06-09-2009, 02:39 PM
#1 (permalink)
My Ride: Acura TSX '05 AT
Can tsx w/ icebox -> Auto Car Wash?
I'm afraid the underbody spray would spray water into the intake.
Have any of you guys with icebox installed went to automatic car wash station?
06-09-2009, 02:55 PM
#2 (permalink)
Boost Enthusiast
Not going to happen. There is ample under-body plastic preventing any sprayed water from going into your intake.
I would recommend against using an automatic car wash for the sake of your clearcoat + paint, however. Those things are dreadful.
06-09-2009, 03:01 PM
#3 (permalink)
get a bucket, a hose, a sponge, some good soap, n get to work
edit: oh and dont forget the SHAMWOOOOWWWW!
 The mod bug has me.
Ride: 2004 SSM TSX 6MT
Exterior: 6000k bulbs, 20% Tints, debadged
Interior: Stock
Engine/Exhaust: Injen MR in CAI mode, Ingalls "Stiffy" ETD, FLP Performance Cat.
Suspension/Wheels: Progress RSB, Stockies for now.
06-09-2009, 03:16 PM
#4 (permalink)
Retired
I'm gonna go ahead and say yes (just so that you don't take your car to the auto car wash)
parting out! http://tsxclub.com/forums/tsx-classi...-part-out.html
2005 CGP AT w/ Navi
Audio | Hertz HSK165 Components | Hertz HCX165 Coaxials | Sundown SAX 100.4 | Sundown SAZ 1500D | Two - 10" SSA Icon D1 | Mercman's Harness & Balun | Dynamat Xtreme | Dice R4 w/ Text | Optima YT D35
Suspension | Progress Rear Sway | Neuspeed Strut | Buddy Club RSD Coilovers | Ingalls Rear Camber kit | Works VS-XX Hypersilver 18x7.5 +45 // 18x8+50 | Falken FK452 | Bridgestone RE960 | MOOG Endlinks | Hawk HPS | Brembo Blanks w/ X-Drill & Slotted |
Aero/Cosmetics | | Mugen Grill | JDM Hoodtrim | 20% Tints all around | Work Extended Blue Lugs | Mugen Emblem | Euro-R Front // A-spec Rear + Side Underspoilers| Window Trim DIY Blackout | Mugen Visors | Rear window spoiler | Painted IM Cover | Yakima Ski Rack |
Lighting | 05 FishDM Headlights | EDM Taillights w/ Foglights | 4300K HID Fogs | Polarg 6000k LED 194 Corners| PIAA 7440 Mirror Orange Turns
Performance | Hondata Reflash | NST Pulleys | Modded Comptech Icebox | Comptech Header | 06 Cat/Exhaust| TB Bypass
To come... | Refinish wheel lips & Powdercoat bronze
Bay area detailin holler at me!
06-09-2009, 03:20 PM
#5 (permalink)
lol.. but I've heard somewhere that automatic car wash actually save water!
but now I'm worried if it'll kill my engine... yikes.
06-09-2009, 03:27 PM
#6 (permalink)
Retired
If you want to be green and save water, look into optimum no rinse wash (But if your car is really caked up, you'll have to do a tradional wash with a hose)
Auto car washs will do more damage to your paint than good
2005 CGP AT w/ Navi
06-09-2009, 03:30 PM
#7 (permalink)
(: Daniel :)
Your car will be fine from getting water in it. If you look underneath and see all the coverings everywhere it will be very hard for water to get in there. Usually ppl who have stuff like hydrolocking is because they hit massive puddles that canoes go in and their CAI sucks it up lol. The Icebox isn't as low as a CAI so that's even better for you.
Autocarwash saving water...not really sure. It isn't worth the overall affects to your car though IMO. High pressure water is fine but what's killer are those huge things flying around and slapping the hell out of your car. The car washes don't clean those off so if someone goes in there with a filthy car and then you go in after the left over dirt and grime particles that get trapped in there will then be slapped about on your paint. They use basic soap too, nothing special. I would just do a full wash yourself since you will be a lot more cautious and you can trust your work. Also, those things don't always completely clean your car to begin with, you can see streaks, scratches and still spots of dirty areas after.
06-09-2009, 03:39 PM
#8 (permalink)
Donating member
In order to get hydrolocking to happen, u have to drive so that water would get into the air filter box from underneath. Then it (filter) would have to be soaked in water. Then u would have to open the throttle wide enough for the air to move the water up into the intake manifold and then make it run up the narrow intake runners into the cylinders. I drove without intake resonator in heavy (and I do mean heavy) rain and behind the other cars which produced a mist of water. I was at ~2k rpms and nothing happened.
To sum up then, chances are between 0 and 0.5% that hydrolocking will happen.
06-09-2009, 03:40 PM
#9 (permalink)
Retired
IMO the worst part is the things start to spin on your car before even the sprayers even get to lubricate your paint with the soap/water. so it's basically dragging dirt... and it isn't until after all the dirt is dragged off that the lube even gets to it - by then, all the damage is already done.
2005 CGP AT w/ Navi
06-09-2009, 03:42 PM
#10 (permalink)
Originally Posted by TSX_WS
In order to get hydrolocking to happen, u have to drive so that water would get into the air filter box from underneath. Then it would have to be soaked in water. Then u would have to open the throttle wide enough for the air to move the water up into the intake manifold and then make it run up the narrow intake runners into the cylinders. I drove without intake resonator in heavy (and I do mean heavy) rain and behind the other cars which produced a mist of water. I was at ~2k rpms and nothing happened.
but... automatic carwash has jets that shoot water from underneath to clean the underbody!
so... would it be safer if I turn off the engine during the wash?
06-09-2009, 04:24 PM
#12 (permalink)
Dont worry about hydrolocking in auto car wash... I do it all the time during the winter and I'm still fine.
In order to hydrolock you're filter/tube have to be totally submerged into water.
5AT '05 Premium White Pearl TSX
06-09-2009, 05:06 PM
#13 (permalink)
My Ride: Acura TSX/2004/ CGP
lol... if you dont wanna wash your car yourself. then spend the extra money and go to a handwash place. any reputable/dependable hand car wash businesses offer undercarriage wash as a service as well.
'04 TSX l 5AT l CGP
CLICK HERE!
#14 (permalink)
Thanks! that's what I'm looking for...
06-09-2009, 05:21 PM
#15 (permalink)
i actually bought a pack of shamwow for drying and didnt like it. It still leaves alot of water, i think its better for when you have like large amounts of water u need to absorb. my microfiber towel works better.
| Thread Tools |
| Display Modes |
Linear Mode
