Old 09-25-2009, 10:07 AM   #1 (permalink)
My Ride: Honda Accord Type S/ 2003/ Graphit
Tonny16 is an unknown soldier, or on the road to either parallels.
Wink comptec supercharger on euro accord
I need to know if I can supercharge a euro accord and if so do i need to mod the ecu thanks
Tonny16 is offline   Reply With Quote
Old 09-25-2009, 11:19 AM   #2 (permalink)
littlebo's Avatar
My Ride: EDM Accord Type-S CL9 2007 Carbon bronze
littlebo is neutral and has a clean balanced record.
Hi. U need to use hondata dual ecu for management, look at hondata website. Im waiting for feedback about possibility of using a tsx ecu on our EDM accord, our ecu is not compatible for this application, swap needed. I saw some EDM accord sc projects based on aem fic management but the r poor due to inability of changing rev limit, vtec engagement point , part throttle tuning and so on . I hope ill get answer soon and if i got luck ill sc my k24a3 . Also take a look that tsx has electro steering, ours has hydraulic so direct bolt on is impossible , some engineering needed.
littlebo is offline   Reply With Quote
Old 09-25-2009, 02:53 PM   #3 (permalink)
Hayai
kuma912's Avatar
My Ride: EP3-RR8-CL9
TSX does not have EPS
Old 09-26-2009, 10:36 AM   #4 (permalink)
littlebo's Avatar
Im sorry , what kind of steering it has ? I havent seen any detailed underhood photo of TSX but know that installing sc on accord has some difficulties due to belt is conflicting with steering pump housing and can be damaged. Could u please post a photo here and ill post mine to compare.
Old 09-26-2009, 02:42 PM   #5 (permalink)
Hayai
kuma912's Avatar
Old 09-28-2009, 03:21 AM   #6 (permalink)
nizmot's Avatar
My Ride: Honda Accord 2003
nizmot is neutral and has a clean balanced record.
There are no problems supercharging it.
You have 2 options. You get the dual ecu and ask Doug at Hondata to help you or try find a good tuner and try with the cheaper Unichip. I got the Unichip but isn't finished. I am waiting for the smaller pulley for more boost.
With Unichip it will be harder to tune(depends on the tuner) and there will be a lot of thinking and with Hondata it will be much easier.
nizmot is offline   Reply With Quote
Old 09-28-2009, 11:09 AM   #7 (permalink)
littlebo's Avatar
There are a lot of guys with sc'ed tsx . If you have similar setup ask someone to download their calibration from kpro . I think it can be used as scratchpad and it will be easier than start tune from zero. Unichip hasnt all those abilities as hondata has and much harder to tune.
Nizmot - do u have someone who can prove that dual ecu setup with tsx ecu works fine on euro Accord ?
