Old 09-20-2009, 03:58 PM   #1 (permalink)
My Ride: CL9
the_cl9 is an unknown soldier, or on the road to either parallels.
oil pump and baffle question. Need help
1. Is the RSX oil pump a direct fit on to the tsx?
2. Do you also have to change the oil pan to the rsx?
3. If not, is there a baffle for the k24 bc i only can find it for the k20?
the_cl9 is offline   Reply With Quote
Old 09-20-2009, 04:12 PM   #2 (permalink)
Hayai
kuma912's Avatar
My Ride: EP3-RR8-CL9
1. No, you need to modify it.
2. No, you can use the stock K24a2 oil pan
3. No, you need a k20a oil pan
Old 09-20-2009, 04:34 PM   #3 (permalink)
My Ride: CL9
1. what modification will be needed? (will it be easier just getting the ERL s2000 oil pump since it requires a k24 tensioner and pan?)
2. thanks
3. doesn't the the rsx have 3 different pan (auto, manual, type-s)? which one is require with the rsx oil pump on the tsx
Old 09-21-2009, 06:05 PM   #4 (permalink)
EuroRspec's Avatar
My Ride: S2000
The RSX has an aluminum pan, the TSX is stamped steel.
Exterior-Stock
Interior-Stock
Engine-Stock
Old 09-21-2009, 06:08 PM   #5 (permalink)
Hayai
kuma912's Avatar
2. thanks
1. Need to cut the oil pump to fit. You can buy one modded to fit. ERL s2000 oil pump is overkill IMHO.
3. Any will fit the K24.
