Old 09-23-2009, 02:35 AM   #1 (permalink)
aznboi0204's Avatar
My Ride: TSX/2006/Carbon Grey
aznboi0204 , with enough acceptance, will soon become famous.aznboi0204 , with enough acceptance, will soon become famous.
Installing a new exhaust
I was asked to do a writeup for this so... here it is
Tools
-3/8 Ratchet Wrench
-13mm Special Bolt Grip Tool (Makes taking off rusted and old bolts easy. Sorta pricey though)
-Floor Jack
-4 Jack Stands or something to hold your car up
-Extensions
-Breaker Bar (Any bar that you can put the wrench in to make it longer. Makes breaking bolts off a LOT easier =P)
-PB Blaster (A GOOD amount of it)
Heres a picture of the Special Bolt Grip
Directions:
Before you start, make sure you spray down the bolts connecting the catalytic converter and the exhaust with PB Blaster the night before. Make sure you do it a few times since it clears the rust off a bit. The stock exhaust is one piece so its only those 3 bolts.
1) Put your car on all 4 jack stands so you have more space to work. From here you can see your exhaust is held in by the 3 welded bolts and 3 rubber pieces, one in the middle and one at each muffler. Leave the hooks that are held in by the rubber pieces in for now.
2) Using the special bolt grip and hoping you used a lot of PB blaster, take off the bottom two bolts that hold the catalytic converter and the exhaust. Might take a while since most likely its rusted and heated on. Use the breaker bar if you need it.
3) After you took off the bottom two bolts, set up the jack near the middle of the exhaust. I did this so the exhaust wouldn't just drop because of step 4.
4) Take the hangers off from the rubber pieces.
5) With the exhaust resting on the jack, lower the jack until you have enough room for the top bolt which was the biggest pain in the ass.
6) Take off the top bolt with extensions on because there is something in the way. That's why I lowered the exhaust a bit and used the extensions.
7) After you took the top bolt off, the stock exhaust should be off.
8) Now all you do is put on the new exhaust. Do it in reverse order. Make sure you have a gasket in between the catalytic converter and the new exhaust or there's a good chance you'll have an exhaust leak and have to go through this again. I also recommend you to use a gasket between each piece of your exhaust. Mine was a press-fit exhaust but I still ordered a gasket just in case. Just make sure the bolts are tightened down and start up the car to make sure you don't have any exhaust leaks.
aznboi0204 is offline   Reply With Quote
Old 09-23-2009, 02:39 AM   #2 (permalink)
aznboi0204's Avatar
I'll take some pictures of the part you have to take off later.
Old 09-23-2009, 03:26 AM   #3 (permalink)
trancE-head
mclovintsx's Avatar
My Ride: cgp Cl9
mclovintsx is on the distinguished road to high status recognition.mclovintsx is on the distinguished road to high status recognition.mclovintsx is on the distinguished road to high status recognition.mclovintsx is on the distinguished road to high status recognition.mclovintsx is on the distinguished road to high status recognition.mclovintsx is on the distinguished road to high status recognition.mclovintsx is on the distinguished road to high status recognition.
thanks! +rep!
Domo-kun co-pilot l tint l debadged l cool white (coming soon)/interior blue leds l license plate leds l Greddy evo2 exhaust l vinyl black out trim l mugen visors l mugen grille l k&n typhoon cai (installing soon)
mclovintsx is offline   Reply With Quote
Old 09-23-2009, 10:57 AM   #4 (permalink)
My Ride: 2004 SSM TSX
CoopEuroR , with enough acceptance, will soon become famous.CoopEuroR , with enough acceptance, will soon become famous.
Can you find that "Special Bolt Grip Tool" at any hardware store or Sears or is there somewhere online that I can order from? definitely need one of those. thanks
The mod bug has me.
Ride: 2004 SSM TSX 6MT
Exterior: 6000k bulbs, 20% Tints, debadged
Interior: Stock
Engine/Exhaust: Injen MR in CAI mode, Ingalls "Stiffy" ETD, FLP Performance Cat.
Suspension/Wheels: Progress RSB, Stockies for now.
CoopEuroR is offline   Reply With Quote
Old 09-23-2009, 11:57 AM   #5 (permalink)
aznboi0204's Avatar
I would believe you can find them at any hardware store. I seen them in other places light Harbor Freight Tools, Advance Auto Parts, etc. If not, you can order them online.
Old 09-23-2009, 01:14 PM   #6 (permalink)
Thanks for showing me these, just ordered a set off Amazon, can't wait for them to get here so I can finally throw on my FLP cat. woot. +rep
The mod bug has me.
Interior: Stock
