06-16-2009, 03:49 PM
#1 (permalink)
Forum Vendor
I'd like to start and official Dyno Charts thread
Who has dyno charts? People ask me a lot about different power gains and I am not always sure what to tell them! I know there are a few peeps on here with some nice mods and numbers!
Marcus
Chatter is probably OK but if you have a comment, please keep this on topic. Start new discussion and questions in a new post!
Dyno Form (Copy the following form into a new post without quoting and replace the "_" with your info. If parts are stock please leave the "_" blank):
Originally Posted by my dyno form
Year / Transmission
_/_
Mods to engine and drivetrian
(please don't list suspension mods):
Intake / Throttle Body / Header / Cat-Test Pipe / Exhaust
_/_/_/_/_
Pulley Kit / Flywheel:
_/_
Cams / VTC Upgrade / Valvetrain / Pistons:
_/_/_/_
Supercharger / Turbo / Neither:
_
Engine Management or Reflash?
_
Other
_
Horsepower Peak @ RPM:
_@_
Torque Peak @ RPM:
_@_
Pic of chart:
_
ONE embed of YouTube of pull:
_
Shop name / Type of Dyno / Gear of Pull:
_/_/_
Approx Temp / Altitude / Humidity
_/_/_
Thanks for sharing!
Marcus
06-16-2009, 05:15 PM
#2 (permalink)
Donating member
Here is a dyno comparison of my 05 auto TSX with header and ghetto icebox VS header, RT cat, UR pulleys, 25 degrees hotter and fully stock air filter assembly. Testing was done on Dynojet machine, here in Sacramento.
First run- 174.08 WHP
Second run-167.08 WHP
As you can see, the car lost 7 WHP with the intake assembly returned to stock and temperature increase of roughly 25 degrees (55-80). Also, I changed stock Michelins for much softer Nexen N5000 tires so that could add a bit of rolling resistance while the car was on the dyno "bump". This is serious considering the fact that I had RT cat and UR pulleys installed AFTER the 1st dyno.... I used exactly the same type/brand of oil and fuel in both runs (Mobil 1 synthetic/Cheveron 91)
CONCLUSION: The intake is assembly and temperature of air are VERY important
Since then, I once again removed the intake resonator and did TB bypass. The juicy gain can easily be felt, especially in cool nights when it take some time for heat to be transferred to the intake manifold.
I will test the car with my current set-up before and after getting a single-outlet cat-back later this year
06-16-2009, 10:56 PM
#3 (permalink)
i'll post later. i'll save my spot.
i have reflash dyno,stock sc, sc with kpro and high boost pulley, and soon to have something else.
04' Black w/ 1 or 2 mods
06-16-2009, 11:10 PM
#4 (permalink)
2005/MT
Mods to engine and drive train:
Comptech Icebox with K&N Filter / 2006 TSX Throttle Body & Intake Manifold / HyTech Header / Renault High-Flow Cat / HyTech Exhaust
Unorthodox Pulleys
Reflash
184.3@5411
Torque Peak @ RPM:
219.6@7400
Pic of chart:
Church's Automotive / Dyna Pack / 4th
February 2009 TOTM The Sleeper!
The Only Easy Day Was Yesterday"
SoCal folks need parts installed? Hit me up!!
06-17-2009, 12:41 PM
#5 (permalink)
Not JDM
IntegraGSR23, correct me if I am wrong but shouldn't the gear pull have been in 4th gear as the ratio is closer to 1?
third: 1.43:1
fourth: 1.07:1
185 WHP/ 155WTQ/ Injen Intake/4th gear pull/ 91 Octane Sunoco
206 WHP/ 166WTQ/ Injen Intake, J's racing SPL header and 70RR exhaust/ 4th gear pull/ 91 Octane Sunoco
Graphs are SAE converted
-Dr. Seuss
Robert G. Allen
07-04-2009, 03:27 PM
#7 (permalink)
^^ nasty. i hope to be right around there after k-pro. ive got the hytech exhaust btw. I wonder how much difference the 06+ cams and the tb etc made? How does it drive?
EDIT: If you can, PM me so that this thread doesn't get de-railed.
07-04-2009, 03:28 PM
#8 (permalink)
Donating member
Originally Posted by northbridge
n I wonder how much difference the 06+ cams and the tb etc made? How does it drive?
I have a friend who is about to do a side by side dyny comparison. I will let u know if he tells me.
07-04-2009, 09:43 PM
#9 (permalink)
whatever
184.3@5411
Torque Peak @ RPM:
219.6@7400
just realized u had them backwards lol i was like oh! so much tq with hytech!!1 hahah
07-05-2009, 05:22 PM
#10 (permalink)
Not JDM
that is one beast AT
-Dr. Seuss
Robert G. Allen
08-27-2009, 10:20 PM
#11 (permalink)
My Ride: Acura TSX 2007 alabaster silver
Has anyone Dynoed a stock 07 TSX?
09-05-2009, 02:20 AM
#12 (permalink)
2005/MT
Pulley Kit / Flywheel:Engine Management or Reflash?
Unorthodox Pulleys
Reflash
184.3@5411
Torque Peak @ RPM:
219.6@7400
Pic of chart:
You got your HP and Torque figures wrong but still impressive
09-05-2009, 02:45 AM
#13 (permalink)
My Ride: Acura TSX/2006/ASM
haha yeah, i was going to say....u have more torque than HP?! how is that possible!!
Exterior: 28% tint, Nokya Hyper Yellow Fogs
Engine: Comptech Icebox, Hondata Reflash
Interior: Blue LEDs
Suspension: Comptech swaybar
Wheels: Weds Sport TC-005 18x7.5 +43
09-05-2009, 07:31 AM
#14 (permalink)
雪彫刻専家
Modifications:
A'pexi Power Intake
TB By-pass Mod
Circuit Sports oil catch can
Ground wire kit
Refer to this thread for Pics, Videos, and other details: Product Review: A'PEXi Power Intake
You'll learn the most when you... SEARCH for yourself!!
Representing TeamS3™ (チームS3™)
09-05-2009, 11:21 AM
#15 (permalink)
Metal Head
^Hey was that 04-05 and AT or 6MT?
04 CGP 6spd MT
| Thread Tools |
| Display Modes |
Linear Mode
