Old 10-30-2009, 11:15 PM   #46 (permalink)
My Ride: TSX/2005/SSM
northbridge has a spectacular aura and a relevant respect from many.northbridge has a spectacular aura and a relevant respect from many.northbridge has a spectacular aura and a relevant respect from many.
Originally Posted by kuma912 View Post
OP wants turbo.
im gonna get the kit toni has on his car. from his dyno plot the car seems very drivable on the street.
also saving up to do all engine building work at once and for a BBK.
HyTech full exhaust for sale: THREAD HERE
northbridge is online now   Reply With Quote
Old 10-31-2009, 01:07 AM   #47 (permalink)
Hayai
kuma912's Avatar
My Ride: EP3-RR8-CL9
How much HP you planning to hit?
kuma912 is online now   Reply With Quote
Old 10-31-2009, 11:22 AM   #48 (permalink)
My Ride: TSX/2009/Glacier Blue
Jeremiah , with enough acceptance, will soon become famous.Jeremiah , with enough acceptance, will soon become famous.
Building it yes. But you won't be able to rev as high as the other motors. There are F20C's revving up to 11000 rpm and K20A's revving up to 10000 rpm. If you do as much work to the K24A. You will only be able to rev it up to 9000 rpm. The K24A is not meant for high revs. To get it to rev to 8000 rpm you'll need to completely build your bottom end. You can get away stock at 7500 rpm. But how long will the engine last?
That I DO agree with. Perhaps a mild misunderstanding on my part, I just didn't want anyone to think that 7.5k is the highest the motor can actually go. 9k is plenty high.
K20 and F2xc motors can rev so much higher due to such a shorter stroke, but they also produce less mid range torque.
Thanks for quick reply.
Jeremiah is offline   Reply With Quote
Old 10-31-2009, 01:46 PM   #49 (permalink)
i'm gonna tune to between 300 - 350 until i swap the tranny in summer. After the swap ill shoot for 400. Even 400whp is alot for this car probably, but whatever.
Old 10-31-2009, 02:40 PM   #50 (permalink)
Hayai
kuma912's Avatar
400whp is a lot. But then again me and my friends have never built high hp cars.
Old 10-31-2009, 03:53 PM   #51 (permalink)
littlebo's Avatar
My Ride: EDM Accord Type-S CL9 2007 Carbon bronze
littlebo is neutral and has a clean balanced record.
Can add that those engines are revvy not only because of its stroke size. All internals there are very good balanced and philosophy of those engines id to make HP which is on high revs. K24 is designed for low and mid range torque , the revs isnt a big necessity for this. Its possible to build k24 with 8500 rpm but internals must be top notch balanced and engine must be builded really hard ! High power NA engines is in past, its too costly, FI is our future )
littlebo is offline   Reply With Quote
Old 10-31-2009, 04:01 PM   #52 (permalink)
TOTM 2009
BigBen's Avatar
My Ride: Acura TSX 2004
BigBen is either reputation whoring, or truly reaching the elite club.BigBen is either reputation whoring, or truly reaching the elite club.BigBen is either reputation whoring, or truly reaching the elite club.BigBen is either reputation whoring, or truly reaching the elite club.BigBen is either reputation whoring, or truly reaching the elite club.BigBen is either reputation whoring, or truly reaching the elite club.BigBen is either reputation whoring, or truly reaching the elite club.BigBen is either reputation whoring, or truly reaching the elite club.BigBen is either reputation whoring, or truly reaching the elite club.BigBen is either reputation whoring, or truly reaching the elite club.
Why don't you just do the swap 1st then build your car? IMO it will cost about the same to build your engine and boost it. You will end up paying double the tunning if you don't swap your tranny 1st.
04' Black w/ 1 or 2 mods
BigBen is offline   Reply With Quote
Old 10-31-2009, 05:53 PM   #53 (permalink)
good call.
Old 10-31-2009, 06:06 PM   #54 (permalink)
Hayai
kuma912's Avatar
Why do you want to swap the transmission? Automatic and turbo are perfect for each other.
Old 10-31-2009, 06:08 PM   #55 (permalink)
i think ill break the auto for sure with 400 whp..
i have no idea where to start with building the AT. i hear straight cut gears are a good start, but apparently they whine like hell... I have no personal experience, so i dont know.
any suggestions kuma?
Old 10-31-2009, 06:42 PM   #56 (permalink)
Hayai
kuma912's Avatar
Bulletproof your transmission. IPT has done the RSX Auto Trans and according to the acura service manual. The MCTA and MRMA transmissions are similar.
Old 10-31-2009, 07:45 PM   #57 (permalink)
littlebo's Avatar
Stock MT tranny cant hold 400 hp and huge turbo torque for a long time, be shure ) Ull need to bulletproof it too. Usually 4th gear say goodbye at high rev shifting.
One guy at redliners has iTR dc5 turbo. When he was 350+ hp his tranny lives for a half of a year, after he pushed to 450+ his next tranny RIP in 2 weeks.
Old 11-01-2009, 12:21 AM   #58 (permalink)
IPT looks like its in NJ. I would have to take off my trans and send it to them?
Im gonna look to see if i can find info on bulletproofed honda transmissions.
Old 11-01-2009, 12:42 AM   #59 (permalink)
Hayai
kuma912's Avatar
Automatic Transmission Upgrades by IPT *pics/review* - Club RSX Message Board
Old 11-01-2009, 02:11 AM   #60 (permalink)
Donating member
My Ride: 05, Auto
I agree with kuma 100%. Turbo + auto = lots of fun. Way less turbo lag, throttle just stays open and the power just keeps going.....
Tags
boost, cams, pistons, power, turbo
