Old 10-24-2009, 04:30 PM   #1 (permalink)
Happy TSX Owner
LeeMaster's Avatar
My Ride: TSX Auto/2006/CGP
LeeMaster can only hope to improve, or face mass condemn.
name me all the components that saves gas(more mpg)
i know only a few of these..
intake
air filter
i also heard Hondata reflash saves gas??
turbo saves gas if you dont floor it??
what else..?
LeeMaster is offline   Reply With Quote
Old 10-24-2009, 04:40 PM   #2 (permalink)
Hayai
kuma912's Avatar
My Ride: EP3-RR8-CL9
Your foot
Old 10-24-2009, 05:14 PM   #3 (permalink)
bluefang08's Avatar
My Ride: Acura/TSX/04'
bluefang08 has a spectacular aura and a relevant respect from many.bluefang08 has a spectacular aura and a relevant respect from many.bluefang08 has a spectacular aura and a relevant respect from many.
Originally Posted by kuma912 View Post
Your foot
That's def number one. And the man reason why I get low timid 20's for mpg.
bluefang08 is offline   Reply With Quote
Old 10-24-2009, 05:24 PM   #4 (permalink)
i2ide's Avatar
My Ride: Acura TSX/2004/ CGP
if you're complaining about gas mileage on the tsx. mmmm you should probably get a different car lol. tsx already gets pretty good gas mileage. but another thing to remember is.... most mods dont go well with fuel efficiency. a more restrictive exhaust may help though. and if you downgrade your cat to an 04/05.
make sure your tire pressure is on point every month or two.
make sure your car's wheels are aligned/balanced.
when on local roads have the windows open if it's hot
when on highway use the ac to decrease wind resistance.
and dont high rev.
those are really the only tips i could think of. other than keeping your car stock lol
'04 TSX l 5AT l CGP
CLICK HERE!
i2ide is online now   Reply With Quote
Old 10-24-2009, 05:32 PM   #5 (permalink)
Happy TSX Owner
LeeMaster's Avatar
Your foot
hahaha thats one thing i forgot to list, but yes thanks thats gotta be the most important
and dont high rev.
nice ones, oh and im not complaining about the gas mileage, i just want to expand my knowledge on the TSX. or any car in general.
Old 10-24-2009, 06:06 PM   #6 (permalink)
ThirdLane's Avatar
My Ride: Acura/TSX/2007/6spd non-navi
ThirdLane is either technically knowledgeable, or well loved.ThirdLane is either technically knowledgeable, or well loved.ThirdLane is either technically knowledgeable, or well loved.ThirdLane is either technically knowledgeable, or well loved.ThirdLane is either technically knowledgeable, or well loved.ThirdLane is either technically knowledgeable, or well loved.
and dont high rev.
Biggest myth in auto world. Using AC is substantially more hurtful to fuel economy than rolling with the windows down at highway speed. drop in aerodynamic efficiency with the windows down will be only a couple of percent. running the ac will affect fuel economy by up to 10-15%.
also going with a more restrictive exhaust would hurt fuel economy. more efficiently an engine can pump air, better fuel economy can be achieved. Try breathing in and out with a straw, you will end up working harder. Same principle with an engine. Engine is merely a heat pump, so if you restrict its air flow whether its intake side, or exhaust side, it will end up being a less efficient unit so in order to produce the same power that a less restricted engine makes, it will burn more fuel doing it.
"He who exercises government by means of his virtue may be compared to the north polar star, which keeps its place and all the stars turn towards it"
2007 Acura TSX 6spd non-navi.
Ding on the hood
ThirdLane is offline   Reply With Quote
Old 10-24-2009, 06:10 PM   #7 (permalink)
ThirdLane's Avatar
Just use common sense when driving. No crazy lead foot driving, no sudden stops, hard turns, stay within the speed limit, make sure your tires are inflated to correct pressure, make sure car is well maintained, and most importantly use your head
Ding on the hood
Old 10-24-2009, 06:11 PM   #8 (permalink)
i2ide's Avatar
idk bout the exhaust though.
if that concept was true. a straight pipe exhaust from the header would be optimal. but it isnt. ive seen it on a lot of cars.
'04 TSX l 5AT l CGP
CLICK HERE!
Old 10-24-2009, 06:17 PM   #9 (permalink)
ThirdLane's Avatar
Exhaust systems serves two purposes in a vehicle: to muffle exhaust resonance of an engine and two create some back pressure. NA engines need some back pressure in order for it to be efficient. If you open up an exhaust all the way, you lose efficiency but if you restrict it, you lose efficiency even more.
