06-04-2009, 10:22 AM
#31 (permalink)
You have to take the front bumper off, pull back the wheel well liner on the driver side and if you took everything from the stock intake out properly you should see a hole for the intake to fit through, just slide it through and attach the filter from the bottom/the wheel well.
if you look at my first pic on this page you'll see it goes down a whole into the wheel well to the right of the battery.
 The mod bug has me.
Ride: 2004 SSM TSX 6MT
Exterior: 6000k bulbs, 20% Tints, debadged
Interior: Stock
Engine/Exhaust: Injen MR in CAI mode, Ingalls "Stiffy" ETD, FLP Performance Cat.
Suspension/Wheels: Progress RSB, Stockies for now.
06-04-2009, 10:31 AM
#32 (permalink)
Yea I saw that whole, there is plastic tubbind down there. Do you take that out and then replace it with the filter? Or does the filter attach to that?
How hard is it to take the front bumper off and do all that? Because everything else I can do. Thanks a bunch man
06-04-2009, 10:35 AM
#33 (permalink)
the bumper is easy, its a couple bolts and a bunch of plastic rivets. just unscrew the bolts, pop out the rivets with a flat head screw driver and it should come off easily. the tubing has to be removed so that you can put the CAI in and have the filter sitting outside the engine bay, in the wheel well.
 The mod bug has me.
Interior: Stock
06-04-2009, 10:43 AM
#34 (permalink)
Ok, doesnt seem too challenging. Do you know of any instructions or whatever that will show this with illustractions? I get what ur saying I just like seeing a visual as well. Thank you again.
Haha if you also want to install it for me that would be great. lol
06-04-2009, 11:04 AM
#35 (permalink)
lol, buy me a plane ticket, I'd much rather be in FL anyway haha.
You're right its not challenging, it was the first mod I had ever done myself and it was very straight forward. I believe my Injen came with instructions that had pictures, if I can find it I'll scan it in and post it up, but it wont be until later today when I get off work.
 The mod bug has me.
Interior: Stock
06-04-2009, 11:28 AM
#36 (permalink)
Haha. Alright sounds good man, it wont be till later when I work on it anyway. If not, its all good, ill either try and wing it or intesivley browse the internet. Overall thanks
06-04-2009, 07:59 PM
#37 (permalink)
gotta love florida
04 TSX PWP AT
Fujita CAI, TB Coolant Bypass, Hondata IMG, P2R TB Spacer & Gaskets
98 Camaro Z28 M6
Intake, Headers, 4.10 Gears, Ram Air, Intake Manifold
06-05-2009, 11:21 AM
#38 (permalink)
Sorry I didn't find those instructions... did you just wing it? if so, how'd it go?
 The mod bug has me.
Interior: Stock
06-06-2009, 11:36 AM
#39 (permalink)
It fine. I went to the injen website and found instructions on how to do it. But then i decided to just cut it and make it a custom short ram intake. That leads me to my another question; What is the difference between the short ram intake and the regular long way (going in back of the bumper)?
It is installed and working nice. Only thing is at around 7,000 rpm it gets a little rattly, on top of the already loud humming. any suggestions or is that just how it sounds?
Thanks a bunch guys! Def. a big help
06-06-2009, 04:29 PM
#40 (permalink)
My Ride: 2006 TSX ROYAL BLUE PEARL
you cut it?? my injen came with 2 pipes, one for short ram and another for cold air. no need for cutting
06-08-2009, 12:07 PM
#41 (permalink)
i think he had a CAI from another company that was 1 piece, not 2 like our Injens. Any ways the reason for putting the filter in the wheel well is that it keeps it out of the engine bay where there is a lot of warm air... with the filter outside the engine bay it can suck in cold air, hence the name.
I believe short ram intakes help more on the bottom end while cold air intakes provide more power on the top end.
as for the rattling noise, I dunno... is everything connected properly?
 The mod bug has me.
Interior: Stock
| Thread Tools |
| Display Modes |
Linear Mode
