Old 05-28-2009, 09:07 PM   #16 (permalink)
Donating member
My Ride: 05, Auto
^ Told u...
TSX_WS is online now   Reply With Quote
Old 05-29-2009, 07:07 PM   #17 (permalink)
RML-R6Staff: Rank 5
Moderator
Entertainment
Carbon's Avatar
My Ride: 2007 CGP Acura TSX
Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.Carbon is almost as elite as a forum moderator.
Got my pulleys in today.
And I was reading the instructions and it says it does not require a new belt, however the instructions are for a 02-06 RSX/TSX Type S 2.0L DOHC, will these still fit? Im going to do my research while I let you guys contemplate this.
Just a few mods...
Carbon is offline   Reply With Quote
Old 05-29-2009, 07:24 PM   #18 (permalink)
Donating member
My Ride: 05, Auto
Is it just the camera or are they a little... scratched?
Old 05-29-2009, 07:26 PM   #19 (permalink)
RML-R6Staff: Rank 5
Moderator
Entertainment
Carbon's Avatar
Ok pulleys will fit:
914871 Underdrive 02-06 RSX Type S 2.0L DOHC 16V (DC53/ K20A2) Pulley set Includes crank, alt. & p/s pulleys
914871 Underdrive 04-06 TSX 2.4L DOHC 16V (CL9/ K24A2) Pulley set Includes crank, alt. & p/s pulleys
Now back to the belt, should we stick to the CR-V belt or the RSX, or stock like the instructions recommend?
Just a few mods...
Old 05-29-2009, 07:27 PM   #20 (permalink)
RML-R6Staff: Rank 5
Moderator
Entertainment
Carbon's Avatar
its the camera phone they machining is actually pretty top knotch.
Just a few mods...
Old 05-29-2009, 07:27 PM   #21 (permalink)
TOTM 2009
IntegraGSR23's Avatar
IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.IntegraGSR23 is either technically knowledgeable, or well loved.
Juan:
Measure them:
UR's spec
Crank: 5.125
PS:5.125
Alt:2.75
If the Ralco's are same a belt is needed
February 2009 TOTM The Sleeper!
The Only Easy Day Was Yesterday"
SoCal folks need parts installed? Hit me up!!
IntegraGSR23 is online now   Reply With Quote
Old 05-29-2009, 07:42 PM   #22 (permalink)
RML-R6Staff: Rank 5
Moderator
Entertainment
Carbon's Avatar
Ralco Specs
Crank: ~5.192
PS: ~5.192
Alt:2.75
Which is a difference of about 1/16" so Im going to go with the CR-V belt. Also my caliper's battery was dying so they could also be off.
Just a few mods...
Old 05-29-2009, 07:56 PM   #23 (permalink)
TOTM 2009
Get the shorter belt, you can always return it if not needed.
Check the tension indicator
Old 05-29-2009, 08:06 PM   #24 (permalink)
Donating member
My Ride: 05, Auto
Well, when I got my UR pulleys, the instruction stated that they would fit both RSX and TSX. RSX did not require a new belt, but TSX did and the part number for the belt came out to be the CR-V belt. My stock belt made clopping noise when I put a bit of extra pressure on the accessories. EX: if AC was on and I tried to turn the wheels while the car was parked, PS needed more power so the belt was slipping. I have had this belt for over 3 months and no issues whatsoever. In the end, it is your decision. Good luck
Old 05-29-2009, 08:37 PM   #25 (permalink)
RML-R6Staff: Rank 5
Moderator
Entertainment
Carbon's Avatar
That was my plan.
Just a few mods...
Old 06-16-2009, 12:22 PM   #26 (permalink)
My Ride: TSX/2004/5 Shades of PWP
scratchieepants has a spectacular aura and a relevant respect from many.scratchieepants has a spectacular aura and a relevant respect from many.scratchieepants has a spectacular aura and a relevant respect from many.
Originally Posted by chuson View Post
RSX belt is also good, which most ppl in GTA use.
Hey Chuson,
Is this the one?
2005 Acura RSX Type-S - Multi Rib Belt - BUY 2005 Acura RSX Type-S - Multi Rib Belt
or the CRV ones listed here (half price of the RSX):
http://www.autopartsway.ca/autoparts...WD%20EX~242348
scratchieepants is offline   Reply With Quote
Old 06-16-2009, 12:29 PM   #27 (permalink)
Not A MOD3RATOR
chuson's Avatar
My Ride: 2005 Acura TSX 5AT
Originally Posted by scratchieepants View Post
Did you order UR pulleys set?
If so I'm using the RSX-S belt. Phil (pcdawg) ordered that for me 3 yrs ago if I remembered correctly. PM him.
Old 06-16-2009, 12:40 PM   #28 (permalink)
Oh I put in an offer on vthree's Ralco Pulleys. No major issues with them being a UR replica part, so I don't mind taking a chance by paying like half of the price of the UR.
:S
I'll send pcdawg a pm. It's just that the CRV belt was mentioned earlier in the thread as being compatible... and it's like half the price of the RSX one
Old 06-16-2009, 12:45 PM   #29 (permalink)
RML-R6Staff: Rank 5
Moderator
Entertainment
Carbon's Avatar
I'm running the crv belt and it works fine.
Just a few mods...
Old 06-16-2009, 12:50 PM   #30 (permalink)
Sweeet, thanks!
And to add to the confusion, here's the listing for both belts on the american vendor site:
http://www.autopartswarehouse.com/se...=10608&Vh=CR-V
The cheaper one is the direct OE replacement... so what's the benefit of the more expensive one?