Ding on the hood
Old 10-24-2009, 06:40 PM   #10 (permalink)
Drive it like u stole it
huel's Avatar
My Ride: TSX/2004/CG
huel is an unknown soldier, or on the road to either parallels.
When on highway use the ac to decrease wind resistance.
how could this work?
huel is offline   Reply With Quote
Old 10-24-2009, 07:50 PM   #11 (permalink)
ThirdLane's Avatar
myth was that rolling on the highway with the windows down would increase aero drag because of the open windows so some thought closing the windows and running the ac would be better for fuel efficiency sake. But sacrifice in aero efficiency with the windows down is next to nothing compared to running with the ac. Its been proven that running with the ac on(on a traditional belt driven compressor system) with affect fuel economy by up to 10-15%. Even all electric system ac systems like on the Prius will affect fuel economy by 5 to maybe 10%.
Ding on the hood
Old 10-24-2009, 07:59 PM   #12 (permalink)
trancE-head
mclovintsx's Avatar
My Ride: cgp Cl9
mclovintsx is on the distinguished road to high status recognition.mclovintsx is on the distinguished road to high status recognition.mclovintsx is on the distinguished road to high status recognition.mclovintsx is on the distinguished road to high status recognition.mclovintsx is on the distinguished road to high status recognition.mclovintsx is on the distinguished road to high status recognition.mclovintsx is on the distinguished road to high status recognition.
Well on highways, I roll the windows up and use the AC but I only set it at the lowest point, so 1. or you can open the moonroof from the back where it tilts up, and open the air vents so it'll be like an AC.
Domo-kun co-pilot l tint l debadged l cool white (coming soon)/interior blue leds l license plate leds l Greddy evo2 exhaust l vinyl black out trim l mugen visors l mugen grille l k&n typhoon cai (installing soon)
mclovintsx is offline   Reply With Quote
Old 10-24-2009, 08:00 PM   #13 (permalink)
trancE-head
mclovintsx's Avatar
My Ride: cgp Cl9
oh you can also lose weight. Less weight, less gas.
Old 10-24-2009, 08:28 PM   #14 (permalink)
My Ride: TSX/05/Silver
CraZie , with enough acceptance, will soon become famous.CraZie , with enough acceptance, will soon become famous.CraZie , with enough acceptance, will soon become famous.
+1 on weight reduction. haha
FS: Falken Torque 5's 19" FK452
- 20% tint - BlueBat Overlays - Painted Calipers - Russell SS Brake Lines - Hawk Ceramics Pads - Rotora Slotted F/R Rotors - iSimple - JDM Fog Lights
CraZie is offline   Reply With Quote
Old 10-25-2009, 01:39 AM   #15 (permalink)
My Ride: TSX/2009/Glacier Blue
Jeremiah , with enough acceptance, will soon become famous.Jeremiah , with enough acceptance, will soon become famous.
The exhaust restriction is the worst idea ever. Restriction creates pumping losses, this is bad, and hurts the motors efficiency.
If you want better gas mileage, I would say airflow restrictions, remove them, leave the cat, or at least a high flow REAL cat on... and less weight. One thing that no one ever brings up is longer gears. The tsx tranny has super short gears. Older honda's I've had had substantially longer gears. After I did a ported head, with opened intake manifold, bigger throttle, decked head, and header of course i/h/e (also had fidanza flywheel) I took my 28~29 mpg 98 accord to roughly 34 mpg on the highway. I could cruise at 80 miles an hour in 5th gear at less than 3k rpms... On my tsx to do 60 miles an hour, I am just at 3k rpms...
If you had a taller final drive, or a taller 6th gear, where the engine could turn significantly slower at highway speed, you would get better mileage. However, seems that this is not a option anyone even entertains here...
That's how GM gets the corvette to get the mileage it does... it's 6th gear is like a 2:1 it's rediculous and the motor turns at like 1500 or so 65. (haven't driven the car, so I cannot say, but you can do the math for the tranny with their information on their web site.)
I also think for boosted apps a taller gear option would be great, because accelerating under boost with long gears is alot of fun, and yields good mileage, relatively speaking.
Anyway, since I am sure my words probably aren't taken too seriously... I did some research for you to read on your own...
http://en.wikipedia.org/wiki/Fuel_efficiency
http://en.wikipedia.org/wiki/Engine_efficiency
http://www.gminsidenews.com/forums/f...t-gm-do-59205/
http://answers.yahoo.com/question/in...3213806AAqr3CQ
Hopefully some of this can help you??
Jeremiah is offline   Reply With Quote
