|full led conversion | broadway convex mirror | jdm honda fit coin holder
exterior-jdm grill w pwp trim| re-badged | 40% windshield | m3 spoiler | mugen license plate bolts |carbon m3 roof spoiler | yakima bike rack
lighting- led tag lights | led reverse lights | led trunk light
engine-battery tucked behind front bumper w/ jumper terminals in fog bezel | black im cover|black dipstick|tb coolant bypass|k&n drop in|comptech diy|polished tips | t1r purple billet oil cap | polished dress up washers and silver bolts | hood dampers | pwp sparkplug cover | t1r resivor covers | buddy club radiator cap
audio-stinger high-low adapter | memphis 12 |memphis amp | vt ported box | 4ga. wiring
chasis-17" white rsl's w. polished lip | tein basics | camber kit | r1 drilled and slotted rotors
04pwptehsex is offline   Reply With Quote
